Flying Night VFR on an Aeronca Champ 7DC?
SRCrowne
Post by SRCrowne »
Hello everyone!
This is my first post on these forums, so I'll start with a real short introduction about myself. Skip the following paragraph if you'd just like to get to the question.
I'm a newly-minted PPL currently flying out of the CYCC-to-CST3 general region. I have always wanted to fly taildraggers, but I was disappointed with the extremely low availability of rentals in my area. So, in the spirit of adventure, I decided that the only way to do fulfill my dream was to purchase an old taildragger. As soon as I finished my training at CSS3, I found a friend with whom to share a plane with, and we bought an Aeronca Champ 7DC together.
I got into a discussion with my mechanic about the capabilities of this plane, specifically, whether it can fly Night VFR as-is, or if it could be made to do so.
The aircraft has landing and taxi lights, position lights (nav lights), and all the equipment listed in 605.16 (1) (a)-(j).
In 605.16 (1) (k), it states the necessity for:
(k) position and anti-collision lights that conform to the Aircraft Equipment and Maintenance Standards.
I asked whether the aircraft needed a beacon/strobes (anti-collision lights) to my AME, and he said his feeling was that since the aircraft was certified without them, and clearly intended for night operation due to the other installed lights, then it MIGHT not need them. (?!)
Another instructor I asked gave a similar response. :? I have tried contacting TC, but who knows when they'll get back to me.
So, any thoughts on the matter and what my options might be?
EDIT: And just as a note, I am only contemplating Night VFR in fair weather, moon-bright nights; I understand legalities aside, a Champ is far from the ideal plane for things like long XC night flights.
Re: Flying Night VFR on an Aeronca Champ 7DC?
Post by ahramin »
I think the list in the CARs is overriding. If you had a beacon that didn't meet the current requirements that would be a different story but with no blinking light, you clearly don't meet the requirements of 605.16 (1) (k). If all that mattered were the rules in place when the aircraft was built, the list of required equipment would be in part V, not part VI.
Heliian
Post by Heliian »
Yes, you need a beacon or strobe.
How about instruments and lighting? Do you have a lit panel?
SRCrowne
Post by SRCrowne »
Heliian wrote: Mon Nov 09, 2020 2:25 pm Yes, you need a beacon or strobe.
There is a light that illuminates the panel as a whole (though weak). Is that sufficient?
Instruments right now are a directional gyro, turn-and-slip indicator, VSI, ASI, altimeter. (We'll probably add an AI in the future.)
Post by ahramin »
Ideally you want the maximum amount of information with the minimum amount of light. In other words only the things you need to see are lit up at any one time (and the switches or knobs for the light controls to the other stuff :)). I've flown with a panel illuminated by a single lamp. It's not ideal but it works fine (until the bulb dies).
You definitely want to spend some time in your cockpit in the dark going through a practice flight to see what things you can and can't see. Regardless of how it works out, I highly recommend having a headlamp available that you can easily reach with one hand.
challenger_nami
Post by challenger_nami »
I have seen commercially operated Navajos in busy international airports operating NIGHT VFR/IFR flights without any beacons/strobes.
if the aircraft was certified before the CARs relating to the Beacons/Strobes kicked in, then that aircraft model got grandfathered.
The answer is all in the regulations.
Anyone think to look in the Aircraft Equipment and Maintenance Standards? No? Didn't think so.
625.16 Power-driven Aircraft - Night VFR
(1) The position lights and anti-collision lights referred to in CAR 605.16(1)(k) shall meet the requirements set out in Schedule 1 of Appendix I of this standard, and shall:
(a) comply with the standards of light distribution, intensity and colour, and the flashing characteristics, where applicable, in accordance with the Airworthiness Manual;
(b) be installed in accordance with the requirements set out in Chapter 551 of the Airworthiness Manual; and
(c) not cause glare or other annoyance to a flight crew member to the extent that the person's ability to perform duties safely is affected.
4. Anti-collision light 1 or more Red, White or Red/White segmented flashing light (NOTE: Each flashing light, when viewed from a distance, shall exhibit the flashing characteristics specified in the Airworthiness Manual). from a source, or sources, located in accordance with the requirements set out in the Airworthiness Manual . In all directions within 30° above and 30° below the horizontal plane of the aircraft in accordance with the requirements set out in the Airworthiness Manual.
