Wings Over Kississing
Roadrunnersmother
Sharklasers
Re: Wings Over Kississing
That's not 100 % accurate according to some guys that work there. EIC purchased one hangar and three airplanes. From the guys that still work there, it will be normal operations going forward. This was apparently done in anticipation of the changes coming with the Government RFP.
- Rank Moderator
Surely a business wouldn't spend money on anticipation? What happens if the anticipated doesn't happen? Or might EIC have a little bird somewhere that's tweeting out of turn?PT6A wrote: ↑Sat Nov 17, 2018 10:25 amThat's not 100 % accurate according to some guys that work there. EIC purchased one hangar and three airplanes. From the guys that still work there, it will be normal operations going forward. This was apparently done in anticipation of the changes coming with the Government RFP.
Happiness is V1 at Thompson!
At which airport did they buy a hangar?PT6A wrote: ↑Sat Nov 17, 2018 10:25 amThat's not 100 % accurate according to some guys that work there. EIC purchased one hangar and three airplanes. From the guys that still work there, it will be normal operations going forward. This was apparently done in anticipation of the changes coming with the Government RFP.
