CYVR 26L TODA to read 17,250' ?
smooth
Post by smooth »
Anyone know why CYVR 26L TODA became 17,250 feet? :rolleyes:
CYVR TODA NOTAM.png (13.73 KiB) Viewed 2387 times
smooth
Re: CYVR 26L TODA to read 17,250' ?
Post by smooth »
Found a CYVR 2037 Master Plan, including extra runway and probably more clearway or stopway...
probably something to do with this
https://www.yvr.ca/en/about-yvr/who-we- ... aster-plan
You exit the apron at Echo, hit TOGA on Delta, do a step turn on Delta 7 and then on to 26L.
telex
Post by telex »
"Found a CYVR 2037 Master Plan..."
YVR on the ball these days putting NOTAMS out seventeen years in advance.
smooth wrote: Sun Nov 01, 2020 11:26 am Found a CYVR 2037 Master Plan, including extra runway and probably more clearway or stopway...
Hope they will tie floats onto that
montado
Post by montado »
telex wrote: Sun Nov 01, 2020 12:15 pm "Found a CYVR 2037 Master Plan..."
This is why they tell you to slow down at TOD, half of their controllers are in training for the new runway procedures.
thenoflyzone
Post by thenoflyzone »
YVR is trying to attract one of the ME3 carriers. Any bit of extra clearway helps I guess....
linecrew
Post by linecrew »
TODA is the takeoff runway available (TORA) plus the clearway. The clearway in this case is half the runway length. The NOTAM is actually correct.
smooth
Post by smooth »
I understand TORA + Clearway = TODA. It just seems TODA is 17250' that's almost 6000' longer than the actual runway length. Just curious is it because 08 end has nothing but ocean(considering the water is the clearway) And what's the TODA like before the NOTAM?
linecrew wrote: Mon Nov 02, 2020 12:12 pm TODA is the takeoff runway available (TORA) plus the clearway. The clearway in this case is half the runway length. The NOTAM is actually correct.
kevenv
Post by kevenv »
smooth wrote: Tue Nov 03, 2020 11:44 am I understand TORA + Clearway = TODA. It just seems TODA is 17250' that's almost 6000' longer than the actual runway length. Just curious is it because 08 end has nothing but ocean(considering the water is the clearway) And what's the TODA like before the NOTAM?
26L TODA before Notam - 12484'
17250' puts it well into the water so why stop at 17250'? How is water considered part of the TODA? Disregard the question, google is my friend. See second attachment....
Screen Shot 2020-11-03 at 4.54.04 PM.png (805.69 KiB) Viewed 1625 times
Screen Shot 2020-11-03 at 5.11.34 PM.png (271.15 KiB) Viewed 1611 times
linecrew
Post by linecrew »
kevenv wrote: Tue Nov 03, 2020 1:55 pm
TP312 5th edition, 4.4.1.3 states that the maximum length of a clearway is half of the TORA, which is why it stops at 17,250'.
kevenv
Post by kevenv »
linecrew wrote: Tue Nov 03, 2020 2:51 pm TP312 5th edition, 4.4.1.3 states that the maximum length of a clearway is half of the TORA, which is why it stops at 17,250'.
Thank you!
smooth
Post by smooth »
found the document, that is very interesting! learn something today
