Will the Bad Conditions Still be There
Probably. Why scare the pax a second time......
C-GGMN, a Jazz Aviation LP De Havilland DHC-8-402 was operating as flight JZA8274 from Vancouver Int'l (CYVR), BC to Kelowna (CYLW), BC with 4 crew members and 78 passengers on board. While on approach, descending from approximately 6500 to 5500 feet above sea level, the aircraft encountered severe turbulence and wind shear of +/- 35 knots. The flight crew had difficulties controlling the aircraft and conducted a missed approach. After a hold, the crew attempted a second approach into CYLW and encountered similar conditions. They again
conducted a missed approach and diverted back to CYVR. There were no injuries.
Maintenance conducted a severe turbulence inspection and found no faults. The aircraft was
returned to service.
Re: Will the Bad Conditions Still be There
So the flight crew did the right thing twice?
Go outside and get some fresh air pelmet.
I agree!
Slow news day pelmet?
No, I just don’t like the idea of going back into a place where I had control difficulties and severe turbulence. But, based on the replies, I guess a different line of thinking is more widespread than I thought.
I think the ones wanting fresh air were the pax.
- rookiepilot
There’s always tomorrow for a new pile of CADORS.
I tend to stick with the TSB reports. But I will publish a few more now.
Does it rough up the same way up where the pilots are strapped-in as in a back row near the tail ? I’d never realized the extent to which one can swing back and forth with the rudder deflections in a back row til one day on Jet Blue going to FL we got assigned the lowest alt over/near some tornado action over TN.
I sat in the very last row of a 777 once for takeoff. It was loud and a lot of side to side motion. The cabin area can have a different experience than the flight deck, including the firmness of the touchdown.pdw wrote: ↑Fri Dec 24, 2021 7:09 amDoes it rough up the same way up where the pilots are strapped-in as in a back row near the tail ? I’d never realized the extent to which one can swing back and forth with the rudder deflections in a back row til one day on Jet Blue going to FL we got assigned the lowest alt over/near some tornado action over TN.
Longitudinally I can see the front and back might be more equal as far as roughness in flight. There a Horizontal Stabilizer downforce is helping by smoothing things out as the wing rides through turbulence. The lateral in that sense is quite different.
The vertical stabilizer on a larger twin turbofan A/C doesn’t build lift to one side much more than the other; the side to side is counter-controlled by rudder a bit more more loosely as the airframe gets sheared around in rough skies. The side to side motion somehow doesn’t pivot exactly the same around a vertical axis at the wing as the longitudinal one does around a lateral axis in pitchchanges. So perhaps the pilots won’t feel the worst lateral sway as much at the front?
Another thing to consider is that the aircraft flexes quite a bit. So the up and down movements close to the elevator will likely be greater than up front, even when equidistant from the point of rotation.pdw wrote: ↑Sat Jan 01, 2022 4:06 pm Longitudinally I can see the front and back might be more equal as far as roughness in flight. There a Horizontal Stabilizer downforce is helping by smoothing things out as the wing rides through turbulence. The lateral in that sense is quite different.
My guess is the FO was the one flying and a highly experienced training Captain was the PM on the first attempt. The Captain took over for the next attempt...
I always found it most stable near where the wings attach to the fuselage. Think of it like a teeter-totter. The whole contraption is one gigantic piece, but it's the very ends of the teeter-totter that get the most relative change in motion. The middle of the teeter-totter (fulcrum) hardly has any relative motion at all. The same principle works side to side (rudder) as up and down (elevator).
