How long should I expect to fly before making it into the regionals
mmmike
Post by mmmike »
Hello, I was just wondering how long will it take for someone to make it into one of the regional airlines. For the sake of the post I just started my CFI job and want to go to the regionals. How long will it take (ex. 2 years) from personal experience or others. Thank you
Conflicting Traffic
Re: How long should I expect to fly before making it into the regionals
Post by Conflicting Traffic »
mmmike wrote: Mon Apr 19, 2021 11:05 pm Hello, I was just wondering how long will it take for someone to make it into one of the regional airlines. For the sake of the post I just started my CFI job and want to go to the regionals. How long will it take (ex. 2 years) from personal experience or others. Thank you
If you're qualified to be a CFI, then pre-COVID you would have been able to go to the regionals almost immediately (assuming you have a MIFR/IATRA, of course). Nowadays it will depend on how fast the recovery is. Best case, maybe a year or so. Most likely case, I would guess maybe three to fours years. Worst case, you don't want to know.
Conflicting Traffic please advise.
valleyboy
Post by valleyboy »
First, if you are presently employed and working as a CFI consider yourself very lucky.
To your question, who can tell but the number of 5 years to clear the pilots on furlough has been batted around. So new hires will be after that. Many factors can change this but the level 1 carriers and feeders are cutting low yield roots, which means a reduction in crews and aircraft. It will take time for them to even consider marginal routes and logically these routes will be serviced by smaller carriers. Who knows if the level one guys will entertain code share.
Bottom line, who knows when but the reset could change the whole canadian approach to the commuter world. I can see more independents out there like Porter.
http://www.blackair.ca
Furloughs have to be rehired, Mainline carriers have to start hiring again to create the movement up, you might get lucky but more likely all the people that during this time are building more relevant experience than you will get looked at earlier in the process.
Get a bit of PIC and go get a job on a King Air or Metro... get a path to an upgrade on one of those and your path to a 705 machine will be shorter.
ayseven
Post by ayseven »
Take this for what you paid for it, from a guy who did NOT make it anywhere... well, I worked when I had to. Listen to Altiplano (for once). HIs advice is right on the money here. PIC, PIC, PIC, the more turbine the better.
Having said that, I am not sure a lot of big 705 guys will be necessarily attractive to many companies, since those people are guaranteed to go back to the biggies once recalls are on the way. I know of a guy who was in Asia flying, who has not flown in a year and a half, who is just biding his time, and not chasing the "up north" charter jobs (been there, done that, for them). I would wager a lot are like that, so the pool of experienced, reliable, proven pilots is not as large as some might think.
In your shoes, I would be tempted to just stay where I was, keep your wits about you, and stop worrying about "maybe". Timing is everything, and if you go away to some far away place, for fun times with chips and pop, etc, you can be out of the loop on the happenings at the regionals down in civilisiation. A bird in the hand, as they say. You are in an airplane, and that is basically what any employer is going to see as MOST important.
Outlaw58
Post by Outlaw58 »
ayseven wrote: Tue Apr 20, 2021 7:21 am In your shoes, I would be tempted to just stay where I was, keep your wits about you, and stop worrying about "maybe".
Bingo
58
redlaser
Post by redlaser »
In a year or more all ATPL pilots will be dead from the coronavirus, A boing 747 aircraft will be selling for 100 bucks, so you can own your own. But seriously, the coronavirus will be around for several years. Your best bet is that you buy an aircraft and get your required hours for a ATPL and Instrument rating.
Don't let your wife talk you out of buying an airplane, :D
ayseven wrote: Tue Apr 20, 2021 7:21 am Timing is everything, and if you go away to some far away place, for fun times with chips and pop, etc, you can be out of the loop on the happenings at the regionals down in civilisiation. A bird in the hand, as they say. You are in an airplane, and that is basically what any employer is going to see as MOST important.
That's just silly. Working up North will not get you out of the loop for hiring at regionals. Regionals are big enough that vacancies are advertised. You're not chasing unadvertised hush cush posh corporate jobs that you only hear about because your friend's friend told you about it when he bumped into you at the airport.
Any regional will prefer turbine PIC time over FI time. They might also like someone with both more than someone who only has one. Since the OP already has FI time, getting some turbine time will only help him. No negative career effects whatsoever. Except that he might hate the job if he's stuck up north for 5 years, but then again some people seem to go crazy instructing for 5 years as well.
mmmike
Post by mmmike »
Conflicting Traffic wrote: Mon Apr 19, 2021 11:47 pm
What about pre covid, how many years do u have to work before getting hired to regionals.
mmmike
Post by mmmike »
What about pre covid? How many years did u have to work before getting a job as getting into regionals.
ToolShed
Post by ToolShed »
4 to get to a Tier 3 regional.
10 years to get to a Dash 8 not too long ago.
rudder
Post by rudder »
Neither Jazz nor Encore nor Porter will be looking at OTS hiring sooner than 2023.
