cleared to 'blah blah' via radar vectors
heeypilot
Post by heeypilot »
got a question.. say you're flying your flight planned route, and somewhere during the flight ATC says 'you're not cleared to AIRPORT via radar vectors, fly heading blah blah blah'..
so say you fly the assigned heading, and you get a comm failure 15 minutes later..
what are you expected to do?
heeypilot
Post by heeypilot »
by 'not cleared' i mean 'now cleared'
oops
Bede
Post by Bede »
Fly direct the FAF, land. I know the book says hold until ETA, but if you squak 7600, the airspace will be cleared for you regardless. There is no use holding up traffic by doing a hold.
trey kule
Post by trey kule »
If I can add my two cents. One of the concerns we have always had is that when you are being radar vectored you might well be below the minimum safe altitude. So. As well as procedure I think it is important to make sure you are at a safe altitude and climb if required.
I have talked to the ATC folks about this and they advise that in these situations they will clear out the area and see what you are doing.
Maybe someone from ATC could confirm my understanding of this.
Pygmie
Post by Pygmie »
What has been said is correct. If below the safe altitude, climb to it. Proceed to either the point at which you were being vectored, the point from which you can carry out the instrument approach, or if no point was specified (i.e. vectors for traffic. . .) proceed direct the next fix on your route.
jetav8r
Post by jetav8r »
Climb to sector, go director
ettw
Post by ettw »
Ah yes, JM's favourite expresion
wsguy
Post by wsguy »
Absolutely!!!! :arrow: Good Ole Johnny boy!
N8
Post by N8 »
I would also like to add, if VMC, continue VFR.
privateer
Post by privateer »
I think JM holds the floor on this one.
catan man
Post by catan man »
Climb to sector, go director. I love it!!! That's keepin' it simple.
Out of Control
Post by Out of Control »
grab your cell phone
Say again, your coming in stupid
