Hello All
Given the fact that Montreal requires all applicants to be fluently bilingual , would you say this mean if you're bilingual
you chances of getting through to the Montreal FIR is significantly better than all the other FIRs ? I'm saying this to mean
the bilingual requirement would reduce the number of applicants who are qualified to apply and as a result they would have
less people to choose from and this would improve your chances.
Also does the montreal FIR use the same FEAST testing system as all the other FIRs?
Do all FIRs now use the FEAST system ?
Thank You
Montreal FIR acceptance rate
ProfessionalATC
pupelarajaka
Re: Montreal FIR acceptance rate
Not sure about the rest of your questions, but I've been told that Montreal does not use the FEAST yet as it needs to be translated to French. Montreal FIR will be the last region to get the new process.
I believe there is a FEAST session coming up this spring in YUL.pupelarajaka wrote: ↑Mon Mar 02, 2020 7:55 am Not sure about the rest of your questions, but I've been told that Montreal does not use the FEAST yet as it needs to be translated to French. Montreal FIR will be the last region to get the new process.
pupelarajaka
Could be. Maybe they'll have it starting this upcoming one.Braun wrote: ↑Mon Mar 02, 2020 8:00 amI believe there is a FEAST session coming up this spring in YUL.pupelarajaka wrote: ↑Mon Mar 02, 2020 7:55 am Not sure about the rest of your questions, but I've been told that Montreal does not use the FEAST yet as it needs to be translated to French. Montreal FIR will be the last region to get the new process.
