In person assessments
stormymonday
Re: In person assessments
It's 5 different tests mainly all aptitude testing. You will write the Wsim which you should be prepared for. But download apps on your phone for aptitude testing prepare for those. Also sit as close to the front as you can as you'll have the listening exam. If your answer wrong in the listening exam you lose a point which is the only exam like this. Good luck.
stormymonday
what is the Wsim? sorry- totally newbie here!!!Scott25 wrote: ↑Fri Nov 10, 2017 3:38 pm It's 5 different tests mainly all aptitude testing. You will write the Wsim which you should be prepared for. But download apps on your phone for aptitude testing prepare for those. Also sit as close to the front as you can as you'll have the listening exam. If your answer wrong in the listening exam you lose a point which is the only exam like this. Good luck.
The Wsim is the only thing you can study for and relates to air traffic. If you get invited to the assessment session they give you practice questions online with the Wsim. So you'll learn what it is then
