220 Pilots, what are you thoughts so far??
Big Red has about 6 fins on the property,They look sharp....whats everyones thoughts on this new bird? Is it nice and fun to fly? I'd love to get some feedback.
Re: 220 Pilots, what are you thoughts so far??
I like it. The HUD takes some getting use to and once the FL290 issue is resolved it’ll be a good plane. Passengers seem to like it. Plane has a few quirks but once you get used to them it’s nothing.
https://eresonatemedia.com/
https://bambaits.ca/
- KenoraPilot
Just as a passenger I wasn't super impressed. The lavs at the back make no sense and it's loud as a passenger. Really looks like a beefed up modern CRJ900. Really first world problems, but honestly I expected a little better from the C-Series. I'm sure its a great performer and I would love to drive one
- Daniel Cooper
It's actually bad performer from what I've heard. Good on fuel though.
Then you heard wrong.
But the fuel efficiency is worth the applause.
Anyone who doesn’t understand or appreciate that new, clean-sheet-designed aircraft have teething problems, doesn’t know a lot about new aircraft. The A220 is no different. Recall, if you will, the B787? Lithium batteries anyone? Not to mention the fact it was 3 years late to the show.
The biggest issue with the C Series, sorry A220, are the toilets.
Crap! Really?
Now that stinks! Don’t it?
Who’d a thought?
Gino
Crap! Really?
Who’d a thought?
Gino
if you are saying that ac a220's lavatories are cramped, yes I agree. theres no room to turn around.Gino Under wrote: ↑Mon Jul 06, 2020 2:11 pm The biggest issue with the C Series, sorry A220, are the toilets.
Crap! Really?
But delta's lavatory is located fwd of L2/R2 door and it is spacious and they even got a window.
Aircanada's lav is located aft of L2/R2 door, and is placed just fwd the aft pressure bulkhead, like their 7m8 and some ex-interjet a320 rouges.
I am not experienced enough to tell you how reliable a220's water/waste systems are, but 787's thin lav waste lines clogged occasionally.
KenoraPilot wrote: ↑Mon Jul 06, 2020 7:55 am Just as a passenger I wasn't super impressed. The lavs at the back make no sense and it's loud as a passenger. Really looks like a beefed up modern CRJ900. Really first world problems, but honestly I expected a little better from the C-Series. I'm sure its a great performer and I would love to drive one![]()
I won’t lie, the aft cabin lavs are sad but that is an Air Canada cabin design choice to add another row of seats. There should be 2 large toilets not the one large aft facing one divided in 2.Gino Under wrote: ↑Mon Jul 06, 2020 2:11 pm Then you heard wrong.
Crap! Really?
Who’d a thought?
Gino
The design from an aerodynamic perspective is amazing, clean and slick. Fuel burn is off the chart low for it’s size and impressive as well as it’s Load, range and field performance. Haven’t had a chance to fly it fully loaded on a hot day yet but according to others it’s very good. Comments on performance are usually that it doesn’t climb or fly fast but it was designed with efficiency in mind. The majority of take offs AND climb outs are at reduced power settings that blend fuel efficiency, engine wear and performance.
Once the kinks get ironed out it’ll be even better.
This is from the original CSeries brochure. Notice 2 lavs or 1 lav depending on seating. AC opted for the 1 lav layout (with 136 seats) but divided it by 2 making 2 out of the standard higher seating capacity single lav design.
- 152A25B2-1D0A-4658-97FD-764F1D6C8749.png (910.11 KiB) Viewed 10810 times
What kind of fuel burns is it getting? A friend of mine flew the Max at AC after flying the EMB and he said it was the same fuel burn on each airplane except the max Is way more seating. Anyone know on a per seat basis how they compare? Also noise max vs 220 ?
Book says the MAX and EMB both have the same fuel burn with the A220 burning 360KG less and hour than the max. 2160 vs 1800.
The MAX8 burns the same fuel (2200 kg/hr) as an A319 which AC has configured with 48 fewer seats (120 vs 168). The A220 and 190 are both around 1800, (from what I'm told) as few AC pilots have ventured above FL290.
