Encore Recalls
Encore Recalls
Recalling 30 pilots for Oct 1st, and MMG going to 70 hrs for the month of October.....A step in the right direction at least.
Re: Encore Recalls
How many does leave on furlough?
How many flying?
"Stand-by, I'm inverted"
Re: Encore Recalls
They just changed it to 47 recalls. I believe that puts Encore at 339 active pilots and 203 still on furlough. MMG pre-covid was 75 hours. Encore pilots still have the 10%ESP suspended at the moment as well though.
Re: Encore Recalls
Recalling out of seniority. A step in the wrong direction yet again. WJ treasured the one list now they aren't following it? It's only good for them when they want it to be. Glad folk are getting back flying but common, lets not allow any leap frogging.
flyingcanuck
Re: Encore Recalls
Re: Encore Recalls
Wrong, there's mainline pilots that did bit it but couldn't hold it at the time but can now.
Re: Encore Recalls
Yycjetdriver
Re: Encore Recalls
There is also furloughed mainline pilots who did bid FO, couldn’t hold it then and could now that are being passed over.Maxpwr wrote: ↑Fri Sep 18, 2020 10:49 amI understand that but it just doesn’t work that way. There was one opportunity to seek employment at Encore using the PTA and that was upon lay-off. It’s not in perpetuity like we wish it was. If you bid to go to Encore ONLY as a captain and couldn’t hold it then you basically turned down employment as Encore FO and chose lay-off instead Those are the only rights the PTA affords mainline pilots as it’s written. It was communicated at the time of the bid and apparently supported by the ALPA MEC. I didn’t write the PTA and certainly would have done it differently but just think it almost passed WITHOUT a right to bump at lay-off![]()
While you’re description of “how it works” and how the PTA came into play during the first round of furloughs is correct. It doesn’t mean that the order isn’t being broken now. If it was to be completely fair and open they would have announced a vacancy bid with 47 encore positions and let the entire “one list” bid on those positions. That did not happen, if it was to be a true “one list“ there’s no reason it should have been a one shot deal.
Re: Encore Recalls
Yycjetdriver
Re: Encore Recalls
Yes I get what you’re saying and that’s why I said in my previous post you’re correct in describing the way it’s working now. I don’t care about that, what I’m saying is that it’s wrong the way it is and there’s going to be many(maybe 47) pissed off pilots.Maxpwr wrote: ↑Fri Sep 18, 2020 12:30 pmWho said it was a true one list? Nevertheless you made my point. If they couldn’t hold any position whatsoever at Encore in May (bizarre) then the point of bumping into Encore via the PTA is moot. It’s that simple. People talk as if the entire list is open to everyone at all times. It is not. The list simply tracks date of hire in WJ group. The Pilot TRANSFER agreement is what allows mobility into another bargaining unit’s roster. What you’re arguing would be like a senior Encore pilot that COULD have flowed a few years ago but chose not to and he technically has the seniority to hold mainline doesn’t mean he gets to. Because his window of opportunity to TRANSFER has closed while others have recall rights to mainline even though they’re technically junior to the Encore guy. See what I mean?Yycjetdriver wrote: ↑Fri Sep 18, 2020 12:09 pmThere is also furloughed mainline pilots who did bid FO, couldn’t hold it then and could now that are being passed over.Maxpwr wrote: ↑Fri Sep 18, 2020 10:49 am
Re: Encore Recalls
Blowin' In The Wind
Re: Encore Recalls
“Fair”, whatever, whatever. I’m continually surprised that pilots don’t have an intimate knowledge of the contracts of which they voted in favour...
ALPApolicy
Re: Encore Recalls
We very much do. The company just does what it wants and our union also.Blowin' In The Wind wrote: ↑Fri Sep 18, 2020 4:40 pm “Fair”, whatever, whatever. I’m continually surprised that pilots don’t have an intimate knowledge of the contracts of which they voted in favour...
WaldoPepper
Re: Encore Recalls
In what situation would a pilot not have seniority to hold an Encore position in May, but does now with 47 recalled?
