6.00x6 nose wheel in C150
Bede
Post by Bede »
Has anyone ever seen a 6.00x6 on a stock C150 nose wheel? I know AirGlas offers an STC for a large wheel up front but I heard that Cessna offered this as an option from the factory. Will a 6" wheel fit a stock fork?
culver10
Re: 6.00x6 nose wheel in C150
Post by culver10 »
Hi Bede,
If you consult the Cessna 150 Parts Manual, you will see that Cessna had a Heavy Duty Nose Gear which used a 6.00x6 wheel. You can Google Cessna 150 Parts Manual, and there are multiple PDF's available for free. The fork and lower strut are different. P/M shows all the different P/N's. So no, the larger nose wheel will not fit standard fork.
Phil
516161
Bede
Post by Bede »
culver10 wrote:Hi Bede,
Phil
516161
Thanks! Exactly the answer that I was looking for!
The factory "heavy duty" nosewheel for a 150 is a 6.00-6-15 size, which is a smaller diameter tire, with the width of the 6.00-6. The fork in the parts catalog is that standard for the C337. The installation is distinct, in that the torque link points forward. That said, if you really need a wider nosewheel on a 150, you're probably on the bitter edge of being in ground too soft for the plane.
torquey401
Post by torquey401 »
Be mindful that the factory hd nose gear was limited up to about the 1967 model year. Plus there is also a Canadian adapplicable to it. There might be stc's out there.
Return to “Maintenance”
