AgPlane Incident thread
Oh oh.....The first one is not even an airplane......
C-FBWE, a Hiller UH-12E helicopter operated by Western Aerial Applications Ltd., departed
Winnipeg City Heliport (CWG2), MB to apply control pellets to a farmers field. While seeding and
making a tight turn, the helicopter was unable to maintain altitude and the pilot attempted a forced
landing. The pilot made an autorotation at 20 feet above the ground and landed hard; making
contact with small tree branches and a pole guy wire. The helicopter sustained substantial damage
to its skids. The pilot was not injured and the 406 ELT activated.
albertdesalvo
Re: AgPlane Crash thread
An auto from 20 feet??
Sounds rather difficult...
It sure does.
He needed another 0 following that 20.
Whitney
C-FELO, a Thrush S2R-T34, operated by Provincial Airways, was conducting an aerial application
flight near Glenavon, SK, located 15 miles south west of Grenfell (CKU6), SK. While applying
chemical onto a canola field, the aircraft’s vertical fin struck a powerline. The pilot then carried out
a hard landing straight ahead and the aircraft came to a stop in an upright position. The pilot was
not injured and the aircraft sustained substantial damage.
C-FOBO, a Robinson R44 helicopter operated by Hanley Heli Service, was conducting an aerial
application flight near Bradwell Saskatchewan, MB. The helicopter departed from a road to spray
an adjacent wheat field, loaded with 30 gallons of chemical. During the initial application pass, in a
westerly direction, the helicopter struck a powerline and the pilot conducted a hard landing straight
ahead. The pilot was not injured; however, the helicopter sustained substantial damage.
C-GICZ, an Air Tractor AT-502B operated by Arty's Air service, was conducting an aerial
application flight near Ste. Agathe, MB. While applying chemical on a canola field, the aircraft's
rudder struck a powerline. The pilot then carried out a low level recovery straight ahead over the
town of Ste. Agathe and diverted to Winkler (CKZ7), MB where the aircraft landed safely. The pilot
was not injured and the aircraft sustained damage.
The operator reported that the right wing tip, the upper rudder cap, propeller blade, and pump
blade fans were damaged and will be replaced prior to returning to service.
Tragic......
C-FJVL, an Arty's Air Service Ltd. Air Tractor AT-502B, was conducting agricultural application
operations 29 NM SSE of Camrose (CEQ3), AB with 1 pilot on board. During an application pass
the aircraft collided with terrain; the pilot was fatally injured. There was no post-impact fire and the
ELT did transmit. The Edmonton TSB office deployed 2 investigators to the accident site.
The 41-9 Aerial Ltd Robinson R44II, C-GGJS (S/N 12254), was carrying out spray operations on a
canola field 18NM north of Boyle (CFM7), AB when on the last tank of the day, during one of the
final passes, the helicopter came in contact with the canola crop. Control was lost and the
helicopter tumbled forward, coming to rest inverted in the crop. The pilot was uninjured and was
able to extract self from the wreckage. The helicopter was substantially damaged. There was no
fire. The ELT did not activate.
C-FCRF, an Air Tractor AT-502B operated by Prairie Sky Crop Solutions, was conducting an aerial
application flight near Niverville, MB. While applying pesticide on a crop, the aircraft's propeller
blade and tail fin came into contact with a powerline. The pilot carried out a low-level recovery,
jettison the remaining pesticide load and returned to Niverville, MB where the aircraft landed safely.
The pilot was not injured and the aircraft sustained damage. Part of the tail fin and rudder
remained lodged in the powerline until it was removed by Manitoba Hydro.
The operator reported that the propeller blade, tail fin and tail rudder was to be repaired prior to
returning the aircraft to service.
C-FIAM, a Call Aircraft S-1B1X, was operating from a farm air strip approximately 15 nm N of
Coronation (CYCT), AB. Check out instruction was being provided to a licensed pilot by an
instructor. Upon touchdown the aircraft bounced and control was lost. The aircraft was landing
west to east and departed the right side of the runway, contacted some trees and then came to
rest. The occupants were uninjured and were able to exit the aircraft unassisted. The aircraft was
From TSB...
C-FCBK, a Thrush S2R-T34 operated by Kindersley Airspray, was performing aerial application of
a field 7NM WNW of Luseland (CJR2), SK. During a turn at a low altitude, the aircraft's left wing
contacted the ground. The aircraft subsequently collided with the terrain and it was destroyed. The
pilot was injured and airlifted to hospital.
Re: AgPlane Incident thread
C-GDKO, an Air Tractor AT-402B operated by Western Canadian Aerial, was conducting an aerial
application flight from Gilbert Plains Airport (CJH2), MB. While on an application pass
approximately 10nm to the northeast of CJH2, the aircraft's landing gear collided with a power line.
