FL430 for commercial airliners
This is something I've been wondering for a while, but I wanted to ask why only few operators in the world fly at FL430. Most Boeing and Airbus aircraft have a service ceiling of FL430, and now with many 787s and a350s around, it's a more common sight around the globe, but I've never seen a North American operator at these altitudes. I know the likes of a 777 or a 747 altitude is generally restricted due to weight, while 787s and a350s not so much. I'm sure there's a lot more technical and operational things involved, such as oceanic crossing assigned altitudes, and others which I am not familiar with, but I'm genuinely curious why more operators don't opt to fly a 430 if their planes are capable...
Re: FL430 for commercial airliners
I think (may be mistaken) above 410 one pilot has to have O2 on at all times. Would the drop down masks only be approved for 410 in that case as well on those aircraft?
Ah that makes sense, I didn't even think about that... did a quick google search and found the FAR reference, which i'm sure the CARS one is likely the same
https://rgl.faa.gov/Regulatory_and_Guid ... enDocument
Now what I would be curious to know is, in other parts of the world where a few operators go up to FL430 on the daily, and stay there for hours, I wonder if the mask rule applies
It is exactly because you’d have one of the 2 pilots always on oxygen. Also the good old 767 could get up 430 as well.
matt foley
Every aircraft will have an optimum and a maximum alt showing on the FMS. These altitudes vary with weight and environmental conditions but an example might be "Optimum FL377 MAX FL401". I have no idea about the most modern types you describe but it would be very unusual to have an optimum above FL400 in a 67/57/37 etc. Very light and looking to go over some weather or a more direct routing in otherwise congested airspace would give a reason to go above optimum but when you do a host of other issues arise ie stall speed and VMO get very close and you are one pocket of turbulence away for being to fast or not fast enough. Higher isn't always better.
MF
MF
Cessna 180
Because 430 isn't an RVSM altitude. You would need a block altitude to operate at FL430.
It is non-RVSM, but you don’t require a block altitude... it is simply the next available level above 410, so it is actually a westbound altitude. 450 would be the next available eastbound altitude.Cessna 180 wrote: ↑Thu Feb 04, 2021 1:18 am Because 430 isn't an RVSM altitude. You would need a block altitude to operate at FL430.
DHC-1 Jockey
What about biz jets? They’re routinely above 410, even up into the FL500’s.
Do one of those pilots need to be on oxygen at all times as well?
Yes.DHC-1 Jockey wrote: ↑Thu Feb 04, 2021 8:44 am What about biz jets? They’re routinely above 410, even up into the FL500’s.
In theory.
I've always wondered about Concorde in this respect, either the regulations were different or there were things we just didn't see on the flight deck.
They also would have had ITAR issues with GPS navigation, but GPS wasn't a big thing in planes until after they were retired.
...laura
...laura
Several transport category planes are certified above FL410 and can reach it weight and environmental conditions permitting, but as mentioned the regulation (605.32 (3)(b)) requires one crew member to wear a mask above FL410. It's due to the time of useful consciousness in the event of an explosive decompression, and I know pilots would love to have that rule changed but unless they can figure out how to increase a human body's TOC I don't see that happening anytime soon. There's not much benefit operating at 430 versus 410 to offset the PITA of wearing the mask full time which is why you don't see it, plus you'd be using up the crew O2 for normal ops instead of emergency and the aircraft bottles aren't that big.
International Traffic in Arms Regulations. Law that says (among other things) that GPS receivers that will work above specified speeds (1000 knots) or altitudes (FL600) are sensitive products that require export approval. The intent was to make it impossible for bad guys to use them in guided missiles and such. It makes other things awkward, like using GPS on satellites.
...laura
New Antique Pilot
I had a short cockpit visit on the Concorde on a flight from LHR-JFK-OSH in 1985.lhalliday wrote: ↑Thu Feb 04, 2021 9:19 am I've always wondered about Concorde in this respect, either the regulations were different or there were things we just didn't see on the flight deck.
...laura
We were up around FL600 and no one was wearing a O2 mask.
NAP
Around 4 seconds of useful consciousness.
I don’t suppose that the CARs (or ANOs in 1985) apply to a UK based airline flying to the USA.New Antique Pilot wrote: ↑Thu Feb 04, 2021 10:52 amI had a short cockpit visit on the Concorde on a flight from LHR-JFK-OSH in 1985.lhalliday wrote: ↑Thu Feb 04, 2021 9:19 am I've always wondered about Concorde in this respect, either the regulations were different or there were things we just didn't see on the flight deck.
