King Air in YQT
King Air in YQT
Post by 2112 »
Just saw this come across my feed, Luckily all walked away. 300 series leased by the RCAF one article said but appears to be registered to Tindi.
https://www.country1053.ca/2022/01/31/n ... ane-crash/
RoAF-Mig21
Re: King Air in YQT
Post by RoAF-Mig21 »
That looks to be "The Government of Saskatchewan" aircraft, or it USED to be at one point.
https://www.jetphotos.com/photo/6673230
DHC-1 Jockey
Re: King Air in YQT
Post by DHC-1 Jockey »
It was an RCAF King Air operating as NSTAR2 (North Star 2) from Trenton.
It looks like an RCAF Challenger just landed in Thunder Bay as CFC3803 and is filed back to Trenton, probably bringing the crew back to base.
Gonzodriver
Re: King Air in YQT
Post by Gonzodriver »
Glad to hear everyone is ok.
Bede
Re: King Air in YQT
Post by Bede »
DHC-1 Jockey wrote: Mon Jan 31, 2022 5:00 pm It was an RCAF King Air operating as NSTAR2 (North Star 2) from Trenton.
What do they use those for? Didn't know they had King Air's.
RoAF-Mig21
Re: King Air in YQT
Bede wrote: Mon Jan 31, 2022 8:15 pm
I didn't know about the 350 either, but the RCAF uses King Airs out of Southport (Portage la Prairie) Manitoba to train their pilots. It's the King Air C90A (BEECH CT-145 KING AIR, RCAF designation)
There is also info on the King Air 350s here:
https://static1.squarespace.com/static/ ... erials.pdf
ant_321
Re: King Air in YQT
Post by ant_321 »
I believe for “corporate” type flying. I used to see them in YQX once in a while. Saw a couple of the senior officers at the base get into the back of it and taxi away once or twice.
tsgarp
Re: King Air in YQT
Post by tsgarp »
They are part of the Multi Engine Utility Flight out of Trenton. Used for light transport (personnel, parts for a mobile repair party).
Bede
Re: King Air in YQT
Post by Bede »
Right in front of employee parking lot.
rudder
Re: King Air in YQT
Post by rudder »
That is one seriously broken airplane.
Definitely headed for the scrap heap.
Bede
Re: King Air in YQT
Post by Bede »
DHC-1 Jockey
Re: King Air in YQT
Here's the details on the leased King Air's from the RCAF website @http://www.rcaf-arc.forces.gc.ca/en/air ... e-350.page
I guess the one that crashed wasn't painted in RCAF colours yet.
Screen Shot 2022-02-01 at 11.56.00 AM.png (1.42 MiB) Viewed 6159 times
NotDirty!
Re: King Air in YQT
Post by NotDirty! »
There are more than a few similarities to the incident discussed in this thread: Asymmetric Reverse Leads to King Air Excursion
Too soon to jump to conclusions, but I start to wonder….
WestTexasDeathPencil
Re: King Air in YQT
Post by WestTexasDeathPencil »
This King Air along with C-GPDC and C-GSYC are owned by Pat Campling/Avalerion Corporation and are operated under contract to the RCAF. They're registered to Tindi, but they don't really have anything to do with them. They were previously registered to Transwest until last year under the same arrangement, though C-GEAS was Campling's personal aircraft until it switched OCs.
The Hammer
Re: King Air in YQT
Post by The Hammer »
WestTexasDeathPencil wrote: Wed Feb 02, 2022 5:25 pm This King Air along with C-GPDC and C-GSYC are owned by Pat Campling/Avalerion Corporation and are operated under contract to the RCAF. They're registered to Tindi, but they don't really have anything to do with them. They were previously registered to Transwest until last year under the same arrangement, though C-GEAS was Campling's personal aircraft until it switched OCs.
Jr is still naming planes after his folks? SYC looked better when it was B58. The 350 is definitely un upgrade from the "Wetdream" PDC used to be.
Bede
Re: King Air in YQT
Post by Bede »
Any update on this investigation? It's not on the TSB site and I assume that's because it's RCAF.
JL
Re: King Air in YQT
Post by JL »
Re: King Air in YQT
JL wrote: Sat Sep 03, 2022 9:19 am DFS investigation.
https://www.canada.ca/en/air-force/corp ... gator.html
Interesting. Could they have pushed the left prop in reverse?
porcsord
Re: King Air in YQT
Post by porcsord »
digits_ wrote: Sat Sep 03, 2022 10:26 am Could they have pushed the left prop in reverse?
Unlikely, the 350 has 2 gates, conceivably they could have got one into ground fine. They do fall out of the sky if you go over the first gate in the air. You'd also have to work to get these things to stall on approach... so I'm not sure what happened.
My money is on pilot error in some form though.
Re: King Air in YQT
porcsord wrote: Sat Sep 03, 2022 10:40 am
From what I recall, the 300/350 does have a bit of a temperamental flight/ground idle system. The flight idle stops are mechanically set by the beta valves, but the ground idle stops are set by solenoids energized by one of the squat switches. If it fails in the on position, it'll set the blade angles to the ground idle stop in an under-speed condition, even if the powers are ahead of the flight idle gate. There is an annunciator if either of the solenoids are still receiving power after takeoff, but I know that was added part way into production. EAS was a very early production 350, so there's a solid chance it didn't have it unless it was retrofitted at some point. There are low pitch annunciators, but those wouldn't illuminate until the blade angle had already dropped well below flight idle.
‘Bob’
Re: King Air in YQT
Post by ‘Bob’ »
I was thinking a solenoid issue as well but they would have got a Master Caution. The early 350 without that system makes sense.
