Class 1 medical with second pilot restriction
Re: Class 1 medical with second pilot restriction
Dialdriver do you have a unlimited class 3 and restricted class 1 sticker . I haven't gotten my book yet so I don't know how it looks.
My main point is do you have an unlimired class3 and restricted class 1 at same time
Yes. I don't require an accompanying pilot, but I have some minor medical requirements to maintain my unrestricted Cat 3. So I can fly solo or with passengers on my Cat 3, but not my Cat 1, due to the more stringent medical standards for it.
When you get you're medical done do they give you a class 3 and restricted class 1 at he same rime
I don't know, but likely only if your medical situation permits it. You'll just have to start the process and see what happens.
Hi everyone,
I'm new here and hoping to revive this thread.
I'm training for my PPL currently on a Class 3 unrestricted medical. I talked on the phone with the Regional Aeromedical Officer and she said she could likely issue a Class 1 "with or as copilot" once I start training for CPL. I was hoping to get an experienced pilot's perspective on how holding a Class 1 "with or as copilot" impacts hireability, especially for a first flying job.
Significantly, unless you somehow think you'll be going multi-crew from day one.
What reason was given for going from an unrestricted Category 3 medical, to a restricted Category 1?
I'll PM you, if that's ok
Sorry, not true.dialdriver wrote: ↑Tue Sep 25, 2018 8:12 pm With an unrestricted category 3, you can certainly train for a CPL. However, as tired said, there may be a limit on the flexibility Transport Canada allows when it comes to issuing you a CPL. But, human rights would require them to consider it.
https://canlii.ca/t/gjnkm
I suggest that you really understand this with great clarity - it sounds odd. My experience has been that a restriction is not "CAT" specific. If the proposed restriction is not likely to be temporary, this is something you should be very clear about before you invest a lot in learning to fly.currently on a Class 3 unrestricted medical. I talked on the phone with the Regional Aeromedical Officer and she said she could likely issue a Class 1 "with or as copilot" once I start training for CPL
Flying as a second crew member with an "as or with" restriction imposes extra burden on the operator and other pilot, not a "doesn't matter" situation for the operator.
My restriction is category specific. My cat 1 is restricted and my cat 3 is not. This is clearly stated on my certificate.PilotDAR wrote: ↑Sat Apr 30, 2022 5:29 pmI suggest that you really understand this with great clarity - it sounds odd. My experience has been that a restriction is not "CAT" specific. If the proposed restriction is not likely to be temporary, this is something you should be very clear about before you invest a lot in learning to fly.currently on a Class 3 unrestricted medical. I talked on the phone with the Regional Aeromedical Officer and she said she could likely issue a Class 1 "with or as copilot" once I start training for CPL
Thus restriction does not cause any burden on my employer.
It's very difficult to see how that helps you. Neither a CPL nor an ATPL are validated by a category 3 medical certificate under any circumstances or for any purpose. Does your ADB say you hold *both* a CPL/ATPL and a PPL?dialdriver wrote: ↑Sat Apr 30, 2022 5:54 pm My restriction is category specific. My cat 1 is restricted and my cat 3 is not. This is clearly stated on my certificate.
I hold a cat 1 medical.photofly wrote: ↑Sat Apr 30, 2022 5:57 pmIt's very difficult to see how that helps you. A CPL isn't validated by a category 3 medical certificate under any circumstances or for any purpose. Does your ADB say you hold *both* a CPL and a PPL?dialdriver wrote: ↑Sat Apr 30, 2022 5:54 pm My restriction is category specific. My cat 1 is restricted and my cat 3 is not. This is clearly stated on my certificate.
RIght. But your category 1 is restricted to "as or with copilot":dialdriver wrote: ↑Sat Apr 30, 2022 5:59 pmI hold a cat 1 medical.photofly wrote: ↑Sat Apr 30, 2022 5:57 pmIt's very difficult to see how that helps you. A CPL isn't validated by a category 3 medical certificate under any circumstances or for any purpose. Does your ADB say you hold *both* a CPL and a PPL?dialdriver wrote: ↑Sat Apr 30, 2022 5:54 pm My restriction is category specific. My cat 1 is restricted and my cat 3 is not. This is clearly stated on my certificate.
I was referring to your unrestricted category 3 medical. Unless you hold a PPL, a category 3 medical does nothing for you. A category 3 medical certificate doesn't ever validate a CPL, so the lack of restriction of your category 3 is academic. You can't use it.My restriction is category specific. My cat 1 is restricted
I appreciate your replies so far, thank you!PilotDAR wrote: ↑Sat Apr 30, 2022 5:29 pmI suggest that you really understand this with great clarity - it sounds odd. My experience has been that a restriction is not "CAT" specific. If the proposed restriction is not likely to be temporary, this is something you should be very clear about before you invest a lot in learning to fly.currently on a Class 3 unrestricted medical. I talked on the phone with the Regional Aeromedical Officer and she said she could likely issue a Class 1 "with or as copilot" once I start training for CPL
Do you mind describing how it imposes a burden on the operator if the position is multi-crew and the medical specifies it's valid for multi-crew Cat 1?
I have no experience or background knowledge and am just trying to understand.
My license does not say "with or as copilot". It says, "Subject to a letter...". That letter states the "restrictions do not apply while using only the Private Pilot Privileges (PPL) of your professional (ATPL) license".
That makes sense: your restriction, whatever the wording is, and the relaxation thereto, are both on your category 1 medical.dialdriver wrote: ↑Sat Apr 30, 2022 6:14 pm My license does not say "with or as copilot". It says, "Subject to a letter...". That letter states the "restrictions do not apply while using only the Private Pilot Privileges (PPL) of your professional (ATPL) license".
However you said earlier:
But you don't actually have a category 3 medical - that would mean you had two different medical certificates. You have just one medical certificate - a category 1 - with restriction that differ based on the use of your ATPL. It may sound like the same thing - but it's not.dialdriver wrote: ↑Sat Apr 30, 2022 5:54 pm My restriction is category specific. My cat 1 is restricted and my cat 3 is not. This is clearly stated on my certificate.
Sorry, it's cleary stated in my letter.
The previous poster suggested restrictions aren't category specific.
I think we're arguing at cross-purposes. I'm trying to clear up a matter of terminology. Your restriction isn't category specific - it's use-specific. It applies to one use of your ATPL but not the other. Since you only have one category of medical, there's nothing "category"-specific about your restriction.dialdriver wrote: ↑Sat Apr 30, 2022 6:22 pm Sorry, it's cleary stated in my letter.
As far as I know, the only people who have two separate categories of medical certificate (and therefore could have a restriction that applied to one category and not the other) are ATCOs who also hold a PPL - they might have both a category 2 and a category 3 medical certificate.
I believe the restriction is clearly category specific, as it is a cat 1 medical. But, the letter clarifies the medical constraints do not apply to the PPL flying privileges of a cat 1 medical.
"The letter goes on to say, " You will therefore not be receiving a separate Category 3 Medical Certificate and PPL". So, if there was a requirement for different restrictions to my PPL flying, I would get separate documents. So, I could have a cat 1 and cat 3 with different restrictions.
