Using a US Trust to own an N-registered plane in Canada
cykf_local
I'm very close to buying/importing a US aircraft into Canada.
I'm a Canadian, and it will be hangered/flown mostly out of Canada. The broker brought up the option of keeping the plane N-registered and instead of buying through a Canadian corp, using a US trust. A little research shows this is both possible and relatively common.
This has a significant advantage for the particular specialty aircraft I am considering. If I bring to Canada and register with C- registration, the N number is lost. Down the road, the market for selling this specific aircraft it in Canada is virtually nil, so with near certainty, the US owner would have to repaint the plane to put on a new N-number. Not insurmountable, but keeping the A/C N-registered makes a lot of sense if I'm confident the plane will one day be back in the US.
I know some of the pros and cons - I need a US license, a 2 year BFR with a US instructor, and all US regs must be followed.
What else? Anyone have any experience with doing this? What should I know?
Thanks in advance,
-k
Thanks in advance,
-k
Re: Using a US Trust to own an N-registered plane in Canada
Lots of people do it, and the lawyers will love taking the management fees off you to file all the corporation and trust paperwork each year, but it’s still illegal under CAR 202.42(1). If TC caches you they can slap you with a $25k fine.
If it was remotely legal, everyone would do it - why do you think we don’t?
You haven’t done your research very well, either: you don’t need a US airman certificate to pilot an N-reg aircraft in Canada; a Canadian licence is just fine.
cykf_local
Appreciate the response, and yes, I understand. Seems as though action is highly uncommon:
http://www.yyzlaw.com/2012/06/25/non-ci ... -trusts-2/
But of course this is from a law firm.
Any _other_ pros or cons?
Thanks in advance,
-k
Thanks in advance,
-k
photofly wrote:Lots of people do it, and the lawyers will love taking the management fees off you to file all the corporation and trust paperwork each year, but it’s still illegal under CAR 202.42(1). If TC caches you they can slap you with a $25k fine. And it’s easy to prove - they just have to look at the aircraft journey log.
cykf_local
cykf_local
skybluetrek
The info.(including their fees) on the website of this UK company doing trust agreements may be of interest to you.
http://www.southernaircraft.co.uk/Home
202.42 (1) Subject to section 203.03, no person shall operate in Canada an aircraft that is registered in a foreign state that has been present in Canada for a total of 90 days or more in the immediately preceding twelve-month period unless
(a) the foreign state is a contracting state;
(b) the operator of the aircraft is
(i) the foreign state,
(ii) an individual who is not a Canadian citizen or a permanent resident but is a citizen or subject of the foreign state, or
(iii) an entity that is incorporated or otherwise formed under the laws of the foreign state; and
(c) if the operator of the aircraft is an entity described in subparagraph (b)(iii), the aircraft is operated in Canada
(i) in accordance with an air operator certificate, or
(ii) in any operation other than an operation that would require a private operator certificate if the aircraft were registered in Canada.
Why can't you use 202.42 (1) B iii and 202.42 (1) C ii ? Why would that be illegal?
A N-regged C172 owned by a US corporation is used in an operation without an AOC. Doesn't that tick all the boxes?
Saw Larry Tanenbaum’s G5 departing YYZ the other day. Had all the MLSE team logos on the tail, with an N-registration ending with LT. Classy.
If he’s doing it pretty sure it’s legit if set-up correctly.
It is legit if done correctly. Operating part 91 is easy. Will take a little extra work.
CRA will come looking for their taxes though. So be prepared to pay HST.
x15
Skin, Tin, Ticket...In that order.
Go ahead - explain how it’s legal.
The only way under the CARs is if you operate under a Canadian POC, or in an operation that would require a POC. That means a medium turbine or bigger, and approved operating procedures. Obviously that’s how the G5 does it. But a small piston? No.
No. A 172 used for those purposes doesn’t qualify to fly under a POC. (It’s not needed for that aircraft and TC won’t issue one.)digits_ wrote: Why can't you use 202.42 (1) B iii and 202.42 (1) C ii ? Why would that be illegal?
Exactly, so that satisfies:photofly wrote:No. A 172 used for those purposes doesn’t qualify to fly under a POC. (It’s not needed for that aircraft and TC won’t issue one.)digits_ wrote: Why can't you use 202.42 (1) B iii and 202.42 (1) C ii ? Why would that be illegal?
A C172 does not require a POC in Canada, which means it is used in an operation OTHER THAN one that does require it.(ii) in any operation other than an operation that would require a private operator certificate if the aircraft were registered in Canada.
So having a C172 registerd in the US means that:
Which rule would our N-registered C172 violate?(b) the operator of the aircraft is
The whole operation might be illegal, I am not an expert in that at all, but based on your CAR reference I'm not sure why.
You are correct; there’s some stuff online about CARAC discussion to liberalize the operating in Canada by foreign entities (in 2002) and I was misreading the regulation.
So I guess it’s not illegal.
Remains to see if the cost of the paperwork outweighs the cost of repainting the tail number...
- confusedalot
In a previous life, we were operating N registered aircraft in canada for a rather large corporation that happens to make engines.photofly wrote:Lots of people do it, and the lawyers will love taking the management fees off you to file all the corporation and trust paperwork each year, but it’s still illegal under CAR 202.42(1). If TC caches you they can slap you with a $25k fine.
Are you saying that we all had US airmen certificates for absolutely no reason? That was 10 years ago.
Can't comment on the US trust fund thing though, do not know how they set up their affairs.
You can fly any nationality of aircraft in Canada with a Canadian licence.401.04 No person shall act as a flight crew member or exercise the privileges of a flight crew licence in Canada in an aircraft registered in a contracting state other than Canada, unless the person holds, and can produce while so acting or while exercising such privileges,
(a) a flight crew permit or licence issued under this Subpart; or
(b) a flight crew licence, or a document equivalent to a foreign licence validation certificate, that is issued under the laws of the contracting state.
So you’d need the US certificate to fly an N-reg in the US or internationally, but not within Canada. Unless I’m misreading that reg too :/
peterdillon
Thats right an American can't fly a Canadian registered plane in Canada nor can a Canadian fly a US registered plane in the US unless they have a license from that country.
This is probably to avoid foreign persons renting a plane to do bad things. When you get your US license you have to go to an interview in person with the FAA. While they don't say that its to see if your a possible security risk.
cykf_local
Yes, this entire approach is predicated upon getting a US license unless never leaving Canada is an option.
peterdillon wrote:Thats right an American can't fly a Canadian registered plane in Canada nor can a Canadian fly a US registered plane in the US unless they have a license from that country.
peterdillon
You need and AI rated mechanic out of the US to do the annual inspection on a US registered plane as Canadian facilities can do maintenance legally but not annual inspections.