There are other 705 regional carriers that are hiring and will be hiring. Right candidate. Right place. Right time.
Single engine piston flight instructing time used to be good enough to get you hired (circa 2019). It isn’t anymore. Maybe in 2024?
Go get time that counts and time that will make you a better pilot. Time in the circuit and time in the ‘practice area’ won’t do that.
rudder wrote: Wed Apr 21, 2021 7:42 am Neither Jazz nor Encore nor Porter will be looking at OTS hiring sooner than 2023.
Good advice!
Go get a King Air or Metro job. Go get real world flying experience. Jobs will be more competitive to get than this generation up and coming have seen... Instructing only and people without command time or an ATPL won't be in the mix.
fish4life
Post by fish4life »
When you see CFI so you mean you have your class 1 instructor rating or are you confusing it with American CFI?
RockSalty
Post by RockSalty »
mmmike wrote: Tue Apr 20, 2021 11:40 pm What about pre covid? How many years did u have to work before getting a job as getting into regionals.
I instructed for about a year before getting an in person interview with one of the regionals a couple of months before covid hit
simply_no_one
Post by simply_no_one »
Best idea is to stick with your CFI job until you have enough to qualify as a medivac FO. Then go get a job flying a King Air and upgrade on that. By the time two years goes by you hit over 2000 hours, ATPL and have some solid real world experience under your belt the regionals will likely be hiring. Now is a good time to pad your experience as best as you can because once hiring opens up, I imagine competition will be fierce. I foresee Jazz/Encore being back to the 1500, ATPL and 500 MPIC requirement like they were a few years ago.
Roar
Post by Roar »
Don’t get discouraged for a two-three year wait nowadays.
It is still incredibly quick, I can remember the day when to get a left seat Navajo job a guy needed 5000hrs, King Air and regional jobs were 7000-8000 hrs and a corporate jet forget it that might as well be the space shuttle.
Ash Ketchum
Post by Ash Ketchum »
Took me 2 years. These days probably 4-5 ish.
‘Bob’
Post by ‘Bob’ »
You don’t have to wait at all.
You can do all major city pairs on the regionals in about 3 or four legs.
mmm..bacon
Post by mmm..bacon »
Wouldn't a better question be "how can I enjoy my aviation career post instructing?"
It might be that you'll spend your entire career chasing 'the regionals' and never get there - just don't get your resume pulled, blow the interview, pooch the ride...dozens of things could happen between you and 'your' regional job. Plan to enjoy your career first, and consider yourself lucky if you get the call..
TheStig
Post by TheStig »
I see from your posts at the beginning of this year that you were in the process of picking a flight school, so as I understand it, this question is hypothetical. Doing research is great and I'm sure you'll find that responses will be varied. As you've already figured out the industry is cyclical and everyones career will take different paths along different timelines.
Flying at an airline isn't the be-all end-all for many pilots, but since you've brought Jazz up, let's talk about the career of a young pilot whose ambition is to be an airline pilot.
Most Airline pilots will agree that it's beneficial to join whichever seniority list you end up on as young as possible. At my airline seniority rules; what position you hold, type, schedule, destinations, base, vacation, everything. However, try not to look at your career as a race to join an airline. For one, you'll view everyone you train with or work with as your competition, you shouldn't. Your peers around you, as complete training and begin careers' together will likely end up some of your best life long friends.
It's worth pointing out that the economic (epidemic?) cycles that aviation is tied to mean that that you and your peers will likely have the same or very similar progression. What I mean his that regardless of it taking someone 3 years or 12 years to join an airline, 80% of the pilots they went to school with were likely hired at airlines within +/-2 years of them, we all live through the same ups and downs.
Put things into the context of a timeline, if you're lucky you could spend 40 years flying and you could work for the same airline for 30+ years. You'll be an FO, Captain fly all over the world, but the 5-10 years you spent working towards that job will be the flying you'll be talking about for those 30+ years.
‘Bob’
Post by ‘Bob’ »
It’s win some lose some.
I am envious of my colleagues who have lots of seniority and job security at established carriers who will enjoy earnings and lifestyle I will never attain.
But conversely, they lost their younger years to lower pay, schedule & reserve, commuting & crashpads (many still are), and the often depressing certainty that this is it.. there’s no looking for greener pastures, no speeding things up by hard work and merit, and above all... ...no fun pretty much right from the get go.
To me, scope is what you wash your mouth out with, equipment bid is what farmers do at auctions, block holder is the rubber tote for your Legos, and seniority is a young Mexican girl. It’s depressing how much these things seems to absolutely consume airline pilots on their own time.
And here I am, 20 years in... ...zooming a turboprop VFR between high mountain peaks for a job where I sleep in my own bed every night.
And I’m sitting next to people who used to be at the regionals.. ...and may not ever go back.
