Flair rehires all laid off employees
tbaylx
Post by tbaylx »
Yycjetdriver
Re: Flair rehires all laid off employees
Post by Yycjetdriver »
This program is only until June 6th. Does anyone in their right mind think airlines will be ramping up or even relatively close to ramping up, not a chance.
This program is likely just the Federal governments way of using one of the largest/hardest hit industry to alleviate pressure on the EI system. Take AC alone for example, with one payment they’re able to alleviate 16,000+ EI applications and look like heroes while doing it. Less than 2 months from now those 16,000+ will most likely all be back applying for EI however, the system has had time to work through all the smaller more diverse applicants and the federal government can come out and say they did all they could while still trying to look like heroes.
Even if the ramp back up begins in the near future, AC wouldn’t need all 16,000 employees right away, it will be a slow methodical rebuild, what other reason is there for keeping them all on a payroll to do nothing.
goldeneagle
Post by goldeneagle »
The article suggests, not only are they taken back, but, at full wage, not just the 75% covered by subsidy. Kind of setting the bar, lets see if any of the other airlines pony up in a similar manner.
tbaylx
Post by tbaylx »
goldeneagle wrote: Thu Apr 09, 2020 7:13 am The article suggests, not only are they taken back, but, at full wage, not just the 75% covered by subsidy. Kind of setting the bar, lets see if any of the other airlines pony up in a similar manner.
That is correct, they were brought back at full wages and all downgraded pilots reinstated. Hope the other airlines can do the same.
While their will be some pilots sitting there are plenty of flight ops projects to keep others busy in non flying roles as needed.
flying4dollars
Post by flying4dollars »
Yycjetdriver wrote: Thu Apr 09, 2020 7:10 am This program is only until June 6th. Does anyone in their right mind think airlines will be ramping up or even relatively close to ramping up, not a chance.
Well you know what? If that happens, that's 2 more months an employee can earn a full wage. Wouldn't you want that for yourself, friends, family etc? This is positive news. Not sure why you don't see that.
vrefplus5
Post by vrefplus5 »
https://flyflair.com/pilot-careers
This is a positive sign.
Wow... that's unexpected... Nice!!
RedAndWhiteBaron
Post by RedAndWhiteBaron »
vrefplus5 wrote: Thu Dec 17, 2020 5:06 pm https://flyflair.com/pilot-careers
That page doesn't load on Firefox. Completely blank.
I sure hope their maintenance department is better funded and pays more attention to detail than their IT department...
flying4dollars
RedAndWhiteBaron wrote: Fri Dec 18, 2020 12:19 pm
Works just fine for me in firefox :roll:
Donald
Post by Donald »
Does the job come with a company van?
Return to “Flair Airlines”
