Flight planning resources for the Rockies
Hi all,
are there any weather sources for planning low level-ish flights through the Rocky Mountains? Yes there are multiple weather stations spread all across the mountains, but I was wondering if there was any more detailed weather forecasts dealing with winds close to the ground etc.
For example, Switzerland and Austria have a system where they generate weatherforecast for specific VFR routes through the alps. The VNC shows VFR routes as well West of Calgary. Are there any specific forecast like that? I couldn't find anything on Nav Canada, but then again, it's been a while that I've flown VFR through them.
Thanks,
digits
Thanks,
digits
Re: Flight planning resources for the Rockies
Click on "VFR route forecast", but it isn't available at this time of year, and I think it only gives the weather from Hope to Lytton and Princeton.
Also, windy.com is quite accurate for forecasting winds.
I'll try that in March, thanks!
https://www.metcam.navcanada.ca/hb/index.jsp?lang=e
You may find these webcams of use before/during the trip.
Good luck.
Good luck.
- Redneck_pilot86
BC highways also has a lot of webcams in various passes that can be helpful
- PeterParker
Windy (.com or the app) is a good source of cams throughout BC and they put both Aviation cams and highway cams all on a convenient format on a map.
