Do you check your killer items just prior to takeoff?
Re: Do you check your killer items just prior to takeoff?
Xander wrote: Sun May 05, 2019 6:17 am
PT6-114A wrote: Sat May 04, 2019 6:59 pm Xander, why APU off?
Because in most cases (99% of the time, unless one of the engine bleeds is MEL’d) it’s not necessary for takeoff.
Furthermore, there is an altitude limitation for running the APU (33000’ on my aircraft) and if you run the APu above that, you will get an « APU EXEEDANCE » Eicas message.
Also it burns fuel for no reason.
So translation: nothing will really happen if you forget about it on takeoff? :smt040
Xander
Post by Xander »
digits_ wrote: Sun May 05, 2019 8:50 am
If possibly exceeding the aircraft’s limitations is nothing for you, then yeah.
The trouble with my life is that I do not think I am cut out to sit behind a desk.
goingnowherefast
Post by goingnowherefast »
Taking off with the apu running won't kill you in your aircraft type. It's not a killer item. I'll use the Navajo as an example, takeoff with the outboard tanks selected could put you in the trees at the end of the runway. It will kill you.
goingnowherefast wrote: Sun May 05, 2019 3:28 pm Taking off with the apu running won't kill you in your aircraft type. It's not a killer item. I'll use the Navajo as an example, takeoff with the outboard tanks selected could put you in the trees at the end of the runway. It will kill you.
Thank you.
To answer the original question: I don't check anything extra in airplanes where the checklist has to be used. Follow the checklist. If you follow the checklist and then do your own killer item checklist, you won't be paying attention to the real checklist too much, since you'll subconciously think "I do my own checklist anyway". If you miss items on a checklist that often, then something is seriously wrong with either your SOPs, CRM procedures or checklist.
It's like people who do their own extra "gear down 3 green" check on short final, 10 seconds after the company checklist called for that anyway :rolleyes:
Xander
Post by Xander »
Yeah?
It’s definitely an undesired aircraft state.
Which have been contributing factors in many aircraft accidents throughout history.
Who knows? You might overload the APU gen because you forgot it. It might catch fire. You may be unable to extinguish it. It might kill you on a very bad day.
Furthermore, I doubt OP meant something that might literally kill you. My interpretation of the question was more along the lines of:
« What items do you double check before takeoff ».
That’s the way I read it anyway.
C.W.E.
Post by C.W.E. »
I always do a short final check for landing to confirm I have the correct gear position.
It is.
" Where am I landing and where is my gear. "
It has saved me landing with the wrong gear position twice.
Schooner69A
Post by Schooner69A »
Place me in the "Gear in the green" camp on short final.
Years ago, doing multiple closed patterns in a T-33, a friend of mine landed with the wheels securely tucked in the wells. When later asked what had happened, my friend didn't sugar coat it: "I guess I forgot to put them down..." Saved a lot of investigation time.
On the T-bird, gear was dropped opposite the button and upon receiving the "3 green" indication, the landing gear handle was given a "shake" test to ensure it was where it was supposed to be. Something interrupted this sequence with predictable results. (In your mind, when you're convinced you've done something, it takes a two times four upside the head to change that conviction...) (;>0)
A final check on short final would have caught the error.
Joe Blow Schmo
Post by Joe Blow Schmo »
Just before takeoff I recheck the Takeoff performance. That’s in addition to the 5+ times it gets checked or cross checked in the SOPs. Just one final check to make sure we’re not 100 tonnes out. It wouldn’t be the first time that happened if we were. Also recheck gear and flaps on short final despite the airplane telling me they’re down.
goingnowherefast
Xander wrote: Sun May 05, 2019 6:29 pm
Yeah?
Right in the first post, the OP uses the example of a home built taking off with the fuel selector in the off position. That's a pretty big killer item. You've got 33000' to notice the APU is running before it even warns you that it's on, and can still turn it off. If it's something you personally check, then it's probably a good idea, but don't pretend it's a killer item.
I usually look for weak spots in the aircraft design, SOPs and checklists. If there's something I don't like, I'll add a personal "double check". Could be the APU if the SOPs and company checklists are inadequate to prevent what you describe. Not necessarily killer items, but an error regardless. My current aircraft type and SOPs are quite good and catching anything close to a killer item. From the flows, to checklist and various aircraft warning systems, they're covered multiple times.
5x5
Post by 5x5 »
Much of this sounds a bit like having checklists to check the checklists. :rolleyes: If there really are items you need to have an internal checklist to cover (not things you do just for your own peace of mind) then shouldn't you be reporting it to the company you work for or the people who own the aircraft you're flying and get the checklists revised? If it's something you actually need to do, then shouldn't it also be needed by anyone else in that aircraft?
Mark Twain
AirFrame
Post by AirFrame »
Since i've just done a runup before takeoff, I expect the critical things are already checked... It runs, it runs at elevated power setting, mixture can shut the engine off, flaps set for t/o, etc.
Last check before rolling out is BBBD, Belts (on and tight) Baggage (secured) Brakes (work) Doors (closed and locked), a final check that they're all where they should be. After that, I recite the two takeoff emergency mnemonics to try and have them ready in my mind if needed:
EFOTO:TSB - Engine Failure On Take Off - Throttle back, Stick back, Brake to a stop
EFATO:SLAM - Engine Failure After Take Off - Straight ahead, Level wings, Airspeed (to best glide), Mayday
Xander
Post by Xander »
goingnowherefast wrote: Mon May 06, 2019 6:54 am
Yeah?
Still an undesired aircraft state. A mild one i'll give you that, much less critical than a fuel selector.
Forgetting the APU would have a nasty little effect of not decluttering the EICAS, thus possibly reducing situational awareness. I would argue that on a bad day it could be fatal. That's serious enough for my list.
The question was: Do you check your killer items just prior to takeoff. It's subjective by nature.
If you don't feel like checking that particular item, then so be it, we'll just have to agree to disagree. For me it's justified and will continue to be.
Fly safe.
Illya Kuryakin
Post by Illya Kuryakin »
I just call "Release the hounds" and hope she flies.
Illya
