grumman goose accident ?
- oldncold
rumor mill is abuzz that a grumman goose with fisherman was involved in a accident up knight or toba inlet on this august long weekend resulting in the aircraft being upside down. unconfirmed report says all pax ok
Re: grumman goose accident ?
I can’t think of a more misleading thread title…
When did a Fireboss owned by ConAir ever get called a Grumman Goose?
- oldncold
you should read the topic title closer eh posted 2 seperate incidents n if you know yur geography cranbrook n toba or knight inlet are signicantly far apart. so before you flame anyone on this site going forward, engage the noodle attached to the shoulders . it will save you from being a dumbass
Well said, yerself there.oldncold wrote: ↑Fri Aug 05, 2022 8:44 am you should read the topic title closer eh posted 2 seperate incidents n if you know yur geography cranbrook n toba or knight inlet are signicantly far apart. so before you flame anyone on this site going forward, engage the noodle attached to the shoulders . it will save you from being a dumbass
oldncold,oldncold wrote: ↑Fri Aug 05, 2022 8:44 am you should read the topic title closer eh posted 2 seperate incidents n if you know yur geography cranbrook n toba or knight inlet are signicantly far apart. so before you flame anyone on this site going forward, engage the noodle attached to the shoulders . it will save you from being a dumbass
You edited your original post on this thread AFTER posting.
If my making that clear offended you, perhaps you should look inwardly as most of your posts over the years have many errors and I am not the first one to have given you a good ribbing on this forum.
Take a pill bud. (Thanks for the geography lesson. I’ve flown extensively into those inlets. Thankfully I never got lost!)
TPC
Forgot the plugs and she sank…. Slow-mo accident
Are they easy to see on the walkaround?
C-GDDJ, a Wilderness Seaplanes Grumman G21A (Goose), was conducting a passenger flight
from Walbran Island, BC, (17 nautical miles southwest of Rivers Inlet [CAU8]) to Port Hardy
(CYZT), BC, with the pilot and 8 passengers on board. After the aircraft began to taxi on the water
for departure, the right wing float appeared to have lost buoyancy. The pilot maneuvered for
another minute in an attempt to raise the float. Unable to raise the float, the pilot attempted a turn
to return to the dock. During the turn, the right propeller struck the water and the pilot saw the right
wing was sinking. He immediately shut down the engines and told the passengers to evacuate.
The pilot assisted the passengers in exiting from the left rear emergency exit and the left side
cockpit window; the right side exits were submerged. Boats from a nearby fishing lodge arrived to
help and took the passengers on board. One passenger received minor injuries during the egress
from the aircraft but there were no other injuries. All the passengers had been wearing PFD's, two
passengers inflated them once out of the aircraft. The aircraft rolled inverted in the water and
floated on the surface.
Once recovered, an inspection found three float plugs for the right wing float were missing which
allowed the float to fill with water.