My numbers are based on “at altitude” but yes, stuck at FL290 the A220 burns the same as an EMB at a proper cruising altitude but with 39 extra seats. Once it can climb above that the difference becomes very apparent.
I usually saw the max down around 2000 kg an hour average. It was more at the beginning of the flight when heavy, but when light it would drop down.
Seems to be taking quite a long time for a fix on that engine resonance issue. Wonder what's happening behind the scene there? Possibly be a bit more to it than a software load? Must be bit of a drag slugging it out at 290 and watching everybody whistling by overhead, dodging CB's, etc?
- Jean-Pierre
The CB issue is a big one this time of year. Imagine how bad the fuel economy is when you are flying off course.
Resonance issues are a big problem. Remember that bridge that collapse. Some engineers are really sweating this one. Imagine the bad press when an uncontained engine failure send shrapnel through the cabin. It would make MAX look like a Volvo of the sky.
I deadheaded on one for the first time the other day. I did notice a bit of resonance in the cabin. Sort of a rumble. I assume it’s from the engine speeds not being matched. Otherwise it was nice.
I don’t have any inside information, but the amount of time the C series has been operating with this major performance restriction is making me wonder if they are having to look at significant (read expensive) engine modifications. Also curious how the engine was validated with this serious inherent issue.Jean-Pierre wrote: ↑Fri Jul 10, 2020 2:41 pm The CB issue is a big one this time of year. Imagine how bad the fuel economy is when you are flying off course.
Well obviously they didn't have the problem during validation.
- 98 Corolla
Aviation authorities seem to lack the resources or expertise to thoroughly validate a modern airliner so they rely on the manufacturer to self validate. Which of course may have a conflict of interest.
I fly it, it definitely has some issues. First it is not an Airbus, not even close.
It feels very small, like a biz jet, even though the cockpit is quite spacious.
The cabin user interface for the F/A’s is horrible, super cheap feel and glitchy, very glitchy. PA system is the same.
Up front, looks wise it’s very nice. However to me, a lot of unnecessary information. The FMS pages layout requires a lot of finger F*^€£ing to get the simplest request, Atis, TO Wat etc.
The seats are a torture device, impossible to get a comfortable position and be able to see through the HUD.
Radio panel is either on a page which is on one of the screens or on the comm panel on the glare shield. They want the left Comm on Capt. Side, right comm on F/O side. Again, finger fucking for a radio change.
Every pilot has a preference on the screen layout, which is annoying.
FMS is slowly growing on me but it has its weaknesses.
We are still unable to do fltplan uplink, patch is coming.
No wind update, patch is coming
No cpdlc , patch is coming.
The electric brakes require a lot of attention on taxi as to not have a constant bucking motion, it’s specific to the fin, some are better then others.
The engines make a lot of noise, on taxi it sounds like we are torturing dogs in the cargo hold, in cruise there is a loud rumble....it’s similar to sitting in a dash 8 classic cockpit noise wise.
Climb performance is crap, and most flights we are super light.
As for the limited flight levels, I have heard rumours of up to another 16 months.
The plane is slippery on decent, low flap speeds make it hard to reduce speeds, flaps 1 is 230kts. Flaps 2 is 210. The speed brakes are useless.
I have found the plane very sensitive hand flying, from the rudders on take off, to roll and pitch sensitivity While hand flying. This thing I bet could do a snap roll easily if the computer would let u.
Initially my landings were very firm, I have found using auto brake low of available makes a huge difference, Brake’s Med and up really grab as soon as you touch and makes the touch down seem harsh.
All just my opinion.
There's a definite rumble around row 23 due to wind around the wheel well and around row 33 due to an antenna (wifi I think) on top causing weird drag. I was told they were looking into it but I'm not holding my breath as they're likely trying to fix the engines first. Flying higher might make those vibrations slightly less annoying too.
It's just a few kinks they have to iron out. Bombardier was in a rush to get the type certified so it's understandable. Airbus will continue to make it a better product and before AC gets all 45 I think it will have gotten better already.
This is why airlines stick to what has always worked. Like a 737.
https://www.flightglobal.com/safety/a22 ... 66.article
Your kidding right? If your not I’m not sure how to respond.