...laura
NAP
IIRC the FARs have more restrictive O2 rules below 410, something about the PF had to don his/her mask if the other pilot left the flight deck above ~250.
Someone has said that O2 regs are probably the most frequently intentionally violated rules in the book. That doesn’t make it right, but not surprising.
- Rank Moderator
What a magnificent bird! Higher, and faster, than many/most of the fighter planes at the time! And, hella sexy looking, too!New Antique Pilot wrote: ↑Thu Feb 04, 2021 10:52 am I had a short cockpit visit on the Concorde on a flight from LHR-JFK-OSH in 1985.
NAP
Happiness is V1 at Thompson!
bobcaygeon
1985........They wouldn't wear masks because that would interrupt the chain smoking....New Antique Pilot wrote: ↑Thu Feb 04, 2021 10:52 amI had a short cockpit visit on the Concorde on a flight from LHR-JFK-OSH in 1985.lhalliday wrote: ↑Thu Feb 04, 2021 9:19 am I've always wondered about Concorde in this respect, either the regulations were different or there were things we just didn't see on the flight deck.
...laura
NAP
Air France was still serving their pilots wine with their crew meals on transatlantic flights and we de-iced with hot water (or not at all)
This is what I would like to know as well. As I have mentioned in one of my previous posts, if one looks up flights on flightradar24, you will notice that quite a few airlines outside North America frequently operate at FL430, and some flights for the duration of the entire flight. For example, there are a few BA99 flights from LHR to YYZ at the beginning of January that operated the entire flight at FL430... This was when the restrictions on the UK were announced, so likely no pax and just cargoNotDirty! wrote: ↑Thu Feb 04, 2021 12:29 pmI don’t suppose that the CARs (or ANOs in 1985) apply to a UK based airline flying to the USA.New Antique Pilot wrote: ↑Thu Feb 04, 2021 10:52 amI had a short cockpit visit on the Concorde on a flight from LHR-JFK-OSH in 1985.lhalliday wrote: ↑Thu Feb 04, 2021 9:19 am I've always wondered about Concorde in this respect, either the regulations were different or there were things we just didn't see on the flight deck.
...laura
NAP
Either way, not really that important, just merely curious
I remember reading somewhere back in the day that the reason the Concorde had such small cabin windows was that it was designed with enough pack flow to maintain partial pressurization with one cabin window blown out so that the pax blood would not boil. Crazy windy I bet. Wonder if they ever demonstrated it during certification? Would also be interesting to know what the emergency descent procedure was.How would they control the G loads in a pushover at Mach 2?
It’s above 250 here without a quick donning mask, 410 with. I’m sure the US is the same.NotDirty! wrote: ↑Thu Feb 04, 2021 12:29 pmI don’t suppose that the CARs (or ANOs in 1985) apply to a UK based airline flying to the USA.New Antique Pilot wrote: ↑Thu Feb 04, 2021 10:52 amI had a short cockpit visit on the Concorde on a flight from LHR-JFK-OSH in 1985.lhalliday wrote: ↑Thu Feb 04, 2021 9:19 am I've always wondered about Concorde in this respect, either the regulations were different or there were things we just didn't see on the flight deck.
...laura
NAP
I’m always confused by some posts where it seems like the author doesn’t care if what they post is accurate. They just take their best guess. The rule in the US changed last year. Took 2 min of searching to verify.
https://www.regulations.gov/document?D ... -0289-0001
Summary
This action amends the oxygen mask requirement for circumstances in which a single pilot is at the aircraft controls. This action applies to all certificate holders who conduct domestic, flag, and supplemental operations. This action responds to a statutory mandate that requires the FAA to increase the flight level threshold at which the FAA requires use of an oxygen mask by the remaining pilot at the aircraft controls when the other pilot at the controls leaves the control station.
Dates
This final rule is effective on March 23, 2020.
For Further Information Contact
Daniel T. Ronneberg, Part 121 Air Carrier Operations, Air Transportation Division, Flight Standards Service, Federal Aviation Administration, 800 Independence Avenue SW, Washington, DC 20591; telephone 202-267-1216; email Dan.Ronneberg@faa.gov.
