My First ILS to minimums
dirtdr
Post by dirtdr »
Got a neat video this weekend and thought I'd share.
My first "real" ILS to minimums
Approach lights at 2:02
Minimum altitude at 2:03
1968 Cessna 310N
CYEG runway 30
https://youtu.be/WdbUoXDi1Dc?t=1m50s
Black_Tusk
Re: My First ILS to minimums
Post by Black_Tusk »
Half scale off on the LOC, breaking out well left of the runway edge... seems a bit unstable, no? In my opinion a go around was in order.
Jimmy2
Post by Jimmy2 »
Yikes.
I'd say staying within flight test limits on your first solo ILS to minima is pretty good. Half a dot deflection would obviously have been better, but let's be realistic. Consistently flying the ILS within half a dot takes practice. Especially if you only do it once in a blue moon.
So I'd say good job!
Well from looking at that video there is no way in hell I would not have landed from that arrival.
To go around just because you are slightly off center line means you are opening yourself to maybe not seeing anything on the next approach.
The intent of an instrument approach is to land if you can safely see the landing area....he did and he did.
And so would I have.
Chuck Finley
Post by Chuck Finley »
That didn't look half bad for his first one. Especially if hand bombed!
Nicely equipped 310 too!
CpnCrunch
Post by CpnCrunch »
Also, he was going at 150kt right down to short final. If anyone else can do better, please post a youtube video before criticising!
PS, what was the reason for 150kt?
dirtdr
Post by dirtdr »
CpnCrunch wrote:Also, he was going at 150kt right down to short final. If anyone else can do better, please post a youtube video before criticising!
I like to keep a lot of energy in case I go missed.
So my procedure is to clean up as little as possible on the way down.
15 flaps on the way in once I'm under 180. This usually gets me 150 with the same power setting.
Gear down once intercepting the glideslope. No power change and 150mph and 500'/min down. If I need to go around, it's just full power, gear up and I'm into my best rate of climb of 125ish with no trim changes or manhandling the yoke. Once climbing then I take out all the flaps and have room to trim back if needed
Now I have lots of energy if I go missed. If I have all my flaps out, and 115mph, I am pretty busy to get climbing again in the event of a missed approach.
If I didn't have 10,000ft runway in front of me, I likely would have slowed her down a bit more on the way down.
I dump full flaps upon sight of the runway. In this case I touched down 1500feet down a 10,000ft runway. A little longer than I would have liked, but...
dirtdr
Post by dirtdr »
. Finley wrote:That didn't look half bad for his first one. Especially if hand bombed!
All hand bombed. Next on the list is a reliable autopilot
confusedalot
Post by confusedalot »
First time, pretty good. On or very close to the centreline.
Taxivasion
Post by Taxivasion »
:shock:
Good job, it was safe and that is what matters. :smt040
How many of you remember the good old days when we could get GCA at civilian airports?
That sure took a lot of the work out of flying the approach and the landing.
Hell while I am asking questions how many here remember Radio Range approaches?
The ASI in a 310 N is marked in MPH. 150 Mph = 130 knots, a pretty reasonable speed for a long runway for an approach you know is going to be close.
While ideally you break out right on the center line I would agree with Cat Driver that continuing the approach was not unreasonable. The good news was the adjustment to position the aircraft on the centerline was gentle and smooth. This is definitely the time when you don't want to be cranking it around.
The even better news is that precision approaches where you break out right at minimums are not that common. I would guess that over my whole career I have flown less than a dozen ILS like that one. Either it is a no hoper and you know you are going around or you break out a bit above minimums.
Re PAR's. It was a sad day when the PAR at Comox was decommissioned. I always tried to get one when I went there. The PAR controllers sure were good :D
CpnCrunch
Post by CpnCrunch »
The glass panel seems to be showing 150. Is that in mph too?
dirtdr
Post by dirtdr »
CpnCrunch wrote:The glass panel seems to be showing 150. Is that in mph too?
Yup
SnotRocket
Post by SnotRocket »
Taxivasion wrote:
:shock:
+ 1
Schooner69A
Post by Schooner69A »
CAT: I'll see your Radio Range Approach and raise you an Aural Null Approach. (;>0)
(I can hear it now: "The Olde Phartes are reminiscing again...")
Do you use a hand operated loop antenna or go with a newer one with a BFO selection?
Zaibatsu
Post by Zaibatsu »
How about an old loop with no sense antenna? Watch out for reverse bearings!
I thought that was really good for a hand-bombed approach. How many of you have flown from the marker to DH by hand? Disconnecting the autopilot when the trim and power is all set isn't quite the same.
Personally, I've only done it in the sim. I did better but I'm not convinced it wasn't fluke or that the sim is 100% representative of real conditions.
One thing I noticed you did which is perhaps why you were half scale was holding attitude and heading as you got close. This is the best thing to do rather than chasing the ever more sensitive loc and gs as you get closer. You got the approach lights and then corrected visually, exactly how you're supposed to.
If you have a flight director in your EFIS capable of displaying approach guidance, it would make it even better.
Black_Tusk
Zaibatsu wrote:How many of you have flown from the marker to DH by hand?
I'm going to gather that many have. Fly a piston twin, B1900, Metro etc up north? ILS's, LPV's to minimums in winter every day with no flight director, A/P and on steam guages (well maybe the B1900 and Metro may have F/Ds).
FAD3C
Post by FAD3C »
+1. Did that very same approach on Jetstreams with no AP or FD. ILS's and LPV's to mins is daily bread up north specially during the fall months.
ogc
Post by ogc »
I spent years doing that myself along with hundreds of others.
Hell a lot of the time we flew them without an HSI
I do not remember ever seeing anyone that far off centre when we got to the bottom, but that's just my experience.
Maynard
Post by Maynard »
(well maybe the Metro may have F/Ds).
Haha.
You're funny.
Nice first ILS.
We flew all the time by hand for decades, because the airplanes did not have an autopilot.
I have over five thousand hours in DC3's and of all the DC3's I flew only one had an autopilot.
Hand flying in IMC is not black magic.
I think the first big airplane I flew that had an an autopilot was the DC6 that North West Territorial Airways owned.
With a long runway my feeling is don't mess with success. If I was on a nice stable descending flight path to the DH then that flight path is going to get you to the thousand foot marker without having to do anything. Changing the configuration by going to full flap after DH makes it a lot harder to keep the flight path stable, just start coming back on the power as soon as you are sure you have the visual references and add a little up trim. You will find you will almost be at the landing attitude and all you need to do to land is a slight flare and close the throttles.
This method works especially well for those foggy night landings.
