AC A320 slides off runway at YYZ
Boreas
Re: AC A320 slides off runway at YYZ
Post by Boreas »
I don't have any inside details on what happened here, but while on topic, the GTAA needs to get it together and groove some of those runways.
If you're gonna pretend you're a world-class airport...
We_tu_lo
Post by We_tu_lo »
Hmm, sounds suspiciously familiar. As far as I know, no changes were put into effect after the "Hard landing" at YHZ.
crazyaviator
Post by crazyaviator »
He said that after about an hour and a half, the passengers disembarked and were taken in buses back to the terminal.
Canada's biggest airport and this is how long it took for the collective intelligence to determine it was safe to exit the aircraft ?
Rockie
Post by Rockie »
We_tu_lo wrote:Hmm, sounds suspiciously familiar. As far as I know, no changes were put into effect after the "Hard landing" at YHZ.
One has nothing to do with the other, and you have no knowledge to comment on any changes that may or may not have been put into affect.
schnitzel2k3
Post by schnitzel2k3 »
AC 623 - YYZ
AC 624 -YHZ
AC 620 - YYZ DC-8 :shock:
Bad juju with that flight number.
S.
aerodude
Post by aerodude »
Sky clear and crosswind, use the 06's and 05.
Light winds and low vis, land aircraft on the shortest wet runway with no centerline lighting: 15R....
Got to love CYYZ. Never surprised.
Right!
Poor, poor job being done there...
Crew probably didn't find out the runway until 3/4 way down the STAR too...
YYZSaabGuy
Post by YYZSaabGuy »
Less a safety issue than that most operators, including the GTAA, don't keep a fleet of buses and drivers on stand-by to respond to occasional post-midnight runway excursions. It takes a bit of time to get the logistics organized.
Bede
Post by Bede »
Boreas wrote:I don't have any inside details on what happened here, but while on topic, the GTAA needs to get it together and groove some of those runways.
You can't groove runways in such cold climates because of ice expansion in the grooves during the winter.
av8ts
Post by av8ts »
Ottawa has grooved runway
Dick
Location: A position or point in physical space. That's where I am!
Post by Dick »
Most pilots don't need a runway to be grooved to stay on it.
Maynard
Post by Maynard »
31 in Ywg is grooved. Pretty cold there
Rockie
Post by Rockie »
Dick wrote:Most pilots don't need a runway to be grooved to stay on it.
Why don't you save the witty criticism until it's actually known what happened?
Could a failure of the tires have caused it?
Rockie
Post by Rockie »
Possibly, pure conjecture though. Wait for the report.
GyvAir
Post by GyvAir »
Looks like one flat, but all present:
https://pbs.twimg.com/media/C5fgiiQUwAE3sZW.jpg
(Sorry.. not sure how to embed this pic)
From another forum....wouldn't using low vis runways make more sense?
"AC623 arrived just after midnight EST (0500Z):
Cyyz 250600z 14002kt 3sm -ra br ovc003 03/03 a2950 rmk ns8 slp997
Cyyz 250542z 08010kt 2sm -ra br ovc003 03/03 a2949 rmk ns8 presfr slp992
Cyyz 250528z 06009kt 3/4sm r15l/p6000ft/u r06l/p6000ft/d r05/6000ft/d r15r/p6000ft/u -shra br vv002 03/03 a2951 rmk fg8 presfr slp998
Cyyz 250515z vrb07kt 3/4sm r15l/2600vp6000ft/u r24r/3000v6000ft/u r15r/3000vp6000ft/u -tsra br vv002 03/03 a2956 rmk fg8 ocnl ltgic
Cyyz 250500z vrb02kt 3/8sm r15l/2800ft/n r24r/3000ft/d r15r/3500ft/u -tsra fg vv001 03/03 a2956 rmk fg8 ocnl ltgic presfr slp018
Cyyz 250450z 22005kt 170v230 3/8sm r15l/3000ft/n r24r/3500v5000ft/u r15r/3500ft/u -tsra vv001 03/03 a2959 rmk fg8 ocnl ltgic presrr slp028
Cyyz 250429z vrb03kt 3/8sm r15l/3000ft/n r24r/3000ft/n r15r/3000ft/d fg vv001 03/03 a2956 rmk fg8 presfr slp017
Cyyz 250400z 12006kt 1/2sm r15l/4500vp6000ft/n r24r/4000v5500ft/d r15r/3000v5500ft/d fg vv002 03/03 a2956 rmk fg8 slp017
Cyyz 250313z 11007kt 1/4sm r15l/2800vp6000ft/d r24r/2600ft/n r15r/3500v4500ft/n fg vv001 03/03 a2956 rmk fg8 slp017
Cyyz 250300z 11007kt 1/2sm r15l/3500vp6000ft/u r24r/3500ft/d r15r/5000ft/d fg vv0 "
ATC recording. Start from the beginning.
http://archive-server.liveatc.net/cyyz/ ... -0500Z.mp3
complexintentions
Post by complexintentions »
pelmet wrote:From another forum....wouldn't using low vis runways make more sense?