Nothing about grandfathering, and anyway, it's not an aircraft certification thing, it's an equipment thing. Different.
challenger_nami wrote: Mon Nov 09, 2020 3:16 pm I have seen commercially operated Navajos in busy international airports operating NIGHT VFR/IFR flights without any beacons/strobes.
Sigh. Flying aircraft that do not meet the CAR's equipment requirements is not "grandfathering" it is just ignorant.
CpnCrunch
Post by CpnCrunch »
Big Pistons Forever wrote: Mon Nov 09, 2020 6:09 pm
From what I can tell, the anti-collision light requirements are grandfathered in the USA. I assumed that would be the case in Canada, but from what I can tell it seems to work differently here, which is a bit weird:
https://www.faa.gov/documentLibrary/med ... 20-30B.pdf
https://tc.canada.ca/en/corporate-servi ... tions-cars
So, if I'm interpreting things correctly, it looks like in the USA you can in fact fly without any anti-collision lights whatsoever if the type certificate is from prior to 16 May 1953. Whether or not there is a separate FAR requiring lights at night, I don't know. In Canada there just seems to be a minimum requirement for all aircraft...unlike the USA, no strobes at all are required, even if the aircraft is manufacturer after 1971, but all aircraft do require basic anticollision lights.
SRCrowne
Post by SRCrowne »
CpnCrunch wrote: Mon Nov 09, 2020 7:10 pm
That is very interesting! Then it would be possible for an aircraft flying legally at night in the US to not be allowed to enter Canada until civil sunrise, which is odd. (Assuming foreign aircraft are subject to the CARs in the same way, which may or not be true, but it may be the case.)
SRCrowne, PM sent....
A certified aircraft which is compliant in its nation of registry would generally be accepted in another nation by reciprocal agreement. Similar to some provinces and states require a license plate front and back, others just back, though any are accepted in the other jurisdiction.
challenger_nami
PilotDAR wrote: Mon Nov 09, 2020 7:42 pm
Example:
ADS-B is a requirement in US Airspace.
ADS-B is Not a requirement in Canadian Airspace.
Is a Canadian registered aircraft which is NOT ADS-B equipped... able to freely fly in the US Airspace, land there, and then fly back to Canada?
Okay, I'll play for a minute....
I did write:
Just in case someone on the extreme wanted to cite some other example to try to show me up. Now I'm certainly not an expert at ADS-B requirements, but, I expect that as long as the Canadian aircraft does not enter US airspace for which ADS-B is required, ADS-B would not be required! That's what the FAA told me when I inquired a while back. I expect it's similar to a US aircraft visiting Canada without Mode C, just don't enter that airspace! But, don't plan your US flight with/without ADS-B based upon what I say, I'm not an airspace expert.
CpnCrunch
Post by CpnCrunch »
challenger_nami wrote: Mon Nov 09, 2020 7:49 pm
Example:
No, the ADS-B requirement definitely applies to Canadian aircraft flying in the USA.
challenger_nami
@BigPistons,
I am just the messenger. Please don’t shoot me.
I agree that an aircraft without anti collision lights at night, is not as safe as it can be.
But the regulators do Grandfather regulations, for whatever reason.
As pointed out above, Grandfathering of Anti Collision Beacons for aircraft Certified before August 1971 is quite clear in USA (FAA)
As some of us know, Minister of Transport here in Canada does grant exemptions to many of the requirements.
What the OP needs to do is to write to Transport Canada and request an exemption. It might get accepted. That is ONLY IF installing a beacon/strobe is not practical for him/her.
Last edited by challenger_nami on Mon Nov 09, 2020 8:40 pm, edited 3 times in total.
A Canadian aircraft not ADS-B equipped has exactly the same freedoms to fly in the US as a US aircraft not ADS-B equipped. You can fly almost anywhere you want, just not in airspace where ADS-B is required.
CAR605 makes it clear to which aircraft the equipment requirements apply:
605.01 (1) This Subpart applies to
(a) persons operating Canadian aircraft other than ultra-light aeroplanes, hang gliders or remotely piloted aircraft; and
(b) persons operating foreign aircraft in Canada, other than remotely piloted aircraft, if those persons are Canadian citizens, permanent residents or corporations incorporated by or under the laws of Canada or a province.
