Increased MLB
Moderators: North Shore, ahramin, sky's the limit, Sulako
vrefplus5
Increased MLB
Post by vrefplus5 »
What would the block time be YOW-MLB?
http://www.cbc.ca/news/canada/windsor/p ... -1.4305304
fish4life
Re: Increased MLB
Post by fish4life »
This seems like desperately grasping at straws for work. YOW - MLB is 1059nm in a straight line and I doubt they will get anything near a direct routing. BBD's website even lists max range as 1100nm which is for the versions with a MTOW of 67 400 and I'm pretty sure the Porter ones are much lower than that.
chipmunk
Re: Increased MLB
Post by chipmunk »
fish4life wrote:This seems like desperately grasping at straws for work. YOW - MLB is 1059nm in a straight line and I doubt they will get anything near a direct routing. BBD's website even lists max range as 1100nm which is for the versions with a MTOW of 67 400 and I'm pretty sure the Porter ones are much lower than that.
That's roughly 130 NM longer than the YTZ-MLB flight, which is normally planned at about 3h10 min.
Structural MTOW is 63,930, and since YOW has much longer runways than YTZ, that number should always work.
ctmorawetz
Re: Increased MLB
Post by ctmorawetz »
I flew MLB-YOW last year when we had to divert there due to weather in YTZ. It can be done no problem. We even were already in the descent into YTZ and had to climb back up.
Keep your stick on the ice - Red Green
fish4life
Re: Increased MLB
Post by fish4life »
It can be done but how many seats have to be blocked off? I doubt you can take the full 78.
goingnowherefast
Re: Increased MLB
Post by goingnowherefast »
Aren't Porter's planes already configured to 74?
ctmorawetz
Re: Increased MLB
Yes, we are configured to 74 passengers. I believe we were capped at 60 for the YTZ-MLB runs last year.
Return to “Porter Airlines”
