Has Stall Training been eliminated
Re: Has Stall Training been eliminated
broken_slinky wrote: Thu May 19, 2022 8:36 am Although, maybe the owner previously experienced an airframe failure that was only recoverable with a chute?
Um ...
PilotDAR wrote: Thu May 19, 2022 8:42 am
....experienced an airframe failure that was only recoverable with a chute?
Is that a thing? Ever, in GA history?
Well there are a few spar AD's around for a good reason!
broken_slinky
Post by broken_slinky »
Absolutely. Now I'm of the "just fly the damn plane" camp but if I had a failure that was impossible to pilot safely back to terraferma, I think I'd be happy to have the option of pulling that lovely red handle.
Could a chute have saved these two? Perhaps.
https://www.aopa.org/training-and-safet ... raft-apart
Maybe with this one too:
https://generalaviationnews.com/2020/07 ... for-pilot/
This was a pretty well reported accident that indicated 2 other planes in North America suffered similar fates.
https://www.flyingmag.com/new-zealand-v ... p-details/
Possibly with this one too, if the pilot realized what was happening, cut the engine and pulled the chute before the spiral was sunk in deep.
https://www.aopa.org/training-and-safet ... ht-breakup
Maybe a bit too big of a bird to be considered GA?
https://www.avweb.com/flight-safety/pro ... in-flight/
Hmmm, the five cited examples have not persuaded me. I am certainly not expert at BRS systems, so open to more knowledgeable input, but I suspect that all of those events involved speeds or unusual attitude/out of control such that the pilot would have been outside a 'chute deployment speed and attitude envelope anyway. But, I'm opening to learning if it is different.
The non certified Biplane, well that could be a different story, no comment on that one...
For the other four, it seems to me that attentive piloting to prevent excursion from controlled flight/overspeed would have prevented anything bad happening. "Flying the plane" would have prevented the plane breaking up, and risking being in a situation where the broken falling plane never entered a deployment envelope anyway.
Indeed...
C210 VH-SUX losing a wing during survey would have been prevented by anything close to a visual inspection of a very accessible area of the spar. Maybe a BRS would have saved that, but the inspection would have been much less costly, and way safer in the long run.
The two times that PA-28's have lost wings, and AD's resulted, at altitude, yes, a BRS might have made all the difference - but both of those planes were low when they broke up, and again, a good inspection, already understood would have turned up the defect which resulted in the breakup.
We can carry around a lot of extra stuff in a plane to protect for what happens after it goes wrong, or, inspect, maintain, and fly so it doesn't go wrong.
I still believe in life jackets though! :oops:
OtherRedBaron
Post by OtherRedBaron »
PilotDAR wrote: Thu May 19, 2022 11:52 am I still believe in life jackets though! :oops:
As my instructor taught me, having trained out of YTZ in winter... there's nothing down there but drowning.
Would I wear one at the soaring club, with nothing but flat fields around? No. Would I wear one over water, with nothing but drowning around? Yes, absolutely.
As for stall training, I recently did some in an SGS 2-32, a glider with washin, and therefore very poor stall handling. At least with soaring clubs, yes, it's still very much a thing.
JasonE
Post by JasonE »
Soaring clubs require all members to complete a spin check each spring. The first time I did I one in a glider, I pushed inverted. Gliders don't require much stick forward for recovery apparently!
I have a hard time resisting a kick of the rudder whenever I stall a plane :) Citabria likes to pop out on it's own after 1 rotation unless you have someone in the back.
Pilots should not be afraid of a spin and should have plenty enough training to be comfortable recognizing one long before it happens, and recovering quickly if it does. I don't feel the standard syllabus here in Canada did a good enough job for me. One lesson with 2-3 spins does not build enough muscle memory IMO.
JasonE wrote: Fri May 20, 2022 2:23 pm
All of PPL and CPL training should be oriented around stall recognition and recovery. There is no reason why an ordinary Cessna or Piper should ever be in a spin. If it is than either you grossly mishandled the airplane, deliberately kept in pro spin controls or were so asleep at the switch you were stupid times 3
1) You let the airplane enter slow flight and did nothing, then
2) You let the airplane stall, and did nothing, then
3) After it stalled you let uncontrolled yaw develop and did nothing
Even if you do let let the airplane stall if you control the yaw with rudder it can not spin.
The accident statistics are clear. The majority of stall spin accidents occur close to the ground and there was not enough altitude to complete a spin recovery. There was however invariably an opportunity to avoid losing control in the first place
Spin training belongs in an introductory aerobatics course, which I highly recommend everyone does.
goingmissed
Post by goingmissed »
There are so many people here who think, "I've been trained to recover from a stall and I am comfortable recovering from a stall, therefore everyone else should be comfortable with it."
