Coffee Mug Search for 737
Jimmy_Hoffa
Post by Jimmy_Hoffa »
Hopefully not too politically charged of a topic.
ISO a good insulated coffee mug/tumbler that fits in the mug holders in the cockpit of the 737 Max. Most standard sizes ones I have tried are too big. Need something that can keep liquid hot for ~8 hours.
-Jimmy
7ECA
Re: Coffee Mug Search for 737
Post by 7ECA »
Yeti seems to be the gold standard for keeping beverages hot or cold, with a wide variety of sizes/shapes of containers. A bit on the pricey side, but worth it as they do perform as advertised.
A cheaper, yet decently performing, alternative to Yeti would be Camelbak.
Might be a bit of trial and error in finding a size/base diameter that will fit in the Max's cupholders. Wouldn't hurt to take a measurement, and then go from there.
DanWEC
Post by DanWEC »
So I labour under an irrational obsession with design and performance of consumer products. Lol. It's as fun as it sounds, especially for my wife when it's time to buy, well anything.
Anyhow I've found Yeti to be alright- high end marketing and design for midrange performance. But without going to some boutique manufacturer, far and away the best mug I've found for keeping coffee hot is one specific model of Thermos.
I've had 3 in the last 10 years that have been all over the North and the rest of the world. It a roughly 14-16oz metal mug with a stepped base so it fits in smaller cupholder, available with or without a handle. The problem with 99% of these mugs is that they don't insulate the lid, while that's fine for keeping drinks cold it doesn't work so well for keeping coffee hot. This thermos mug has a thick mechanism and a rubber seal that pops down by moving a lever on top. It's the only one I've found that won't have a warm lid after a few minutes which would indicate it's losing heat. Like 6 hours in a parked BE10 at -40 and it's still hot. Fits in the bus cupholder, not sure about 73.
Ya can get them at Walmart for about 40 bucks.
Wow, I must be bored tonight.
Pfft
Post by Pfft »
Gsi Microlite. Thin, fits every cupholder without pulling it out. . . stays hot for too long.
ant_321
Post by ant_321 »
Just pull the liner out of the holder on the centre consul. You can fit nearly any mug in there then.
Jimmy_Hoffa
Thanks for the suggestions. Got some food avenues to look at.
-Jimmy
Hydroflask makes the product you seek.
Doesn't leak when closed, keeps it piping hot for hours.
albertdesalvo
Post by albertdesalvo »
DanWEC wrote: Sun Jul 03, 2022 7:30 pmbest mug I've found for keeping coffee hot is one specific model of Thermos.
So bored you forgot to tell us which model. :rolleyes:
I went to walmart.ca and searched for "thermos stainless". Dozens upon dozens of them came up. Not much good.
RocksAndProps
Post by RocksAndProps »
The Yeti Rambler 10oz/280ml fits in the 737 cupholders. It really doesn't hold very much liquid, but it stays hot for hours and hours.
DanWEC
Post by DanWEC »
albertdesalvo wrote: Mon Jul 04, 2022 9:41 am
https://thermos.com/collections/mugs-tu ... g-mug-16oz
Some others might have a longer "hot" rating on paper but this is the best I've had in practice. Seals well too for tossing into the security bins.
Post by North Shore »
I'll second the Thermos brand. I use one of the tumblers instead: https://thermos.com/collections/beverag ... ottle-16oz
Stainless steel, with a plastic lid. Slim enough that it fits in most cupholders I've seen. I can fill it with boiling hot beverage at the beginning of a ski day, leave it outside in sub-zero, and it's just cool enough to sip at lunch, and then finlly drink without problems by 3 or 4 pm.
Happiness is V1 at Thompson!
albertdesalvo
DanWEC wrote: Mon Jul 04, 2022 11:43 amhttps://thermos.com/collections/mugs-tu ... g-mug-16oz
Found it, ordered from Amazon, it'll be here tomorrow. Thanks Dan. :goodman:
albertdesalvo
North Shore wrote: Mon Jul 04, 2022 12:09 pmI'll second the Thermos brand. I use one of the tumblers instead:
I liked the look of that one, so I ordered one of those too. Thanks NS. :mrgreen:
albertdesalvo
Pfft wrote: Sun Jul 03, 2022 9:10 pmGsi Microlite. Thin, fits every cupholder without pulling it out. . . stays hot for too long.
Also ordered one of these (they were on sale, couldn't resist). Thanks Pfft.
While you're in the 'buy it now' mode, you should perhaps consider these:
https://www.aircraftspruce.ca/pages/p ... ljohn.php
Seems like you're going to be drinking so much coffee you'll need them! :lol:
I'm happy with Contigo, there's a large version I found at Walmart that holds a Large Timmy's/ McD's coffee perfectly. Problem is it fits the 737 cup holder a little too tightly and frequently the liner sticks to the bottom of your mug. apparently that liner is $250 from Boeing as guys keep accidentally putting their cup away in their bags with the liner still attached.
albertdesalvo
North Shore wrote: Tue Jul 05, 2022 6:33 amSeems like you're going to be drinking so much coffee you'll need them! :lol:
Ha ha, I didn't have to click, the URL gave it away. Handy product to have around. :)
I'm not that much of a coffee fan, I figure I'll check em all out, choose the best one for myself, and give the others away. It's something everyone can use, after all.
DanWEC
Post by DanWEC »
albertdesalvo wrote: Thu Jul 07, 2022 4:53 pm
Please tell me you're talking about the mugs.
albertdesalvo
Errm, yes indeedy. Not sure how people would react if gifted a TravelJohn :rolleyes:
mantogasrsrwy
Post by mantogasrsrwy »
Is your airline's coffee so bad that your have to bring cofffee with you? My insulated coffee mug is for the drive in. After that I can deal with what the passengers are served.
DanWEC
Post by DanWEC »
Unless you work for Avianca, then yes.
Also your coffee has a little poop in it probably.... And yet I drink it too as the warmup before approach because the thermos is long gone....
Jimmy_Hoffa
mantogasrsrwy wrote: Thu Jul 07, 2022 8:00 pm Is your airline's coffee so bad that your have to bring cofffee with you? My insulated coffee mug is for the drive in. After that I can deal with what the passengers are served.
Talk to your mechanics about when they clean the potable water tank… instant convert for life.
Jimmy_Hoffa wrote: Fri Jul 08, 2022 3:18 pm
I figure that's why Boeing makes the water come out at 130 degrees C. To kill whatever grew in there during the 2 years all the Max's were parked.
