Should Air Canada be nationalized
WellThatAgedWell
https://canadiandimension.com/articles/ ... air-canada
Above is an opinion piece. Weak arguments but fun to entertain anyways.
What would jobs look like at Air Canada if this were to happen? Would service improve? Would it be profitable? Would it better serve the public?
Re: Should Air Canada be nationalized
https://www.google.com/amp/s/www.cbc.ca/amp/1.6389874
This is what happens when the government gets involved
- PeterParker
Let's also nationalize Nav Canada while we're at it. Nav Canada is a gong show to the point that I feel that we're going to see airplanes fall out of the sky due to an utter and complete lack of staffing within Canada's ATC system...
Also, for everyone in here who will invariably come out to argue how privatization will make things better - show me how Nav Canada is supposedly better than the FAA's ATC system?
We should contract or cede control of our entire air system to the FAA, boot Transport, Nav Canada, CATSA, GTAA, etc. - the whole lot of them. Complete integration from agency mandate to licensing to flight time rules to air traffic to airport priorities.
TFTMB heavy
CPDLC has launched in several US centres. The infrastructure is there nationwide. No doubt we will see national KUSA coverage soon.
We asked a US controller one day when theirs would be on line for Canadian aircraft, the response was “you will be able to once you guys are caught up!”
DHC-1 Jockey
If you've been following the ATC FAA subreddit, you know that things aren't any better in the FAA. Their staffing is at critical levels much the same way NavCanada is.PeterParker wrote: ↑Fri Jul 15, 2022 10:02 pm Let's also nationalize Nav Canada while we're at it. Nav Canada is a gong show to the point that I feel that we're going to see airplanes fall out of the sky due to an utter and complete lack of staffing within Canada's ATC system...
And for the technology, NavCanada has the FAA beat hands down. When they come visit, FAA controllers are amazed at the technology NavCanada is using. I believe some FAA sites are still using old-school paper strips that get sent from one sector to another by vacuum tube the way it was done in the 60's.
newlygrounded
Try to call or email TC then then a fsdo. See who replies first?DHC-1 Jockey wrote: ↑Sat Jul 16, 2022 10:15 amIf you've been following the ATC FAA subreddit, you know that things aren't any better in the FAA. Their staffing is at critical levels much the same way NavCanada is.PeterParker wrote: ↑Fri Jul 15, 2022 10:02 pm Let's also nationalize Nav Canada while we're at it. Nav Canada is a gong show to the point that I feel that we're going to see airplanes fall out of the sky due to an utter and complete lack of staffing within Canada's ATC system...
alkaseltzer
Nationalize the airport authorities and ATC.
Much better for the end customer.
You mean reverse everything the Feds have done over the past 25 years?alkaseltzer wrote: ↑Sat Jul 16, 2022 10:52 am Nationalize the airport authorities and ATC.
Oh the FSDO does respond quickly. Unfortunately they tell you nobody is back in the office due to covid and you need to work through a third party $$$ to have your issue addressed!newlygrounded wrote: ↑Sat Jul 16, 2022 10:44 amTry to call or email TC then then a fsdo. See who replies first?DHC-1 Jockey wrote: ↑Sat Jul 16, 2022 10:15 amIf you've been following the ATC FAA subreddit, you know that things aren't any better in the FAA. Their staffing is at critical levels much the same way NavCanada is.PeterParker wrote: ↑Fri Jul 15, 2022 10:02 pm Let's also nationalize Nav Canada while we're at it. Nav Canada is a gong show to the point that I feel that we're going to see airplanes fall out of the sky due to an utter and complete lack of staffing within Canada's ATC system...
If it takes Transport Canada sixteen months to issue a Category 1 medical, what makes you think they're going to get you through customs any faster than the GTAA?
- schnitzel2k3
Gotta be honest, whatever they (FAA) are using for weather is way better than Canada. I feel a lot more confident getting vectors from the Americans in terminal airspace, vs Canadian controllers who repeatedly vector into significant weather.DHC-1 Jockey wrote: ↑Sat Jul 16, 2022 10:15 amIf you've been following the ATC FAA subreddit, you know that things aren't any better in the FAA. Their staffing is at critical levels much the same way NavCanada is.PeterParker wrote: ↑Fri Jul 15, 2022 10:02 pm Let's also nationalize Nav Canada while we're at it. Nav Canada is a gong show to the point that I feel that we're going to see airplanes fall out of the sky due to an utter and complete lack of staffing within Canada's ATC system...
