deHavilland Otter kit?
Is there a home build kit for the de Havilland DHC-3 Otter? Are there any other planes with similar fuselage dimensions that can be home build kits?
piperdriver
Re: deHavilland Otter kit?
Ah, come 'on.... It'd be fun to watch someone remove from their basement, and trailer to the airport!No and no.
Another reason for why not would be:
[Amateur built aircraft]
(Ref. AMA 549.103/2).
(b) Aeroplanes:
(1) The maximum permissible take-off mass M shall not exceed 1,800 Kg (weight W=3,968 lb).
citabriaguy
No twin only.
Btw do you have the 2 or 3 car garage?
Should we give him Viking's number? I mean, I'm sure they'd get a kick out of restarting the Otter production line for a one-off.
I have a massive barn.citabriaguy wrote:No twin only.
you could buy and build a small homebuilt (google is your friend) to get you feet wet so to speak then look for or design one to suit your purposes. join the local homebuilders club and get started.
Well, except for if the purpose is to carry "Otter" sized payload, the CARs will not allow you to build an aircraft anywhere large enough.then look for or design one to suit your purposes.
How about an airship? Powered balloon or hybrid blimp, dirigible, whatever you call it.
RebelCFTQC
I think the closest you will get in a homebuilt is a Murphy Moose 3500lbs gross.Krazer12 wrote:Is there a home build kit for the de Havilland DHC-3 Otter? Are there any other planes with similar fuselage dimensions that can be home build kits?
NunavutPA-12
There are cheaper ways to get your ATV to camp.Krazer12 wrote:Is there a home build kit for the de Havilland DHC-3 Otter? Are there any other planes with similar fuselage dimensions that can be home build kits?
On the other hand, if you have five years and a few hundred thousand bucks just lying around ....
