DEC Jazz
Tbayer2021
Re: DEC Jazz
Post by Tbayer2021 »
airway wrote: Fri Sep 02, 2022 6:33 am
Loon-A-Tic wrote: Fri Sep 02, 2022 4:54 am
FL030 wrote: Thu Sep 01, 2022 4:09 pm
No longer any hour requirements I see.
Valid Transport Canada Instrument Rating.
Valid Airline Transport Pilots License.
Valid Transport Canada Multi Engine rating.
Valid Transport Canada Class 1 Medical.
Must be able to obtain a Restricted Area Identity Card (RAIC).
Must hold a current passport at time of hire.
If you are a Permanent Resident, you must be able to obtain and maintain crew visa documentation required to operate aircraft within the USA.
Must be legally entitled to work in Canada.
Must have completed a High School diploma.
Candidates must meet Transport Canada English proficiency standard.
Hiring Minimums for Direct Entry Captain is an ATPL with a preference for 705 level Pilot In Command experience as an asset.
Doesn't the last requirement essentially dictate time required owing to the ATPL reference !!
"Hiring Minimums for Direct Entry Captain is an ATPL with a preference for 705 level Pilot In Command experience as an asset."
Having a ATPL has always been required at Jazz in order to upgrade.
An ATPL is not a company requirement, it's a CAR's requirement to act as PIC on any transport category aircraft. Anyone wanting to upgrade and not aware of this should rethink their desire to be a Captain.
rudder
Re: DEC Jazz
Post by rudder »
Tbayer2021 wrote: Fri Sep 02, 2022 8:55 am
If you don’t have an ATPL You will not be interviewing for a DEC position. Once on line (or on a PIT course), you will not be awarded a CA position (opportunity to qualify) without a valid ATPL on file with the company.
If you do not know that am ATPL is required for CA in a Part 705 operation then you have no business worrying about the DEC process. You need to go back and hit the books.
Tbayer2021
Re: DEC Jazz
rudder wrote: Fri Sep 02, 2022 9:16 am
Are there some out there actually expecting to be awarded the left seat without meeting the bare minimum legal requirement?
rudder
Re: DEC Jazz
Post by rudder »
Tbayer2021 wrote: Fri Sep 02, 2022 9:31 am
Likely not. The bid would be ignored anyway.
But there are some that meet minimum licensing qualifications (but with zero relevant experience for DEC at a 705 operation) that are permitted to attempt to qualify as CA.
Most other operators have an experience matrix. Jazz does not.
negative_g
Re: DEC Jazz
Post by negative_g »
I heard there's big delays getting your ATPL signed off with TC. Probably causing issues not just at Jazz but 703/704 as well for upgrading.
QKZXKV
Location: Nickelbelt/Concrete Jungle/Lobster country...
Re: DEC Jazz
Post by QKZXKV »
negative_g wrote: Fri Sep 02, 2022 6:45 pm I heard there's big delays getting your ATPL signed off with TC. Probably causing issues not just at Jazz but 703/704 as well for upgrading.
That's if the candidates sit around and let TC take their time. Squeak wheel gets the grease!
Caterpillar
Re: DEC Jazz
Post by Caterpillar »
Most 703/704 COMs don't require captain to have ATPL. You mostly require ATPL to be a training captain.
Some companies will require ATPL for insurance/experience/etc... I can only assume everything is been changing since Encore/Flair/Jazz/Porter is emptying the pool of ATPL.
Since I’m flying the King Air, does that qualify me to fly the Queen of the skies?
short bus
Re: DEC Jazz
Post by short bus »
^ the above is very wrong information
RockSalty
Re: DEC Jazz
Post by RockSalty »
Caterpillar wrote: Wed Sep 14, 2022 1:34 pm
Plenty of medevac operators require an ATPL for their captains since thats what the province normally wants. What I've started to see happen instead of requirements going down is pay going up at a few of them to try and stop us from leaving.
