Covid GA Annual Inspection Deferral?
MrWings
Post by MrWings »
They extended the medical licensing. Anything like that for GA annual inspections?
Is work still going on as per usual?
Re: Covid GA Annual Inspection Deferral?
AMEs and AMOs are for the most part still working so you should be able to schedule an inspection.
MrWings
Post by MrWings »
OK, great. I tried calling my AME but no answer. Thought maybe he was shut down. I'll try again.
Thanks.
MrWings wrote: Wed Apr 01, 2020 1:43 pm OK, great. I tried calling my AME but no answer. Thought maybe he was shut down. I'll try again.
Thanks.
He might be shut down. But that would be his choice.
Found
Post by Found »
Shop around and find someone open if you need an annual, we are busy (and not just annuals) because a lot of shops shut the doors.
Heliian
Post by Heliian »
Found wrote: Thu Apr 30, 2020 11:24 am Shop around and find someone open if you need an annual, we are busy (and not just annuals) because a lot of shops shut the doors.
The shops that were left before the pandemic are mostly still open in these parts. It's springtime so expect more people coming in.
Return to “Maintenance”