The wire cutters on the gear legs severed the line. The pilot stopped spraying and returned
uneventfully to CJH2. The pilot was uninjured. The aircraft sustained minor damage, limited to
spray nozzles and the pump fan blades.
From TSB...
C-FMXB, a Thrush S2R-H80 aircraft operated by Agmax Ltd., was performing an aerial application
flight 5.5 nm NE of Minnedosa (CJU5), MB, near the community of Polonia, MB. During a low
pass, the aircraft inadvertently touched the crop and the landing gear was ripped from the
fuselage. The aircraft subsequently belly landed onto the ground in an upright position. The pilot
was not injured. The aircraft sustained substantial damage to the landing gear, lower fuselage,
engine, and propeller.
From TSB....
C-GCKV, a Thrush Aircraft S2R-H80 operated by Fly'N Dutchman Ag Ltd., was conducting aerial
application operations 5.7 nm southwest of Melfort/Miller Field (CJZ3), SK. On an application leg,
the aircraft gained altitude to avoid a power line. After clearing the power line, the pilot initiated a
descent to resume spraying. The descent was not arrested in time and the aircraft struck the level
terrain. The pilot received minor injuries and was transported to hospital. The aircraft was
GodlvlPilot
She posted on her insta that she needed surgery and lots of time to heal. But for the most part the subject line makes it sound less worse then her personal post about it.pelmet wrote: ↑Wed Jul 17, 2024 1:42 pm From TSB....
Glad to hear she survived it and is on the mend - and best wishes for a full recovery. If it's who I'm thinking of, I met her on the ground during a fuel stop at CJZ3 a few months ago, seemed like a really nice person.GodlvlPilot wrote: ↑Mon Jul 29, 2024 6:32 pmShe posted on her insta that she needed surgery and lots of time to heal. But for the most part the subject line makes it sound less worse then her personal post about it.pelmet wrote: ↑Wed Jul 17, 2024 1:42 pm From TSB....
Must have hit the level ground really hard. Is that easy to happen in agplane ops?I WAS Pez wrote: ↑Tue Jul 30, 2024 11:07 amGlad to hear she survived it and is on the mend - and best wishes for a full recovery. If it's who I'm thinking of, I met her on the ground during a fuel stop at CJZ3 a few months ago, seemed like a really nice person.GodlvlPilot wrote: ↑Mon Jul 29, 2024 6:32 pmShe posted on her insta that she needed surgery and lots of time to heal. But for the most part the subject line makes it sound less worse then her personal post about it.pelmet wrote: ↑Wed Jul 17, 2024 1:42 pm From TSB....
From TSB...
C-FYPO, an Ayres S2R-R1340 operated by Precision West Ag Corp (dba Provincial Airways), was
conducting a VFR aerial application flight from Rosetown Aerodrome (CJX4), SK. While spraying a
field 27 miles west of CJX4, the aircraft's left landing gear struck a powerline while climbing out of
the field. The wire was cut by the left landing gear wire cutter and the pilot maintained control of the
aircraft. The aircraft then returned to CJX4 for an uneventful landing.
The operator's maintenance inspected the aircraft and it was observed that there was a scratch on
the left wing leading edge and minor damage to the left wingtip fairing.
From TSB...
C-FRXL, an Air Tractor AT-502A agricultural aircraft operated by Pembina Air (1999) Ltd. departed
a private airstrip at Niverville, MB, on a VFR flight to perform aerial application of a field 1 nm East
of Tourond, MB. While turning at a low altitude to start the spray run, the aircraft inadvertently
descended and struck the terrain. The aircraft sustained substantial damage. The pilot sustained
minor injuries.
minor injuries.
piperdriver
Do you have the date for this incident pelmet?pelmet wrote: ↑Sun Sep 08, 2024 6:55 pm From TSB...
minor injuries.
Sorry,piperdriver wrote: ↑Mon Sep 09, 2024 4:44 pmDo you have the date for this incident pelmet?pelmet wrote: ↑Sun Sep 08, 2024 6:55 pm From TSB...
minor injuries.
I deleted the email right after posting this. But Cadors would have the date.
Merry Christmas to those not subscribed to the dailies who want the data:
https://www.tsb.gc.ca/eng/stats/aviation/data-5.html
From TSB...
minor injuries.
minor injuries.
From TSB...
C-GPRO, an Ayres S2R-R1340 equipped with a Walter M601E engine and operated by Precision
West Ag Corp (dba Provincial Airways), departed the Rosetown Aerodrome (CJX4), SK, to conduct
an aerial application flight of a field near Birsay, SK. After the first application pass of the field, the
aircraft collided with the level terrain. The aircraft was substantially damaged. The pilot was fatally
injured. There was no post-impact fire and the ELT activated. The TSB deployed to the site.
