One-Days at Air Transat
Discuss topics related to Air Transat.
goingmissed
Post by goingmissed »
Are they available? I assume that bidding is seniority based, so with that assumption, how senior of an FO do you need to be to hold single day pairings?
TIA
TFTMB heavy
Re: One-Days at Air Transat
Post by TFTMB heavy »
Not very, a lot of more jr pilots try to get longer pairing for per diems or because they commute.
Tbayer2021
Post by Tbayer2021 »
TFTMB heavy wrote: Fri Aug 05, 2022 7:06 am Not very, a lot of more jr pilots try to get longer pairing for per diems or because they commute.
You mean to say most Southern destinations are layovers. Or how does it work?
TFTMB heavy
Tbayer2021 wrote: Fri Aug 05, 2022 8:47 am
You asked if one-days are easy to get and how senior you need to be to get them. The answer is not very senior. Many bid for per diems to supplement income or because they commute.
There are no layovers down South these days. Lots of turns, some domestic layovers and Europe.
Latitude
Post by Latitude »
If you’re looking for single day pairings you can bid for them and will definitely have them. It’s mostly junior.
garfield
Post by garfield »
Single day pairings out off YYZ I guess, other bases are quite senior
TFTMB heavy
garfield wrote: Mon Aug 08, 2022 9:02 am Single day pairings out off YYZ I guess, other bases are quite senior
YUL has the most senior pilots but also is very junior on the bottom end and they are growing the base and there were a lot of transfers. YVR has not had any growth in years.
averageatbest
Post by averageatbest »
Does anyone have a pairing list for Air Transat? It would be nice to see what pairings are being offered.
TFTMB heavy
averageatbest wrote: Fri Oct 28, 2022 10:14 am Does anyone have a pairing list for Air Transat? It would be nice to see what pairings are being offered.
It varies wildly per season, this time of year is not a great example. Anything from 1 day to 6 days.
flyinhigh
Post by flyinhigh »
Releasing that company document would go against any companies policies. On top of that, they change every month like every other company.
Return to “Air Transat”