100%schnitzel2k3 wrote: ↑Sat Jul 16, 2022 4:36 pmGotta be honest, whatever they (FAA) are using for weather is way better than Canada. I feel a lot more confident getting vectors from the Americans in terminal airspace, vs Canadian controllers who repeatedly vector into significant weather.DHC-1 Jockey wrote: ↑Sat Jul 16, 2022 10:15 amIf you've been following the ATC FAA subreddit, you know that things aren't any better in the FAA. Their staffing is at critical levels much the same way NavCanada is.PeterParker wrote: ↑Fri Jul 15, 2022 10:02 pm Let's also nationalize Nav Canada while we're at it. Nav Canada is a gong show to the point that I feel that we're going to see airplanes fall out of the sky due to an utter and complete lack of staffing within Canada's ATC system...
newlygrounded
Hasn't been my experience. See what the others said about ATC vectors tooJHR wrote: ↑Sat Jul 16, 2022 3:09 pmOh the FSDO does respond quickly. Unfortunately they tell you nobody is back in the office due to covid and you need to work through a third party $$$ to have your issue addressed!newlygrounded wrote: ↑Sat Jul 16, 2022 10:44 amTry to call or email TC then then a fsdo. See who replies first?DHC-1 Jockey wrote: ↑Sat Jul 16, 2022 10:15 am
Two words: Descend Via,...PeterParker wrote: ↑Fri Jul 15, 2022 10:02 pm Let's also nationalize Nav Canada while we're at it. Nav Canada is a gong show to the point that I feel that we're going to see airplanes fall out of the sky due to an utter and complete lack of staffing within Canada's ATC system...
I must have made it up then...newlygrounded wrote: ↑Sun Jul 17, 2022 4:55 pmHasn't been my experience. See what the others said about ATC vectors tooJHR wrote: ↑Sat Jul 16, 2022 3:09 pmOh the FSDO does respond quickly. Unfortunately they tell you nobody is back in the office due to covid and you need to work through a third party $$$ to have your issue addressed!newlygrounded wrote: ↑Sat Jul 16, 2022 10:44 am
alkaseltzer
Gaslighted question. What have the feds done to be reversed?rudder wrote: ↑Sat Jul 16, 2022 12:37 pmYou mean reverse everything the Feds have done over the past 25 years?alkaseltzer wrote: ↑Sat Jul 16, 2022 10:52 am Nationalize the airport authorities and ATC.
alkaseltzer
You must have some pre-existing conditions.
1996 - privatized airports and NavCan.alkaseltzer wrote: ↑Mon Jul 18, 2022 10:28 amGaslighted question. What have the feds done to be reversed?rudder wrote: ↑Sat Jul 16, 2022 12:37 pmYou mean reverse everything the Feds have done over the past 25 years?alkaseltzer wrote: ↑Sat Jul 16, 2022 10:52 am Nationalize the airport authorities and ATC.
alkaseltzer
Misunderstood my question…I’ll rephrase. In todays climate, what would be better for Nav Can and airport authorities to be able to continue gouging passenger livelihoods and wallets? Compared to re-nationalizing them?
When do the fat cats finally get kicked out from running these enterprises inefficiently? It is Canada after all, and we have an extremely high tolerance for bureaucracy.
Pre-existing conditions or clean bill of health for a newly issued Cat 1, TC turnaround times are down right awful at the moment.alkaseltzer wrote: ↑Mon Jul 18, 2022 10:30 amYou must have some pre-existing conditions.
https://nationalpost.com/news/canada/co ... DwMYNzvKbo
thenoflyzone
Only 1 guy answered the OP's question, and the rest of the thread turned into a rant against NavCan. Why am I not surprised.
Service wouldn't improve.
Profitable? Hell no....(alitalia, Air india are but a few examples of mismanaged government owned airlines)
Would it better serve the public? Debatable. Subsidizing underserved routes would be a better strategy I think.
Also, if you want pilot pay to increase, nationalization isn't the way.
If privatizing the gains and making the losses public is a problem, then the solution isn't to un-privatize the gains. It's to stop using public funds to bail out the company. Period.
I don't think nationalization will be better for anyone really. To answer your questions directly....WellThatAgedWell wrote: ↑Fri Jul 15, 2022 7:41 pm https://canadiandimension.com/articles/ ... air-canada
Let's just remove the border and get annexed by the U.S while were at it..
I guess you better stop flying right now then....What a stupid comment to make.PeterParker wrote: ↑Fri Jul 15, 2022 10:02 pm Let's also nationalize Nav Canada while we're at it. Nav Canada is a gong show to the point that I feel that we're going to see airplanes fall out of the sky due to an utter and complete lack of staffing within Canada's ATC system...
