An-124 landing on nose-gear
ccd
Post by ccd » Sun Nov 05, 2017 2:50 am
A shocking photo of an An-124 landing on its nose gear. I do not understan how it could not collapse under that huge weight. Are they made in a special way on those airplanes?
whistlerboy02
Re: An-124 landing on nose-gear
Post by whistlerboy02 » Sun Nov 05, 2017 4:13 pm
The wings are still flying, and bearing most of the weight. its not ideal though
Gilles Hudicourt
Post by Gilles Hudicourt » Sun Nov 05, 2017 6:05 pm
badmash
Post by badmash » Mon Nov 13, 2017 12:10 pm
This isnot too shocking, i've seen this before on An-124s, IL-76s and An-32s. Infact SOPs for An-32s take into account landing on the nose wheel and are made in accordance. If you notice, all the three aircraft I mentioned, come in on a very shallow angle during approach, holding the nose low till the final flare where they usually put down all three . An-32s for one can be totally fine coming down on all three. It has to do some design factor.
mmm..bacon
Post by mmm..bacon » Mon Nov 13, 2017 12:18 pm
It's built in Russia...
Happiness is V1 at YTH!
confusedalot
Post by confusedalot » Thu Nov 16, 2017 8:12 pm
he he he....a picture is worth a thousand words.
NorOntair
Post by NorOntair » Wed Nov 29, 2017 9:34 am
I asked xchox about this very thing several months ago given he/she is the resident expert on Russian Aviation. Pretty standard apparently. Also, they are apparently designed to take repeated nose first landings. Also standard is throwing the reversers prior to touch down. Cool stuff.
