SD
Workopolis. No views.
Hey, Guys. I'm curious as to whether or not I've done something wrong with my Jazz application on workoplis.com. I applied there on the 20th of October, and Jazz hasn't looked at it even once. Seems to me, I've screwed something up, but when I review it, it all looks normal. Have they done all their selecting? Any info would be helpful, thanks.
SD
SD
Gurundu the Rat
stevewilson
Shankdown;
It is possible you just created a profile without actually applying for the job. Sounds funny, but you can just create a profile without applying. Go into your "job list" and see if the Jazz job is in there. If not, go down to the bottom and hit "apply" (I think that is under the job listing itself, not under your profile, but I may be wrong--it is somewhere around there)
Quick test: Did you have to answer a little 20 point questionaire? If not, you haven't applied yet.
Hope that was it.
Steve
Hope that was it.
Steve
IflyaSewerpipe
CHICKEN WINGS
Positive,
I have some friends on th 31st of October course and they were 23 or so.
I have talked to the guys giving the sim eval. and they said 40/month.
90 RJ seats openned in YYZ and 40 RJ seats in YUL.....plus the dashs positions!
They seemed very pleased about so much initiales to do!
It seems that they dropped their minimums also. Freinds with 2000TT + got a couple views on workopolis. They started at 4500TT + last July. Looks like there are not many pilots left around.
Good luck to all of you.
wallypilot
pauliewalnuts
- flyinggirl
Gurundu the Rat
You will be given a seniority number which they pick out of a hat for every class. Whoever gets picked first gets first dibs on whatever equipment and base is available. Everyone gets YYZ base for the first few months but you can bid on a vacancy at another base from the last equipment bid. Upon the effective date of the vacancy you bid on you will be able to go to your new base. Effective dates are usually around 3-9 months after the equipment bid. Hope that helps.How and when do they decide who gets what equipment in the class?
jazz spots
Anyone know the breakdown of RJ/Dash 8 for dec groundschools, and what bases are associated. Thanx
- DiscoDashSeven
- DiscoDashSeven
Pourdu_fun
