2 by 4’s inside a 180
Morning Cessna 180 drivers
Have you ever loaded 2 by 4 eight foot length inside the plane? Don’t want to fly external load
Re: 2 by 4’s inside a 180
I think it can be done, though you probably won’t get many in. Best if you can remove passenger seat, rear seat and rear bulkhead. While things can be slid through the passenger window if it opens, easier if you can remove door. Once in, and slid as much forward to lie just shy of right pedals (stowed if possible) replace bulkhead. Then door. I’m going to say six or nine can be safely strapped to seat rails. Measure for length before attempting, I can’t remember if it was a 180 or 185 we did that on and I think the 185 is slightly longer.
Can be done removing the rear bulkhead, but just as a note, is it something you can do with metal studs? Could pack about 5-6x more if so before you bulk out.
- Rank Moderator
Probably cheaper nowadays with metal ones, too!
IIRC, I took the passenger door off, the pax seat out, and the rear seats out of a 185, and an 8'er would just fit in. Couple of brownline clips, and a piece or two of rope/herc strap, and you're good to go!
Happiness is V1 at Thompson!
Thanks folks
I have 8 of those that I want to fly to our camp. I’ll remove the bulkhead and back seat this afternoon.
Measurements suggest it can be done. Will let you know
Are you on floats? Why don't you want to carry them externally? Eight 2 x 4's are an easy and safe external load on floats.
Never done the external load thing...but was considering it if I could not load everything inside first before....in the end I was able to load all the 2 by 4's yesterday without having to either remove the door or the passenger seat...
Thanks folks...someday I'll have to get acquainted with flying small external loads...
Before someday, TC will be enforcing the rules requiring an STC for any external load on a fixed wing....someday I'll have to get acquainted with flying small external loads...
(hint to C180/185 floatplane owners, you should all go in together to obtain an STC for useful loads, it'll make the costs seem more reasonable...)
yes they will fit. But easiest with front and back seats out and door off but they will go in with the door on but will take two people to load them. Make sure they are secured well so they can't get at your rudder peddle and can basically stack them up to where they don't interfere with controls.
