Avro Arrow blueprints on display after sitting in Sask. man's home for decades
golden hawk
jakeandelwood
Re: Avro Arrow blueprints on display after sitting in Sask. man's home for decades
Ironic how they are on display at the Deifenbaker Canada center.
- Beefitarian
Get some copies to those guys in Sprinbank building the replica. STAT!!
Ouch.jakeandelwood wrote: ↑Wed Jan 08, 2020 9:51 am Ironic how they are on display at the Deifenbaker Canada center.
Check the guy's barn, maybe he has the "missing" Arrow, too...
Never mind that... Get them into a scanner STAT!! Then post them online somewhere.Beefitarian wrote: ↑Wed Jan 08, 2020 11:11 am Get some copies to those guys in Sprinbank building the replica. STAT!!
Those are small blue prints , I would be more impressed if he had the big blue prints and even more impressed if he had the As-Built Drawings .
As built? As in reverse engineered after the construction of the prototype?
The Arrow used the Cook-Craigie plan which meant the first planes were essentially production models made with production tooling and thus there was no prototype Arrow save a wooden mock-up for validation. The DC-8 was also built in this manner.
So there would likely only be small drawings with detailed changes or small updates to existing drawings for problems and fixes post production.
So, the big question, should someone start a go fund me to build one?iflyforpie wrote: ↑Fri Jan 10, 2020 12:31 pm As built? As in reverse engineered after the construction of the prototype?
Wouldn’t it be awesome to have one for flight testing!
"Stand-by, I'm inverted"
It would be great, but probably easier to design a better aircraft from scratch given the 65 years of advances in metallurgy and composites, aerodynamics, aircraft systems, and manufacturing processes.
And considering a modern fighter is nearly breaking the worlds best funded military, I don’t think a go fund me will cut it.
Some aircraft blue prints were actual size . It was how things were built back then . Once built the actual dimensions " as built " were noted and useful notes added to aid the next crew building.
It was partly in jest, but my thought was building it as designed to see how advanced Canada was and actually comparing it to the technology of today, real comparison, not assumed. Of course this would require extremely deep pockets, which I don’t have but I’d kick in 20 bucks,iflyforpie wrote: ↑Fri Jan 10, 2020 1:45 pm It would be great, but probably easier to design a better aircraft from scratch given the 65 years of advances in metallurgy and composites, aerodynamics, aircraft systems, and manufacturing processes.
Not too many were actual size. Impractical for something like a spar or a wing plank and no need. I’ve scratch built hundreds of aircraft parts without full sized drawings.
Generally the full size is what the mockup is for. That’s where they check the fit of everything but using materials that are cheap to buy and easy to form like wood. I’ll do the same type of thing making a pattern from cardboard or plywood for a large aircraft part to validate it. Of course now and for the last 40 years it’s been done with CAD.
So when a part for the Arrow was made, it was done from small plans from which tool makers made the moulds, dies, and jigs and from there the first full sized parts were made. If it was done properly, there was very little rework afterwards. There are few things more satisfying than making a part from scratch from plans and having it fit perfectly the first time.
There was another gentleman in Saskatoon who worked as a design engineer on the Arrow.
I believe his name was Paul,Mellin. He designed either the left or the right landing gear. He had about a four foot blueprint of it framed and on his wall.
The pesky Official Secrets Act does not have an expiry date, but I think there might be some more around.
Accident speculation:
One of my teachers in University was en Engineer working on the Arrow. He brought blueprints one day in class. Coolest thing in University!!
Going for the deck at corner
Oh the humanity, displaying anything Avro related at the Dief's haunt...
- Beefitarian
The guys in Springbank have a partially completed replica they have been building based on pictures. I figure they deserve to check some blueprints to see how close they are.
They have finally caught the attention of the EAA, I noticed an article about them in one of the e-mails last year.
Human Factor
Deep pockets, or a knack at computer animation:mbav8r wrote: ↑Fri Jan 10, 2020 3:38 pmIt was partly in jest, but my thought was building it as designed to see how advanced Canada was and actually comparing it to the technology of today, real comparison, not assumed. Of course this would require extremely deep pockets, which I don’t have but I’d kick in 20 bucks,iflyforpie wrote: ↑Fri Jan 10, 2020 1:45 pm It would be great, but probably easier to design a better aircraft from scratch given the 65 years of advances in metallurgy and composites, aerodynamics, aircraft systems, and manufacturing processes.
And considering a modern fighter is nearly breaking the worlds best funded military, I don’t think a go fund me will cut it.![]()
https://www.youtube.com/playlist?list=P ... I_PgDDPWdo
Will fix airplanes for food.
- Beefitarian
Fun video.
We can't even build Beavers, Norsemen, Harvards or Lancasters anymore.
- schnitzel2k3
Use the P&W F119 off the Raptor, add a little thrust vectoring, combine an exclusive electronic warfare suite and voila. Couple hundred billion later.mbav8r wrote: ↑Fri Jan 10, 2020 3:38 pmIt was partly in jest, but my thought was building it as designed to see how advanced Canada was and actually comparing it to the technology of today, real comparison, not assumed. Of course this would require extremely deep pockets, which I don’t have but I’d kick in 20 bucks,iflyforpie wrote: ↑Fri Jan 10, 2020 1:45 pm It would be great, but probably easier to design a better aircraft from scratch given the 65 years of advances in metallurgy and composites, aerodynamics, aircraft systems, and manufacturing processes.
Then build it so it can be pilotless and Gen 6 ready.
I'm on board mbav8r.
