Cameron Air CYTZ
Cameron Air CYTZ
Any updates on working and pay conditions working for Cameron Air down at CYTZ?
How much time do they want to get on the 206?
Re: Cameron Air CYTZ
Does anyone have any info on this? Couldn't find any info on Cameron Air's pay or working conditions using the search function. Feel free to PM me instead if you'd prefer.
Thank you.
Thank you.
One of the owners is a convicted pedophile, so there's that.
Yikes.Tbayer2021 wrote: ↑Wed Jan 19, 2022 11:52 am One of the owners is a convicted pedophile, so there's that.
WOW! Thanks for posting the article. Scary stuff to say the least.
Rent in Toronto will cost you 2000$ or more a month, and they expect you to work for peanuts.
Don't let your wife talk you out of buying an airplane,
There’s potential to get loads of hours once the float planes are going. I’ve seen three come into St. Catharines all at once, they certainly appear to be good at the game of how to look after the many available customers around Toronto. Only money talks here (it’s expensive equipment), and there you must be more-so wary of the wide range in personalities of passengers you will run into as well.
The destinations cover a wider area, so accomodation is not necessarily in the heart of the City when so many return trips are going elsewhere.
Another perk is you might get some investment tips from Kevin O'Leary, too, on the flight up to the lakes.
Is Cameron Air busy flying customers to cottage country?
if you are on the ground I guess there is now way but to look up!
I worked there for two years and loved it. The flying is fun, you meet interesting people, and the planes are all in good shape. They have a very busy PC-12 now as well.
Last I heard, your compensation will be 35,000 / year.
You will have the opportunity to fly the right seat in the PC-12NG. And after about a year on the 206, you can go to the Caravan. And then after a year of that, you can be a dedicated PC-12 crew. Note that this info is from 2021, so some things may have changed. It's probably a decent place to build float time if you can afford it.
Thanks for the info, how much float time do you think they want today?Loading... wrote: ↑Fri Jun 09, 2023 7:47 am Last I heard, your compensation will be 35,000 / year.
They only require 7 hours. Minimum for float rating.ellinas wrote: ↑Fri Jun 09, 2023 9:29 amThanks for the info, how much float time do you think they want today?Loading... wrote: ↑Fri Jun 09, 2023 7:47 am Last I heard, your compensation will be 35,000 / year.
So if I apply at Cameron with 100 hours of my float time they might look at me? Doesn’t hurt to tryLoading... wrote: ↑Fri Jun 09, 2023 9:37 amThey only require 7 hours. Minimum for float rating.ellinas wrote: ↑Fri Jun 09, 2023 9:29 amThanks for the info, how much float time do you think they want today?Loading... wrote: ↑Fri Jun 09, 2023 7:47 am Last I heard, your compensation will be 35,000 / year.
Yes I certaintly would. Good luck!ellinas wrote: ↑Fri Jun 09, 2023 5:40 pmSo if I apply at Cameron with 100 hours of my float time they might look at me? Doesn’t hurt to try
I made more than $35K on the 206 in 2020. It's only gone up since then, I still know people that work there. The job is fun, the planes are pretty good, and the flying is great.Loading... wrote: ↑Fri Jun 09, 2023 7:47 am Last I heard, your compensation will be 35,000 / year.
How many float hours did you have when you were hired as I think they’re looking for 250 or 500 hours on floats due to their clientele. I applied with 100 hours on floats but haven’t heard back .FishermanIvan wrote: ↑Thu Jun 15, 2023 1:04 pmI made more than $35K on the 206 in 2020. It's only gone up since then, I still know people that work there. The job is fun, the planes are pretty good, and the flying is great.Loading... wrote: ↑Fri Jun 09, 2023 7:47 am Last I heard, your compensation will be 35,000 / year.
I had about 300 hours or so, if I remember right.ellinas wrote: ↑Thu Jun 15, 2023 2:52 pmHow many float hours did you have when you were hired as I think they’re looking for 250 or 500 hours on floats due to their clientele. I applied with 100 hours on floats but haven’t heard back .FishermanIvan wrote: ↑Thu Jun 15, 2023 1:04 pmI made more than $35K on the 206 in 2020. It's only gone up since then, I still know people that work there. The job is fun, the planes are pretty good, and the flying is great.Loading... wrote: ↑Fri Jun 09, 2023 7:47 am Last I heard, your compensation will be 35,000 / year.