Re: Encore Recalls
Not that they didn’t have the seniority, but they took a voluntary lay off, and now facing a reality-check after their summer off, decide they want to now work for encore. IMO they had their chance.
planebored
Re: Encore Recalls
Are you dumb, stupid or dumb... huh?Maxpwr wrote: ↑Fri Sep 18, 2020 10:49 amI understand that but it just doesn’t work that way. There was one opportunity to seek employment at Encore using the PTA and that was upon lay-off. It’s not in perpetuity like we wish it was. If you bid to go to Encore ONLY as a captain and couldn’t hold it then you basically turned down employment as Encore FO and chose lay-off instead Those are the only rights the PTA affords mainline pilots as it’s written. It was communicated at the time of the bid and apparently supported by the ALPA MEC. I didn’t write the PTA and certainly would have done it differently but just think it almost passed WITHOUT a right to bump at lay-off![]()
If it's truly ONE LIST then that WJ pilot who couldn't hold the position then but can now should get first dibs.
My guess is WestJet doesn't want them to go to Encore because that means a full course and now that 6 months have passed and we're 6 months closer to the end of this pandemic they don't want to spend that money knowing they'll be back at ML in short order.
kiaszceski
Re: Encore Recalls
So everyone could potentially bid all positions?
Seems lot of people would choose mainline rather that Encore, meaning all 737 OTS that got in since 2018-ish would now be at Encore ?
planebored
Re: Encore Recalls
I am not a Westjet pilot, but I have 2 very close friends who are (one Encore on WJML) and have had many beers with them discussing the ways of the (canadian aviation) world.kiaszceski wrote: ↑Tue Sep 22, 2020 1:11 pm So everyone could potentially bid all positions?
My opinion for the 3 cents it's worth, now is the best time to transition to a true one list when recalls happen, and allow people to bid into positions they can hold based on their overall number. Then any Encore pilots who have not been given a ML job can bid it now.
Again, 3 cents.
Yycjetdriver
Re: Encore Recalls
Zero chance of that happening, would be a very costly venture. While the training at Westjet is very good(thanks to the hard working and dedicated trainers), costs have always been the primary focus for the company in regards to training.planebored wrote: ↑Wed Sep 23, 2020 12:34 amI am not a Westjet pilot, but I have 2 very close friends who are (one Encore on WJML) and have had many beers with them discussing the ways of the (canadian aviation) world.kiaszceski wrote: ↑Tue Sep 22, 2020 1:11 pm So everyone could potentially bid all positions?
Again, 3 cents.
Re: Encore Recalls
It seems that you are unfamiliar with the WJ CA. WJ does not have a "One List"- it's a pilot transfer agreement, the terms of which are as Maxpwr described.planebored wrote: ↑Tue Sep 22, 2020 12:49 pmAre you dumb, stupid or dumb... huh?Maxpwr wrote: ↑Fri Sep 18, 2020 10:49 amI understand that but it just doesn’t work that way. There was one opportunity to seek employment at Encore using the PTA and that was upon lay-off. It’s not in perpetuity like we wish it was. If you bid to go to Encore ONLY as a captain and couldn’t hold it then you basically turned down employment as Encore FO and chose lay-off instead Those are the only rights the PTA affords mainline pilots as it’s written. It was communicated at the time of the bid and apparently supported by the ALPA MEC. I didn’t write the PTA and certainly would have done it differently but just think it almost passed WITHOUT a right to bump at lay-off![]()
Re: Encore Recalls
Yycjetdriver
Re: Encore Recalls
Rumour has it a grievance was filed by the mainline union today. I haven’t seen it personally but have heard the point of it was recalls being made to encore from furloughed encore pilots only, which violates bumping rights of a combined seniority list. Guess your prediction was wrong.Maxpwr wrote: ↑Fri Sep 18, 2020 2:39 pmOk yes totally agree it’s a shit sandwich served with a side of diarrhea soup. Just don’t want mainline pilots thinking it’ll somehow be changed any time soon.Yycjetdriver wrote: ↑Fri Sep 18, 2020 2:21 pmYes I get what you’re saying and that’s why I said in my previous post you’re correct in describing the way it’s working now. I don’t care about that, what I’m saying is that it’s wrong the way it is and there’s going to be many(maybe 47) pissed off pilots.Maxpwr wrote: ↑Fri Sep 18, 2020 12:30 pm