VV001.
Not like it was sudden. At 0300Z, VV0.
My Jepps show 15R is Cat 1 only.
There are certain annoying aspects of European airport operations, but one thing I do like is they go into LVO ops long before the weather is this bad.
This will annoy our resident speculation-police, but perhaps they were attempting to autoland on an unprotected signal and then the localizer took them for a ride? À la Singapore in MUC (2011).
Do those old 320's even have centreline guidance after landing?
C'mon Rockie. Your company, your fleet, your type. It's foolish to think there will be no wondering what happened, might as well make the conversation intelligent. I got asked a lot about EK521 and I didn't even work there anymore. I didn't mind.
cossack
Post by cossack »
More YYZ bashing for no good reason.
Was there any reason to evacuate the aircraft? Apparently not.
No buses at YYZ after midnight? Shocking. Lets have 3 guys sitting in their buses just in case from now on.
aerodude wrote:Sky clear and crosswind, use the 06's and 05.
Your first line describes the usual operation where we are capacity constrained and using the E-W runways with a high crosswind to maintain the capacity that your airlines demand. We'd happily go to the 33s or 15s and you can sit on the ground elsewhere for a couple of hours.
I wasn't working but it takes something out of the ordinary to put YYZ onto the 15s. Where were the TS cells? Maybe that was the driving factor here. 15R is the shortest runway but its not that short. It was reduced vis not low vis. Big difference.
altiplano wrote:Right!
And you know that because... Where were you at the time?
complexintentions wrote:Not like it was sudden. At 0300Z, VV0.
Weather was within limits for that runway. If it wasn't, they wouldn't have landed on it. Why they didn't stay on it is a separate matter.
We don't go into LVO before the weather dictates it. There is RVO first and all runways in YYZ are available for RVO. If we went LVO and advertised Cat2 and 3 only the airlines would say we are being too restrictive. Can't have it both ways.
If the tire caused the excursion it wouldn't matter which runway they landed on.
Get a grip.
Bede
Post by Bede »
av8ts wrote:Ottawa has grooved runway
I was thinking more of MIA-type of grooves. The one's that actually work.
complexintentions
Yeeeahhh I call bullshit on this one. Going into LVO with VV100 isn't exactly radical. I've never heard about airlines going into LHR/FRA/AMS complaining about having to hold because of LVO ops with wx as reported during the incident flight.
Why not just admit that even with the highest landing fees in the world the airport doesn't even have centreline lighting or approaches above Cat 1 on most runways? Not saying that it contributed to AC's offroading adventure but come on. It's 2017. The aircraft are equipped, time for Canada to join the modern age.
Rockie, does this mean you're not going to bid the 624/623 pairing anymore? :lol:
Seriously though, I don't agree with your objection to speculation, as long as it's expressed as such and not fact. I know it's hard to tell sometimes, but there actually is a fair bit of intelligence on this forum mixed into the nonsense, and healthy theorizing at least gets people thinking about threats and possible ways to counter them. I only tease because the incident seems fairly benign as they go, there'd be no joking around if it was something more serious.
Ancient
Post by Ancient »
For the last 5 years we've been seeing reports from watchdogs saying automation is dulling airline pilots skills. Perhaps we are now seeing that come to roost. That Montego Bay report was shocking to read. Can't say I've read the YHZ report yet. We have been very very lucky that no one has been killed in these near disasters. I hope it won't take fatalities for there to be a change in the industry if there is a trend developing. I don't think airplanes landing short, or wide, or hard is benign.
complexintentions
They didn't land wide, short, long, or hard. They landed, and then were not able to stay on the runway. Why? Don't know yet. But given the apparently minimal damage and total lack of injuries and fatalities, yeah I'd say it's pretty benign as incidents go.
Don't cherry-pick my words, please.
