Jazz Dash 8 400 Freighter
GoinVertical
Re: Jazz Dash 8 400 Freighter
Post by GoinVertical »
Speaking of Dash 8 fire suppression, does anyone know what the regs are on certification when it comes to combis?
The Dash 8-100/200 combis have an awful lot of space for freight and bags, no aisle to walk down to extinguish a fire, and no built-in fire extinguishers. Not sure about Air Inuit's 300 Combi mod.
Meanwhile the Q400 has full fire suppression in a baggage space that's much smaller than the above combis' space.
ATR maintains an aisle I believe?
So what's up with that?
goingnowherefast
Post by goingnowherefast »
Dash 8 100 and probably the earlier 300 models require a space above the bags for a person to crawl above the baggage with a fire extinguisher. The later versions have a divider making a mini isle in the back.
Also depends on what category of cargo compartment, A, B, C or D. I'm no expert on cargo compartment certification requirements, but you're free to look it up in the CARs.
Bajan Pilot
Post by Bajan Pilot »
Only the 300's had the mini aisle.
goingnowherefast
I believe the DH8-106s (basically the Q100s) had the mini-isle as well, but I've been wrong before. Does Jazz have any of those?
goingnowherefast wrote: Tue May 05, 2020 6:30 pm I believe the DH8-106s (basically the Q100s) had the mini-isle as well, but I've been wrong before. Does Jazz have any of those?
I don’t believe so. Even if we did I think the -100s are pretty much removed from service now.
Let’s Go Brandon
Bajan Pilot
Jazz has never had any Q models except for the 400.
dhc#
Post by dhc# »
So has Jazz utilized the freighter config yet?
2R
Post by 2R »
How much pop and chips can they haul ?
Better practice those short field landings :)
Rumor has it, that it has not actually operated.
I asked some Q pilots and yes, best intentions but the idea never “took off”
Let’s Go Brandon
rudder
Post by rudder »
Unlike AC which sourced customers prior to developing their cargo mods, Jazz took the “If you build it, they will come” approach.
Nobody came.
Daniel Cooper
Post by Daniel Cooper »
They'll use it in Pickle Lake in 30 years.
GoinVertical
I really thought when they had announced this that they had already figured out a structure to distribute some of the freight AC was bringing into YYZ/YUL to smaller communities...
Obviously that wasn't the case.
goingnowherefast
Daniel Cooper wrote: Wed Jul 22, 2020 6:05 pm They'll use it in Pickle Lake in 30 years.
They'll be out of cycles, so run them unpressurized with a giant hole cut in the side to fit roof rafters. I'm sure they'll still be sporting Jazz paint because anybody in Pickle Lake is too cheap to paint planes.
goingnowherefast wrote: Thu Apr 30, 2020 5:08 pm This mod leaves the seat tracks, windows, overheaed bins and everything still intact. Basically takes the seats out and strap down cargo to the seat tracks instead. The isle needs to be open because fire supression will be people walking down the isle with a fire extinguisher. There's no weight reduction, nothing being done to actually make it into a "good" freighter. This is temporarily repurposing the airplane to haul a little freight. They want the plane to quickly transform back into a passenger aircraft with minimum effort. If they wanted a perminant Q400 freighter, the overhead bins would be gone, windows removed and plugged with aluminum, floor would be entirely changed. Fire supression would be automated so the now non existant isle can carry cargo. The weight capacity of a perminant Q400 freighter would be substantially higher than this temporary mod.
Hopefully the first thing a cargo Dash would have is a barn door.
goingnowherefast
Yeah hopefully, turn the air stairs into a massive cargo door if there becomes a real Q400 freighter. The rear doors needs to support flight loads from the tail, the front just needs to support the cockpit weight, no controlling and stabilizing forces.
discountpilot
Post by discountpilot »
Did Jazz offer to fly freighter for 10% off? Just curious.
rxl
Post by rxl »
discountpilot wrote: Thu Nov 12, 2020 8:54 pm Did Jazz offer to fly freighter for 10% off? Just curious.
NO
flyingcanuck
Post by flyingcanuck »
Hahahaha good one
discountpilot
flyingcanuck wrote: Fri Nov 13, 2020 9:19 pm
Hahahaha good one
I'll be here all week.
