Page 1 of 1
ipc
Posted: Sun Apr 24, 2022 11:46 am
by flyndad
Anyone done a recent IPC and if so what was tested?
Re: ipc
Posted: Sun Apr 24, 2022 1:43 pm
by Squaretail
The same things they always check.
You have to do a precision approach, a non precision approach and a hold. If its a multi, one of those approaches is going to be single engine.
For more detail, its the same stuff.
https://tc.canada.ca/en/aviation/public ... ne-tp-9939
Re: ipc
Posted: Mon Apr 25, 2022 12:10 pm
by Kaykay
They test unusual attitude recovery as well.
Re: ipc
Posted: Mon Apr 25, 2022 12:15 pm
by digits_
Kaykay wrote: Mon Apr 25, 2022 12:10 pm They test unusual attitude recovery as well.
That's not part of a standard IPC according to the document linked above. Might be a school thing.
Re: ipc
Posted: Mon Apr 25, 2022 12:28 pm
by Kaykay
digits_ wrote: Mon Apr 25, 2022 12:15 pm
See advisory circular 401-004, section 4, 2a (i and ii) also 6.3 flight activities 4a i and ii. Both indicate requirement for unusual attitude recovery and this is consistent with all of the examiners in my area. Why it’s not in the FTG, I don’t know. If it’s been superseded somehow, I’d appreciate the reference.
Re: ipc
Posted: Mon Apr 25, 2022 12:40 pm
by digits_
Kaykay wrote: Mon Apr 25, 2022 12:28 pm
https://tc.canada.ca/en/aviation/refere ... no-401-004
My apologies, I had no idea. Thanks for the references!
Re: ipc
Posted: Mon Apr 25, 2022 12:45 pm
by Kaykay
digits_ wrote: Mon Apr 25, 2022 12:40 pm
Happy to help! It caught us all off guard at one point too :)
Re: ipc
Posted: Sun May 08, 2022 10:26 am
by ReducedSeparation
I did an IPC recently. The AC cited above outlines everything in detail, but here’s a general overview:
The whole emphasis is to try and keep things as “real” as possible as if it were a normal IFR flight. It’s one thing for the candidate to sit down and regurgitate all of the regs in a flight test fashion, but on the IPC you’re supposed to be tested in more of a scenario-based environment. For example, flight test would be “when is a take-off alternate required” but IPC would be “what is the minimum weather required to take-off today, and if you take-off at mins and have an emergency, what do you do?” (fly to the take-off alternate). Few other questions like that in the ground brief, reviewing aircraft performance/weight and balance and a typical emergency/abnormal situation question.
For the flight (in aircraft or sim), maybe unusual attitudes and another abnormal situation en route to your destination, non-precision ground-based navaid approach (LOC, VOR, NDB), missed approach, hold, engine failure, precision approach (ILS/LPV) to a landing and that’s it.
No tricks (in theory), just flying how you would normally fly a plane in the real world.
Re: ipc
Posted: Sun May 08, 2022 4:42 pm
by flyndad
Very helpful, thank you
