Sunwing hiring update
Discuss topics related to Sunwing.
JoeyBarton
Post by JoeyBarton »
Good evening folks,
Any update on the hiring forecast? Heard they are conducting a oct GS, is there anything planned for later on this year?
jd832
Re: Sunwing hiring update
Post by jd832 »
JoeyBarton wrote:Good evening folks,
Sunwing hired 42 during April and May. Two classes of 10 out of 49 to be hired this fall are going through training right now. So 29 more applicants to be hired and to start training soon. We received a recent memo stating we will have non-stop hiring in the next 12 to 24 months.
Good Luck!!
rudder
Post by rudder »
Any carrier that has early start/late start long duty days will be affected by the proposed FTDT rules likely to come in to effect early in 2019.
SW and all other affected carriers will have 2018 to get staffed up. I heard that SW estimated a 17% impact on crew efficiency.
GoHomeLeg
Post by GoHomeLeg »
Sounds like massive hiring will start soon for next winter.
frog
Post by frog »
They prefer internal reference.
So if you have a buddy at Sunwing, use him/her ! :)
whipline
Post by whipline »
Looks like we’re joining the race to find pilots. Should be around 100.
Good news you might get a WJ number and as a new hire you’ll get called for overtime first. A world first!
goleafsgo
Post by goleafsgo »
Is there an updated pay scale? The latest I can find only goes up to 2019.
DHC-1 Jockey
Post by DHC-1 Jockey »
Screen Shot 2022-04-07 at 7.44.41 PM.png (186.91 KiB) Viewed 16210 times
Minimum annual guarantee is 900 hours (down from 1000 hours in CBA 3).
You'll note there's some pay freezes from Year 1-2 on the Captain side and at the top end of the scale for both Captains and F/O's. There are some funky LOU's that deal with this issue that are too long to explain here.
goleafsgo
Post by goleafsgo »
FOD_Vacuum
Post by FOD_Vacuum »
Sunwing hiring portal is open for FOs and DEC!
https://jobs.jobvite.com/sunwing/job/ocWkjfwv
Good luck to all those who apply-I believe Interviews start next month.
whipline wrote: ↑Thu Apr 07, 2022 8:22 am Looks like we’re joining the race to find pilots. Should be around 100.
You mean a Swoop number
cloak
Post by cloak »
co-joe wrote: ↑Thu Apr 14, 2022 4:23 pm
What’s the difference ace?!
goingmissed
Post by goingmissed »
cloak wrote: ↑Wed Apr 20, 2022 11:23 am
WestJet and Encore use a five digit number. 1xxxx, 2xxxx, 3xxxx. They are used for all WestJet and Encore employees, including pilots, flight attendants, CSAs, and other staff.
Swoop uses a six digit number starting with 8. 8xxxxx. I am unsure if they are shared with other Swoop employees.
cloak
Post by cloak »
So? What’s your point?
I like the entertainment!
sstaurus
Post by sstaurus »
I believe he’s jokingly alluding to how WJ would love to slot the sunwing guys under the swoop LOU :wink:
sstaurus wrote: ↑Thu Apr 21, 2022 5:12 am
Not only that, Westjet manline isn't hiring. But Swoop is desperate to hire non Encore pilots as quickly as possible before Encore pilots wake up and do something about it. Sunwing traditionally goes from 30 tails, down to 7 in the summer, yet they force recalled all of their pilots who were working elsewhere to do what? Are deployments happening? Maybe Westjet is recalling Sunwing pilots so they can give them pink ties, and pay them pink wages?
frog
Post by frog »
Yes deployments are happening and Westjet is not recalling swg pilots.
As for the rest...speculations...
GoHomeLeg
Post by GoHomeLeg »
Half our planes are going to Europe in summer. We have more than 7 planes in the summer.
rooster
Post by rooster »
Any updates on how the pilots will fit in into the list when the merger happens? I see SW is hiring. Is it worth it for a pilot to go to SW now without much knowledge of what the future holds for the pilot group? I guess for a new hire, it's not as critical as a senior SW pilot. I'm a bit out of touch with the merger.
mmm..bacon
Post by mmm..bacon »
Bumpity bump bump...
And...is that payscale still valid? If I'm reading it right: 900h (minimum annual) x $61.61 = $55449/yr. perdiems? base allowance? negotiable start level? Anything to make that salary higher than the Navajo pay I made back in 2002?
doiwannabeapilot
Post by doiwannabeapilot »
yes. uber eats
frog
Post by frog »
Per diem : yes
Work on GDO : X2
OT
Deployment : not sure it is going to happen again.
DHC-1 Jockey
mmm..bacon wrote: ↑Thu May 19, 2022 10:26 am Bumpity bump bump...
Negotiable start rate?: No. Payscales are as per the CBA.
Base allowance?: No.
Perdiems: I got about $700 per month doing multi-day trips. If you do single-day turns and receive crew meals, I don't believe you get perdiems at all.
fruz
Post by fruz »
Should you interview with Sunwing, be sure you ask the interviewers where they see themselves in five years. They are mostly likely going to ask you this but I think the question is just as notable when reversed in this case. Hopefully they are honest with you.
Fredsbutt
Post by Fredsbutt »
fruz wrote: ↑Fri May 20, 2022 12:07 pm Should you interview with Sunwing, be sure you ask the interviewers where they see themselves in five years. They are mostly likely going to ask you this but I think the question is just as notable when reversed in this case. Hopefully they are honest with you.
Dumb question….IMO
The honest answer everyone should give no matter what airline they’re interviewing at should be “who knows”.
5 years ago nobody would have thought Canadian aviation would have been effectively shutdown…..
Return to “Sunwing”
