Asymmetric Reverse Leads to King Air Excursion
I found this one interesting. Is there anything King Air(or similar drivers) are doing to discover reverse thrust asymmetry prior to departure. Perhaps the run-up at the beginning of the day. How many pilots do that run-up prior to the first flight anyways.
"The GCS Aviation Ltd. (CAR604) Beech B300, C-FGSX, was operating on a flight from Victoria,
BC (CYYJ) to Red Deer, AB (CYQF). Upon landing, the pilot engaged propeller reverse thrust and
the RH engine engaged reverse before the LH engine. The asymmetric thrust condition created a
directional control issue. The pilot attempted to recover using yaw control, braking and bringing the
engines out of reverse thrust; however, the aircraft continued to yaw to the left and exited the west
side of the runway. The aircraft skidded sideways and rotated approximately 270 degrees before
coming to rest 50 feet from the edge of the runway surface. The airport authority assisted in
transferring the passengers back to the hangar, and the aircraft was subsequently towed back to
the hangar. The pilot and two passengers received no injuries. The aircraft damage was limited to
a flat RH tire.
Company maintenance performed engine ground runs and found the RH engine was entering
reverse ahead of the LH engine. The LH engine beta valve and reverse pick-up rigging was
adjusted and the aircraft released for continued service."
a flat RH tire.
- Col. Panic
Re: Asymmetric Reverse Leads to King Air Excursion
It’s a good thing that every King Air I ever flew had perfectly symmetric reverse! It was always reassuring on a slippery runway that you could jam it into max reverse at 100 kts and never have to worry about this kind of response. Kudos to the crew involved for keeping the greasy side down, and making sure nobody got hurt! Heroic flying skills!!
Back when I flew twin PT-6 powered airplanes, the drill always was to select Beta, pause, visually confirm the Beta indication lights were both illuminated, then apply power. The brief pause seemed well worth it to prevent asymmetric power. From my DHC days, I was sadly aware of a number of pilots who slammed in lots of reverse on a STOL landing to then realize reverse thrust was asymmetric as they were going off the side of the runway.
Without reading the report, that sounds like a ground prop solenoid issue. In the 300 and 350 there is actually an annunciator light to warn you of this as it's seen as quite serious. The issue isn't just that there is a mismatch in torque in reverse, but that one prop stays at the flight idle low pitch stop and the other one potentially one either goes into the ground idle (beta) or even full reverse mode. The 1900 has basically the identical electric low pitch stops as the 300/350 but for some reason that light and any mention of it is not in the AFM. It might just be the longer wheel base and bigger rudder of the 1900 makes it less of an issue.
Shitty reverse rigging is one of my biggest pet peeves from my time in Beechcraft. Engineers hate messing with it because every little change requires a full engine run, so any adjustments cause hours and hours of fuss. One 200 I flew actually had no reverse thrust at all and had presumably been like that for years. I can still hear the room full of engineer eyes rolling when I told them. The N1 never even increased with the levers at the stops, just beta. When they finally finished messing with it you could parallel park that Beech.
I feel certain I need a recording of this for my ring tone. Or at least, can you describe the sound? Please!?
“Jamming’ it into max reverse at 100 knots” was likely the cause of the incident. PilotDAR’s procedure is SOP in every airline I have worked at. Even in some really heavy iron the PM calls the reverse annunciation before the PF starts powering it up.
- Col. Panic
https://en.m.wikipedia.org/wiki/Sarcasmsportingrifle wrote: ↑Thu Jan 27, 2022 7:15 pm “Jamming’ it into max reverse at 100 knots” was likely the cause of the incident. PilotDAR’s procedure is SOP in every airline I have worked at. Even in some really heavy iron the PM calls the reverse annunciation before the PF starts powering it up.
Jamming ? What is the difference between Jam and Marmalade ?
I cannot Marmalade my fist into your face
You can always spot the guys who never get a second date by the way they roughly abuse equipment. The gentle art of seduction and caressing is lost on those thugs . Divorce court is in their future !
Treat and respect the plane like a lady and she will not be a bitch to you
- Col. Panic
That’s more than can be said for my ex-wives! I’m pretty sure one did try to marmalade her fist in my face!!
There’s like… zero reason to use reverse on a Beech product.
Especially in Red Deer.
That's a completely inaccurate statement.
Chase lifestyle not metal.
I agree tho. I never used reverse on a landing and I have 2000 hrs of King Air all around Nunavut on small gravel runway. You simply don’t touch reverse on gravel, even less if you have contaminated runways during winter.
Hi, yes you do. I assure you. You don't ever stop on gravel, but you most certainly do use reverse. I should say you can, it may not be necessary. But it's perfectly fine. Former Borek trainer, voyager trainer, lots of time in locations you've mentioned. Reverse is PERFECTLY fine on gravel. The king airs are easy planes to fly, which is nice. Exciting is for my days off. I haven't flown a king air for 17 years but I doubt it's changed.RegionalPilot wrote: ↑Tue Feb 01, 2022 4:24 pmI agree tho. I never used reverse on a landing and I have 2000 hrs of King Air all around Nunavut on small gravel runway. You simply don’t touch reverse on gravel, even less if you have contaminated runways during winter.
I remember one guy that liked to keep max reverse on until pretty much stopped. I was surprised the blades didn't pick up a bunch of stones. Seemed risky to me.
100% those guys wreck props every season.
- Col. Panic
Way to “mansplain” to the guy whose username is literally “King Air Guy”.RegionalPilot wrote: ↑Tue Feb 01, 2022 4:24 pmI agree tho. I never used reverse on a landing and I have 2000 hrs of King Air all around Nunavut on small gravel runway. You simply don’t touch reverse on gravel, even less if you have contaminated runways during winter.
Every Beech product I have flown has had very effective reverse. Models with a ground idle gate make it much easier to not select reverse, should that be your wish, but having many hours in models without the second gate on the power levers, you can use reverse on every landing, regardless of the surface. In any case I suggest judicious use of reverse until the engines are evenly spooled up, and don’t put yourself in a position where you are throwing a cloud of dust and gravel directly in front of your engines, so you ingest that crap moments later.
I only acquired abut 2000 hours of turbo-prop time during my career - mostly Commander 1000 with a smidge of KingAir time. I really don't remember using much actual reverse during landings; lots of beta, but no actual reverse...
I used full reverse on virtually every landing. Reverse is free, brakes are expensive.
For gravel operations, we say brakes are cheap, props are expensive…
Engines have them both beat on dollar valueRegionalPilot wrote: ↑Wed Feb 02, 2022 2:16 pmFor gravel operations, we say brakes are cheap, props are expensive…