(2) The following requirements apply to persons operating foreign aircraft, other than persons referred to in paragraph (1)(b), while those aircraft are operated in Canada:
(a) the requirement to carry a flight authority on board the aircraft in accordance with section 605.03;
(b) the requirement that an aircraft be equipped with transponder and automatic pressure-altitude reporting equipment in accordance with section 605.35;
(c) the requirement that an aircraft be equipped with one or more ELTs in accordance with section 605.38; and
(d) radiocommunication and radio navigation equipment requirements that are specific to the aircraft and types of flight referred to in sections 605.14 to 605.21.
Foreign pilots operating foreign aircraft in Canada are not required to comply with the equipment requirements, and don't need strobes or a beacon under Canadian law. Canadian pilots operating the same foreign aircraft in Canada, do.
Both foreign and Canadian pilots operating foreign aircraft in Canada need an ELT, a mode C transponder in transponder airspace, and the appropriate radio equipment.
As some of us know, Minister of Transport does grant exemptions to many of the CARs.
This is true, I have requested and received two exemptions over the years (both for noise exemptions for prop changes on older planes). The process begins with paying an application fee which is about twice the application fee for a serialized STC, and thereafter doing about that amount of work to create the submission - to make a plane less compliant with present standards.
In the case of night lighting, and considering the ease of installation of LED Nav/strobe units, it's easier to get an approval and install the proper equipment.
challenger_nami
PilotDAR wrote: Mon Nov 09, 2020 8:37 pm
+1
I was not intending to show you up. It was a valid point.
Thank you for your courtesy, but I don't agree that drifting the topic with the introduction of ADS-B, in a discussion about night lighting requirements, is a valid point in this context. Doing so takes the discussion away from the topic that the OP wished to discuss with no benefit.
In the mean time, the OP may have found the answer he/she needed, despite the distraction.
challenger_nami
PilotDAR wrote: Mon Nov 09, 2020 9:11 pm
These conversations very often tend to evolve(drift). That is inevitable.
As a matter of fact,... without intending to point blame, your own point evolved (drifted) the conversation from the Grandfatheribility of the Beacon toooooooooo the airworthiness in different jurisdictions. Which is fine.... as I said, conversations evolve.
I am outta here. Good evening y’all.
Now Back to the main topic of:
requirement of Anti Collision Light for Night VFR in Canada.
RedAndWhiteBaron
Post by RedAndWhiteBaron »
There's a very old saying... "if you need to ask, you can't afford it"
I'm not saying anything about your finances, and it would be stupid of me to do so. But I do think that if you need to ask about this, it may not be a wise idea. But lest I forget to remind everyone, I know nothing.
valleyboy
Post by valleyboy »
My only question here is "why"
Legal is not always safe so again why would you want or need to fly a champ at night. Are you building time for licenses or are you a hobbyist.
I'm not criticising, I'm just interested why would you go to all the time and expense to fly a champ at night. New private pilot and a champ at night is a high risk situation.
Good decision to buy a champ and fly conventional gear, my initial 3 hours of flight training was on a champ then I changed to a J3 cub for all but night flying, rented a 172 and did night circuits at Pearson all night to finish my night rating for my commercial.
I does my heart good to see you have the passion for to step back in history. Get out there and find and fly those small grass strips, you will have a ball. Get it off the pavement to really enjoy it.
cheers
http://www.blackair.ca
PT6-114A
Post by PT6-114A »
“Legal is not always safe so again why would you want or need to fly a champ at night. Are you building time for licenses or are you a hobbyist.
I'm not criticising, I'm just interested why would you go to all the time and expense to fly a champ at night. New private pilot and a champ at night is a high risk situation.”
May I ask why you think this? I did my PPL, night and about half of my CPL on a 1967 citabria. Why are you any safer flying a C172 at night? (Not trying to start anything just asking) after the Citabria we had a C150 the only thing that was a little nicer about it was it had a few more post lights but felt safe in both.
I think flying a properly equipped Champ at night is perfectly fine. It's no worse than any other type, and if you actually had to make a black hole forced landing, might actually be a little better (lighter, slower & a little more suited to off airport than most). I get the shivers more flying the 182RG at night than my 150. I can get my 150 onto the ground in the beam of my landing light better than I could in the 182RG!