Bluewaffe
Re: DEC Jazz
Post by Bluewaffe »
Any update on how the DEC candidates are doing? I heard theres a 10% passing rate?
kiaszceski
Re: DEC Jazz
Post by kiaszceski »
Maybe just ask the training department?
fixnfly
Re: DEC Jazz
Post by fixnfly »
Bluewaffe wrote: Tue Oct 25, 2022 4:31 pm Any update on how the DEC candidates are doing? I heard theres a 10% passing rate?
To be fair, a good number of them were flight instructors with fresh atpl’s, so you can’t really expect them to have the decision making skills to go DEC on the RJ flying to some of the busiest airports along the eastern seaboard. I guess it goes to show the quality of DECs that Jazz is hiring at the moment
Ash Ketchum
Re: DEC Jazz
Post by Ash Ketchum »
fixnfly wrote: Thu Oct 27, 2022 12:50 am
I had no idea the pass rate was that low. I guess it's hard to attract experienced candidates with the pay Jazz is offering first year Captains.
Outlaw58
Re: DEC Jazz
Post by Outlaw58 »
Ash Ketchum wrote: Thu Oct 27, 2022 4:21 am
You still don't have any idea what the pass rate is.
Someone saying "he heard" it was 10% does not make it so. Comment on facts please.
58
kiaszceski
Re: DEC Jazz
For context, the Encore pass rate is a bit above 50% with people having 500 hrs on a 705 and 2000 hrs minimum.
If the DEC are flight instructors the 10% aren't surprising.
That being said, Jazz rescinded the Pilots ad.
FO ad: minimums are CPL+ IATRA + 750 hrs
DEC ad: ATPL, preferred 3000 hours total time, 1000 hours multi-engine turbine time and at least 500 of command time on a multi-engine aircraft.
rob-air
Re: DEC Jazz
Post by rob-air »
An instructors shooting for DEC shows a lack of understanding what they are trying out for. they should go fo, ease through training, put CA in the standing bid on the plane they are training on and get a training date in the spring.
daedalusx
Re: DEC Jazz
Post by daedalusx »
It’s down right dangerous to put a 1500 hr Instructor on the left seat of a 705 plane. What the hell were they thinking ?
No experience dealing with busy ATC, high op tempo down in the USA
No experience dealing with deicing and ramp operations.
No experience dealing with NPA with high terrain out West
No experience dealing with shitty contaminated short runways and crosswind.
No experience dealing with wind shear and stormy WX around the Great Lakes and the maritimes.
That fact that a 1500hr instructor would even apply for this position shows how utterly clueless they are. Imagine that paired with a 250 hr wonder cadet on their first pairing post line Indoc going to YYF landing RYW 34 at night on a bad winter night or during the forest fire season.
Truly the definition of the blind leading the blind.
“Oh but they’re really good at memorizing the COM” :shock:
Canadaflyer46
Re: DEC Jazz
Post by Canadaflyer46 »
daedalusx wrote: Thu Oct 27, 2022 1:25 pm It’s down right dangerous to put a 1500 hr Instructor on the left seat of a 705 plane. What the hell were they thinking ?
What’s scary is this the direction airlines are taking in Canada, as opposed to increasing pay to attract experienced candidates.
Unfortunately we all know the only thing that will change this strategy. It’s sad to say but it will cost some lives before they start putting safety ahead of profits here.
Look at the accident record go to basically zero in the US since the 1500 rule was implemented. Experience in the flight deck is important. Just not a concern to airline execs until it’s mandated.
FL007
Re: DEC Jazz
Post by FL007 »
In some cases, no experience flying IMC.
QKZXKV
Re: DEC Jazz
Post by QKZXKV »
Bertollag wrote: Mon Aug 08, 2022 2:50 pm Hi Everyone,
I have a question about the DEC positions at Jazz. Do you think it is a good move starting as a captain when you don’t know the company, the aircraft, the routes… do you think being FO for a couple of months really makes a difference to learn the stuff or the DEC position is fine ?
Thank you very much !
I would never want to be DEC and on a 1 yr probationary period. I'd say 1 yr minimum on property and on type before CA.
