New Paint Job...??
Airbusfan
New Paint Job...??
Post by Airbusfan »
Seems Air Canada isn't painting any more...? What's up with that...?
delta1
Re: New Paint Job...??
Post by delta1 »
Airbusfan wrote:Seems Air Canada isn't painting any more...? What's up with that...?
Ummmm what makes you think that??
Alcoholism
Post by Alcoholism »
The new livery is now old. Stay tuned for a major announcement and a new-new livery.
mato
Post by mato »
Maybe just busy keeping the summer rush going with max aircraft utilization.
Probably be about 5 more years until the last aircraft with the sea foam paint is either repainted or retired.
Mach1
Post by Mach1 »
I thought they only repainted when in times of financial crisis?
Blue42
Post by Blue42 »
Summer! Should start up again in the next month or two.....heard an A330 is next to go...
PostmasterGeneral
Post by PostmasterGeneral »
What a lot of people don't realize is, a plane needs to be completely stripped every few years anyways in order to check the fuselage skin for cracks. It's always repainted back into the same scheme, so really, nobody is the wiser.
Reprinting a fleet on that schedule doesn't add any additional cost to an airline.
mbav8r
Post by mbav8r »
PostmasterGeneral wrote:What a lot of people don't realize is, a plane needs to be completely stripped every few years anyways in order to check the fuselage skin for cracks. It's always repainted back into the same scheme, so really, nobody is the wiser.
Not sure where you're getting your information but that is not true, aircraft are X-rayed to check for stress cracks, can't even imagine relying on the naked eye for something as important as that. I've flown the same aircraft with the same paint and flaws in that paint for several years. I've also seen the process for the X-ray.
However, it is true that every so often aircraft will need to be repainted and I doubt many of ACs aircraft will go in ahead of that schedule but I could be wrong.
JBI
Post by JBI »
According to @contrailaviationphotography an A330 will be going in for painting next week. Not sure where they get their info from.
Mircea7378
Post by Mircea7378 »
Was told they do painting when an aircraft is scheduled for maintenance work but I could be wrong.
FADEC
Post by FADEC »
Some aircraft require stripping on a schedule; some don't depends on the type certificate and approved maintenance schedule.
aV1aTOr
Post by aV1aTOr »
Alcoholism wrote:The new livery is now old. Stay tuned for a major announcement and a new-new livery.
The current AC toothpaste livery is over 11 years old.
Return to “Air Canada”