Guess what, some people aren't comfortable with it. They don't want to rely on a stall recovery technique that they may not have practiced in a decade. Some people are weekend warriors who go out for a leisure flight without the intention of pushing the aircraft to it's limits.
Who are any of us to judge another pilot for choosing to add an additional layer of protection to their aircraft?
goingmissed wrote: Sat May 21, 2022 8:51 am There are so many people here who think, "I've been trained to recover from a stall and I am comfortable recovering from a stall, therefore everyone else should be comfortable with it."
I would suggest that if a pilot is not completely comfortable with slow flight and stall recovery, then they should be working on that, not how to pull the red handle. I fully support that pilots should practice at the limits, but the limits that matter are those just before and after the airplane leaves controlled flight. So the exercises of most value IMO are flight in the extreme slow flight regime at moderately high power. The airplane should be just nibbling at the stall so that you have to actively manage AOA and yaw to maintain control.
If you can comfortably do that with automatic control inputs you will never get into an inadvertent spin because you will have instinctively put in the control inputs necessary to prevent the developing loss of controlled flight and subsequent spin entry.
Last edited by Big Pistons Forever on Sat May 21, 2022 11:53 am, edited 1 time in total.
My perspective is different. In my opinion, the only benefit provided by a BRS to a certified plane is that if the airplane ends up in an unflyable condition, yet still within the 'chute deployment envelope, the RBS becomes the last layer of protection. Hitting the ground excepted, no unaccelerated stall in a certified plane will render it unflyable. If the pilot thinks of the BRS as a layer of protection, they must be prepared, trained, and current enough to maintain the flight as much as possible within the deployment envelope, and have a plan for when they cannot remain in the envelope (close to the ground, takeoff and landing come to mind). Like be ready to "avoid" a stall.
I opine that if a weekend warrior is so proficient with flying to the optimum of the BRS' protection, maintaining decent stall avoidance and basic recovery skills is probably less effort! Low altitude events aside, an unaccelerated stall in near wings level co-odinated flight in a certified plane is pretty well a non event. If they worry pilots, those pilot should seek out some currency training - it's time.....
I respect a pilot who knows, and flies within his/her limits, that's commendable. And if that pilot has stall avoidance so perfected that they will never stall, okay, that is safe. So another layer of protection on top of safe, is still... safe.
goingmissed wrote: Sat May 21, 2022 8:51 am Guess what, some people aren't comfortable with it. They don't want to rely on a stall recovery technique that they may not have practiced in a decade.
Are you seriously advocating that a device that destroys the airframe is an acceptable alternative to a normal stall recovery?
WANP
Post by WANP »
Stall recovery is easy, and should be practiced often, same with slow flight, and other maneuvers. In 26 years as a pilot, never once did I wish my plane had a chute.
So that begs the question, do people see these chutes as a reason to practice less, take more risks, and just plan to use it to save their butt?
Whitney
goingmissed
photofly wrote: Sat May 21, 2022 11:45 am
I know of a group of four children (under 20 y/o) that were killed in a 172 that got into a flat spin.
I am in no way stating that it is a substitute to the proper stall recovery, but it is not for any of us to judge someone for wanting to add an additional layer of safety.
I for one keep tools in my car to be able to change my wheels, oil, or many other small tasks. Am I obtuse because I am preparing for the possibility that something will go wrong instead of focusing only on preventative measures and not having a plan-B?
goingmissed wrote: Sat May 21, 2022 2:30 pm
We all know where the fault for that lies, and it's not with the absence of a parachute. Why would a pilot not have practiced a stall recovery in a decade? I'm not arguing that nobody should want a parachute, but there are lower limits to proficiency below which I think someone should recognize they should just not fly.
The only way to get an airworthy 172 into a flat spin is to load it behind the aft aft C of G limit. 172's have two aft C of G limits, depending upon how the pilot has chosen to operate it. But even loaded in front of the more aft of those two limits, it will not flat spin - I've done the testing. From spin testing other Cessnas (260/208) I can say that at the aft C of G limit, it may require "brisk" control wheel input (as described in the POH) and sustained full nose down to break the stall/spin. But correctly loaded Cessna singles do not enter unrecoverable spins.
I am aware of a few accidents over the years, where four new pilots/students were flying together in a 172, and spun it in. I would wonder if there was some "hey, watch this..." factor in those accidents. I've never heard "hey watch this..." just before flying to achieve effective stall avoidance.
fish4life
Post by fish4life »
They shouldn’t be flying the plane if they aren’t comfortable with stall recovery, if they don’t fly enough to stay comfortable then they should go up with an instructor until they are. The day after you are done your flight test should be a day you are becoming more proficient at flying it shouldn’t be a high point of your proficiency.
