What airplane was the most difficult to fly?
- Cat Driver
The most demanding airplane I flew was the Grumman Turbo Goose.
Short coupled and lots of torque and P factor on take off.
Demanding to land on the runway with cross winds.
Liked to porpoise on rough water.
Had to be careful with power settings in cruise because it was easy to get in the VNE speed range.
The visibility in turns was terrible because of the engines sticking way out in front.
But the sucker sure was a blast to fly.
Schooner69A
Re: What airplane was the most difficult to fly?
Because of the limited number of fixed and rotary wing aircraft in my logbook, I can't say as I ever flew one that I considered difficult. Although, I recently flew a Stinson that was nearly as old as I am and I marvelled that there are still people who love them. Not because it was difficult to fly - it was actually quite benign - but because it was an OLD airplane with OLD technology and switchology. Overhead co-located rudder and elevator trim, slightly reclining seats, wicked visibility, and in general, a reluctance to climb or cruise very fast. On 150 HP.
Harrumph... (;>0)
Harrumph... (;>0)
Grumman Tracker or Conair Firecat. That sucker was determined to kill me, partly because of the way we flew it but one tried to blow me up, high speed stall, low speed stall, uncontrolled pitch-up, rudder stall in a strong crosswind (that was a surprise), useless brakes (carriers had arrestor cables), absolutely unstable (which is why it was so maneuverable - dont drop your pen while doing your logbook) not to mention blowing engines.
It was one of my favourites though, but I got off it before it got me.
Funny, Cat, another Grumman!
- Jack Klumpus
From the types I've flown, the metro 23 was not the funnest for 12 leg days with no auto pilot.
When I retire, I’ll miss the clowns, not the circus.
My Thurston Teal (probably a little Grumman in the design here and there) will make you happy resulting from where you are able to fly it, rather than that you flew it! As Xbank remarks about the Tracker, if you take your eyes off it for a moment, it'll be pointed a different direction - particularly on the runway! It's less stable than some helicopters I have flown.
Another type which challenged me was the Siai Marchetti 1019. It had a little too much power for the rudder to overcome if you used it all at the start of takeoff (even though the flight manual recommended 95% power then brake release). Worse, a 30 flap takeoff (flight manual short field procedure) would get you to a place in early climb where full nose down control was required, and the nose was still going up. And it had no supplementary stall warning system, so you had to be alert, 'cause stick force was no longer a cue. It was fine once you got used to it, but it took some awareness, self teaching, and practice.
crazyaviator
I'd say mine is the Jetstream 31. Although it wasn't all that "hard" to fly, it was a demanding and unforgiving airplane. Negatively stable with high take-off and landing speeds and no autopilot. Add some ice and it was interesting. You sure earned your money on a 10+ leg day in sh!tty weather. My instrument hand flying skills/scan have never been better than when flying this airplane that's for sure.
- Rank Moderator
My first twin: Piper Seminole - the damn engine kept quitting at the most inopportune time!
Happiness is V1 at Thompson!
Reminds me of one of Multi Rating students. He said " How come I am paying for 2 engines. but I only get to use them one at a time ? "North Shore wrote:My first twin: Piper Seminole - the damn engine kept quitting at the most inopportune time!
For me it was the Air Tractor AT-802. Very sensitive high lift wing that reacts to every little ripple in the air. A turbulent summer's day makes you feel like you just spent hours in a clothes dryer.
B-25 is probably the hardest to consistently land well. Otherwise, civil specifications forces aircraft to be fairly easy up and away.
Going for the deck at corner
+ 1Rudy wrote:For me it was the Air Tractor AT-802. Very sensitive high lift wing that reacts to every little ripple in the air. A turbulent summer's day makes you feel like you just spent hours in a clothes dryer.
The crappiest flying characteristics of any aircraft I have ever flown.
Forestdump
I'm guessing it doesn't get any better with the floats attached. A wise man pointed out to me recently that it is indeed an Ag airplane. It's not built to fly, it's built to survive a crash.
