Bamaji Air Caravan Hits Ice
Fortunately, no serious injuries.......
C-GIPR, a wheel-equipped Cessna C208 aircraft operated by Bamaji Air Inc., was conducting a
visual flight rules (VFR) flight from Sioux Lookout (CYXL) ON, to an ice strip on Springpole Lake,
ON with the pilot and 1 passenger onboard. Approximately 17 nm NNW of CYXL the aircraft
impacted the frozen surface of Lac Seul. The ELT activated and was detected by the Search and
Rescue Satellite-Aided Tracking (SARSAT) system. A DND aircraft that was conducting training in
the area responded and SARTECHs parachuted into the site. The occupants suffered minor
injuries and the aircraft sustained substantial damage. There was no fire. The TSB is investigating.
- Redneck_pilot86
Re: Bamaji Air Caravan Hits Ice
Nothing but dumb luck prevented this from being a plane load of fatalities.
How do you know that? Do you have some other info on this crash?Redneck_pilot86 wrote: ↑Sat Mar 26, 2022 10:10 am Nothing but dumb luck prevented this from being a plane load of fatalities.
- Redneck_pilot86
I’ve seen photos of what’s left of the aircraft. It was a bad wreck, and they are lucky nobody died.
I’m not going to pretend to know exactly what happened, but knowing the location of the accident and the weather of the day, it’s not hard to figure out what happened. It’s happened before, and will probably happen again.
What was the weather like?Redneck_pilot86 wrote: ↑Sat Mar 26, 2022 11:46 pm I’ve seen photos of what’s left of the aircraft. It was a bad wreck, and they are lucky nobody died.
- Redneck_pilot86
SPECI CYXL 082134Z 26010G16KT 230V290 2SM -SHSN BKN010 OVC020 M03/M09 A2958 RMK SN6CU1SC1 SLP045=
METAR CYXL 082100Z 26010G19KT 230V290 15SM -SHSN FEW020 OVC070 M03/M09 A2957 RMK CU1AC7 SLP042=
METAR CYXL 082000Z 27010G22KT 3SM -SHSN BKN010 OVC020 M03/M07 A2957 RMK SN4SC1SC3 VIS VRB 1 1/2 - 4 SLP042=
SPECI CYXL 081940Z CCA 25015G24KT 1 1/2SM -SN VV010 M04/M07 A2957 RMK SN8 SLP041=
METAR CYXL 081900Z 26008G15KT 4SM -SN FEW012 BKN020 OVC060 M03/M06 A2956 RMK SC2SC4SC2 VIS NE 2 SLP038=
SPECI CYXL 081855Z 24010G16KT 1/2SM SN VV004 M03/M06 A2956 RMK SN8 SLP038=
METAR CYXL 081800Z 24010G15KT 3SM -SN BKN010 OVC015 M03/M05 A2956 RMK SN5SC2SC1 VIS VRB 2 - 4 SLP038=
202203082058 SPECI CYPL 082058Z AUTO 20005KT 6SM -SN SCT016 OVC046 M04/M06 A2951 RMK SLP021=
202203082035 SPECI CYPL 082035Z AUTO 22006KT 3SM -SN SCT016 SCT027 OVC032 M04/M07 A2951 RMK SLP021=
202203082031 SPECI CYPL 082031Z AUTO 23007KT 2 1/2SM -SN SCT016 SCT027 OVC032 M04/M07 A2951 RMK SLP021=
202203082023 SPECI CYPL 082023Z AUTO 22008KT 2SM -SN FEW014 SCT019 OVC030 M04/M07 A2952 RMK SLP022=
202203082022 SPECI CYPL 082022Z AUTO 22009KT 2 1/4SM -SN BKN016 OVC030 M04/M07 A2952 RMK SLP022=
202203082000 METAR CYPL 082000Z AUTO 20008KT 3SM -SN BKN016 OVC030 M04/M07 A2952 RMK SLP027=
202203081950 SPECI CYPL 081950Z AUTO 21007KT 3SM -SN BKN016 OVC028 M04/M07 A2952 RMK SLP023=
202203081945 SPECI CYPL 081945Z AUTO 21007KT 2 1/4SM -SN BKN016 OVC028 M05/M07 A2952 RMK VIS VRB 1 1/2-3 SLP023=
202203081942 SPECI CYPL 081942Z AUTO 21008KT 2SM -SN BKN016 OVC028 M05/M07 A2952 RMK VIS VRB 1 1/2-3 SLP024=
202203081939 SPECI CYPL 081939Z AUTO 22008KT 2 1/4SM -SN BKN016 OVC027 M05/M07 A2952 RMK VIS VRB 1 1/2-3 SLP024=
202203081937 SPECI CYPL 081937Z AUTO 22006KT 3SM -SN BKN016 OVC027 M05/M07 A2952 RMK SLP024=
202203081932 SPECI CYPL 081932Z AUTO 21008KT 3SM -SN SCT014 OVC025 M05/M07 A2952 RMK SLP024=
202203081926 SPECI CYPL 081926Z AUTO 20007KT 3SM -SN BKN014 OVC023 M05/M07 A2953 RMK SLP026=
202203081924 SPECI CYPL 081924Z AUTO 20009KT 2 1/4SM -SN BKN014 OVC023 M05/M08 A2953 RMK VIS VRB 1-3 SLP026=
202203081900 METAR CYPL 081900Z AUTO 20006KT 2SM -SN BKN014 OVC025 M05/M07 A2953 RMK VIS VRB 1 1/2-3 SLP030=
202203081851 SPECI CYPL 081851Z AUTO 21007KT 2SM -SN BKN014 OVC027 M05/M08 A2953 RMK VIS VRB 1 1/2-3 SLP027=
202203081848 SPECI CYPL 081848Z AUTO 20007KT 2 1/4SM -SN BKN014 OVC027 M05/M08 A2953 RMK VIS VRB 1 1/2-3 SLP027=
202203081800 METAR CYPL 081800Z AUTO 19005KT 1 3/4SM -SN OVC012 M06/M08 A2953 RMK VIS VRB 1 1/4-2 1/4 SLP031=
The accident happens at 2020z, within 20 miles of YXL.
Whiteout conditions. Instrument flying required.