Supplementary Information
I. Executive Summary
This final rule addresses section 579 of the Federal Aviation Administration Reauthorization Act of 2018, Public Law 115-254 (Oct. 5, 2018) (“FAARA 2018”), which requires the FAA to issue a final regulation revising § 121.333(c)(3) of title 14, Code of Federal Regulations (14 CFR), to apply only to flight altitudes above flight level 410. Such an amendment would increase the flight level (1) threshold from flight level 250 to flight level 410 (i.e., a flight altitude of 41,000 feet), at which the FAA requires a pilot at the controls to put on and use the required oxygen mask while the other pilot leaves his or her control station. As a result, by this action, the FAA amends 14 CFR 121.333(c)(3) to replace the current flight altitude threshold of flight level 250 with flight level 410.
I posted a part 91 reference, you posted a part 121 reference, that's where I made the mistake in my second post.BTD wrote: ↑Thu Feb 04, 2021 4:18 pm I’m always confused by some posts where it seems like the author doesn’t care if what they post is accurate. They just take their best guess. The rule in the US changed last year. Took 2 min of searching to verify.
Summary
Dates
Also, you're reference talks about leaving ones seat... all it says there is that when one crew member leaves, the other doesn't need to put their mask on unless they are above flight level 410
https://www.ecfr.gov/cgi-bin/text-idx?S ... 3&rgn=div8
Part 121.333
"(a) General. When operating a turbine engine powered airplane with a pressurized cabin, the certificate holder shall furnish oxygen and dispensing equipment to comply with paragraphs (b) through (e) of this section in the event of cabin pressurization failure.
(b) Crewmembers. When operating at flight altitudes above 10,000 feet, the certificate holder shall supply enough oxygen to comply with §121.329, but not less than a two-hour supply for each flight crewmember on flight deck duty. The required two hours supply is that quantity of oxygen necessary for a constant rate of descent from the airplane's maximum certificated operating altitude to 10,000 feet in ten minutes and followed by 110 minutes at 10,000 feet. The oxygen required in the event of cabin pressurization failure by §121.337 may be included in determining the supply required for flight crewmembers on flight deck duty.
(c) Use of oxygen masks by flight crewmembers. (1) When operating at flight altitudes above flight level 250, each flight crewmember on flight deck duty must be provided with an oxygen mask so designed that it can be rapidly placed on his face from its ready position, properly secured, sealed, and supplying oxygen upon demand; and so designed that after being placed on the face it does not prevent immediate communication between the flight crewmember and other crewmembers over the airplane intercommunication system. When it is not being used at flight altitudes above flight level 250, the oxygen mask must be kept in condition for ready use and located so as to be within the immediate reach of the flight crewmember while at his duty station.
(2) When operating at flight altitudes above flight level 250, one pilot at the controls of the airplane shall at all times wear and use an oxygen mask secured, sealed, and supplying oxygen, in accordance with the following:
(i) The one pilot need not wear and use an oxygen mask at or below the following flight levels if each flight crewmember on flight deck duty has a quick-donning type of oxygen mask that the certificate holder has shown can be placed on the face from its ready position, properly secured, sealed, and supplying oxygen upon demand, with one hand and within five seconds:
(A) For airplanes having a passenger seat configuration of more than 30 seats, excluding any required crewmember seat, or a payload capacity of more than 7,500 pounds, at or below flight level 410.
(B) For airplanes having a passenger seat configuration of less than 31 seats, excluding any required crewmember seat, and a payload capacity of 7,500 pounds or less, at or below flight level 350.
(ii) Whenever a quick-donning type of oxygen mask is to be used under this section, the certificate holder shall also show that the mask can be put on without disturbing eye glasses and without delaying the flight crewmember from proceeding with his assigned emergency duties. The oxygen mask after being put on must not prevent immediate communication between the flight crewmember and other crewmembers over the airplane intercommunication system.
(3) Notwithstanding paragraph (c)(2) of this section, if for any reason at any time it is necessary for one pilot to leave his station at the controls of the airplane when operating at flight altitudes above flight level 410, the remaining pilot at the controls shall put on and use his oxygen mask until the other pilot has returned to his duty station."
My apologies, I didn’t know about that change... I did write “IIRC”, and it seems I did recall correctly the now superseded regulation.
Having done some research, I see that ICAO Annex 6 covers oxygen requirements, but does not include a requirement to wear a mask above 410, only if the cabin altitude exceeds 10,000 for more than 30 minutes, or exceeds 13,000 for any time. I understand that EASA regulations also allow operations above 410 without wearing O2, so the BA flights are legal at 430 without using crew O2.
Thanks for this. I tried looking up UK and EASA regs but I haven't been able to find them, might just be my crappy google skillsNotDirty! wrote: ↑Thu Feb 04, 2021 5:17 pm My apologies, I didn’t know about that change... I did write “IIRC”, and it seems I did recall correctly the now superseded regulation.