Metro II (SW3)
Not enough wing nor power
Not enough rudder especially single engine with more than 1/4 or 1/2 flap, it's been awhile
Nose wheel steering was forever failing with or without a failure annunciation
MU II. Worst ice magnet I've flown. Picked up ice on nose and prop spinners and made cup like shapes. Slowed aircraft down quickly and unable to maintain altitude many times
None - just need to master the type idiosyncrasies, having said that there are hateful days in any type. That seems to be more what is being said here. Air planes are simply not difficult to fly. Some are just uglier than others. Something like my love life
http://www.blackair.ca
I have had to deal with some annoying autoland characteristics. Nosegear coming down too fast, maximum wind limitations,.valleyboy wrote:None - just need to master the type idiosyncrasies, having said that there are hateful days in any type. That seems to be more what is being said here. Air planes are simply not difficult to fly.
- Cat Driver
Are you saying there are no airplanes that require you to be extra vigilant when flying them?None - just need to master the type idiosyncrasies, having said that there are hateful days in any type. That seems to be more what is being said here. Air planes are simply not difficult to fly. Some are just uglier than others.
It is true that all certified airplanes are designed to be flown by all pilots who are licensed and type rated/ familiar with the type being flown.
Having said that I have found some are significantly more difficult to fly properly than others and of all the different airplanes I have flown the Turbo Goose was the most demanding, for sure I would not advise someone without a lot of flying boat time to just jump in it and try and take off or land in difficult conditions.
Have a look at how short coupled it is and how far those props are forward and it will give you a better idea of what it handles like on take off.
https://www.youtube.com/watch?v=3wCmrqy070o
Illya Kuryakin
Kind of in the same boat as valleyboy on this. Some are nicer to fly than others. The 150 is as hard to fly as anything. The Cessna 320 and the Lark Commandet are hideous handling pieces of crap. You have to be "on to" the 748 at night in the rain going into Red Sucker....the Vampire was interesting.....a Twin Comanche has a positive angle of attack on the ground, so landings could be a challenge. As for "hard to fly"? Nope. None.
Illya
Illya
I'm in the same boat as well. The environment makes more of a difference to me than the actual aircraft itself. Planes are designed to certain standards. They have to be stable, structurally sound, controllable.
High performance planes demand more attention, but that's why you start on basic ones. Learning principle of Relationship.
Give you an example. The RCAF tried to make the Tutor the primary trainer back in the 60s when the Chipmunk and Harvard were retired. New aircraft, nosewheel, simple turbine engine, side by side seating for the best instruction. The ensuing washout rate was like 90%, so they got the Musketeer.
Does that make the Tutor hard to fly? No. I've never flown one but from what I've heard it has few vices,, but it's not something to start even the most elite selection of zero hour candidates on.
Now the Snowbirds use the Tutor. Could a very experienced pilot just hop in one and fly with the team? Not a chance. Heck, they are curtailing their schedule because they feel the very experienced team members need more practice.
That's why I say the operating environment and relative skil is what makes a plane hard to fly, vs the aircraft itself.
Schooner69A
"...The ensuing washout rate was like 90%, so they got the Musketeer."
It wasn't that the Tutor was particularly hard to fly, but the Tutor turned out to be a very expensive airplane to find out that a student got airsick, wasn't motivated, wasn't coordinated, hated flying, didn't like authority, just needed a place for the winter, etc. The Chipmunk was actually resurrected to play its part as a selection vehicle until the Musketeer was purchased.
- Cat Driver
You sound like a Canadian flight instructor with your instructors flying bible in your back pocket.Learning principle of Relationship.
- confusedalot
Beech 18, only about 20 hours in it circa 1981. Bitch in a crosswind and forget about single engine cruise LOL, otherwise fun to fly.
second up is the HS 748, more like operating a submarine than an airplane.
got spoiled after that. the bigger they get, the easier to operate.
- Cat Driver
The Beech 18 on floats is an awesome airplane...it was my favorite float plane.
