Helicopter Accidentally Drops Load Thread
This seems to happen every once in a while just in Canada. Not sure if it is due to poor design making it easier to happen than it should be or otherwise......
C-GFQP, a Bell 212 helicopter operated by Canadian Helicopters Limited, was slinging a diesel
electric generator at a radar site located 43 nm SSW of Igloolik (CYGT), NU with only the pilot on
board. While manoeuvering at approximately 1700 feet, the pilot unintentionally activated the load
release switch and the load dropped. The pilot was able to maintain control of the helicopter and
then landed safely. There were no injuries and the helicopter did not sustain any damage.
mmm..bacon
Re: Helicopter Accidentally Drops Load
Re: Helicopter Accidentally Drops Load Thread
From the TSB.....
The Synergy Aviation Ltd Robinson R44II, C-FZQX, was departing Villeneuve Airport (CZVL), AB
on a flight to Swan Hills (CEM5), AB with an apparatus containing a gas leak detector and a
thermal camera attached to the cargo hook. The helicopter was cleared to the north, transiting over
Taxiway Bravo, when a noise was heard from the rear seat area. Shortly thereafter Villeneuve
Tower called to inform the crew that something had fallen from the aircraft, and it was laying on
Taxiway Bravo. The flight crew requested a return and landed midfield to investigate. It was
determined that the detection unit had fallen from the aircraft. Both flight crew confirmed that the
manual release had not been activated during the departure. There was no damage to the
helicopter or the detection assembly.
Maintenance update: Upon further investigation it was determined that the cargo was not faulty;
however, it was found that the manual release handle was not in the fully down position and may
have allowed the hook to open due to vibration.
From TSB....
C-GAQT, a Bell 407 aircraft operated by Canadian Helicopters Limited, was conducting external
load operations at Hope Bay (CHB3), NU. Two external water bladders were slung through the
eyelets of the bladders and hooked up to the cable connected to the helicopter. Shortly after
departing, one of the bladders ripped through the eyelets and fell to the ground. There was no
injury, and no damage to the aircraft or to the environment.
From TSB via Google Translate...
C-GCWW, an Aerospatiale AS 350 B-2 operated by Canadian Helicopters Limited was conducting a flight
transport of cargo under long sling according to visual flight rules from the airport of
Sept-Îles (CYZV), QC to an outfitter located approximately 28nm north of CYZV. At
moment to lift the load, for an unknown reason, the hook of the sling located under
the device opened and the sling fell to the ground near the hook. The cause of the opening
is the subject of an investigation by the operator. There were no injuries.
From TSB....
C-FGAV, a Bell 407 helicopter operated by Custom Helicopters Ltd, was conducting an external
load flight from a camp located approximately 20nm northeast of Rankin Inlet (CYRT), NU. The
external load (a tent floor) was lifted and when the helicopter was at approximately 200 feet AGL
and at an airspeed of 10-20 knots, the external load was flying erratically. The pilot intentionally
released the long line and the load fell to the ground in an open area away from the ground crew.
The pilot then landed the helicopter and shut down without further incident.
The operator inspected the long line and cargo hook, and no anomalies or damage were noted.
C-FVHW, a Valley Helicopters Ltd. Bell 206L-4 (LongRanger IV) helicopter, was conducting
longline operations under visual flight rules 12 nautical miles east-northeast of Hope Airport
(CYHE), BC, with one pilot on board. At 1000 PDT, while operating at 400 feet above ground level,
the pilot inadvertently pushed the longline cargo release button. The slung load of trees was
released from the longline. The released external load landed in a heavily forested area. There
were no reported injuries. There was no damage to the aircraft or to property.
Happens all the time. What we really need to know is how close was the nearest school bus full of elementary students.
Date Entered: 2023-10-19
Narrative: Nanaimo Airport Security reported a member of the public phoned to report they had seen a helicopter lose a load of metal sheets into the ocean just north of Thetis Island. A Kestrel Helicopters Aerospatiale AS 350 B-2 (C-GKHX) confirmed it was them and they were looking into what had happened. Coast Guard advised the flight service station (FSS) no pollution report required.
Aerial work, you can't fly over built up areas or people. This mitigates risk to the public. Some aircraft have a terrible set up IMO for emergency release buttons location. The biggest failing i've seen is how companies treat lifting gear, everything below the belly hook is not certified. Remote hooks get treated like shit and rarely if ever get maintenance unless it fails, same with Long Lines, no tracking of use or inspections records. Pilot field serviceable is considered acceptable for some reason. Some companies try, but when it comes ops gear very little is actually maintained that well. Compared to how cranes are maintained, heli companies fall way short.
From TSB....
C-GCIV, a Transport Canada Bell 429 helicopter departed Port Hardy Airport (CYZT), BC, as flight
CTG435 under visual flight rules to Scarlett Point (CBJ7), BC, with only the pilot on board. The
helicopter was helislinging a load consisting of a bundle of rebar and a white bag containing 300
pounds of steel mounting brackets which was attached and suspended below the bundle of rebar.
Approximately 1 nautical mile SE of Scarlett Point, ground personnel heard a splash and when the
helicopter arrived at Scarlett Point, the white bag was empty. There were no injuries; the helicopter
was not damaged.
was not damaged.
itsgrosswhatinet
Transport Canada longlines scrap rebar?
Safety starts with two
Seems to happen more often than one might expect...
C-FCHE, a Bell 205A-1 helicopter being operated by Custom Helicopters Ltd., was performing
water bucketing drops at a forest fire located 12 NM south of Snow Lake, MB. The aircraft had
previously performed 21 water bucket drops. On the 22nd drop, while slowing to position for the
target area, the water bucket released from the cargo hook. The pilot returned to base and the
aircraft was inspected. The water bucket fell into an unpopulated area and has not been recovered.
The operator's maintenance determined that interference between the electrical cord and the
manual release on the hook caused an inadvertent release of the water bucket. The cargo hook
was inspected, and no faults were found. The electrical cord was repositioned, and the aircraft
continued to perform water drops on the fire with another water bucket.
...from TSB.
...from TSB.
From TSB...
C-GFQP, a Bell 212 HP helicopter operated by Canadian Helicopters Limited, was conducting external load operations 129 NM NNE of Goose Bay, NL (53.55°N, 56.83°W), with 1 crew member on board. The helicopter was slinging a load of roof sheeting when, approximately three minutes after departure, the long line cable detached, and the load fell to the ground. No injuries were reported, and there was no damage to the aircraft or surrounding property. Maintenance action: a post-occurrence inspection determined that the manual release was not properly rigged. The system was set too tight, with insufficient slack when in the closed and locked position. As a result, the manual release was partially pulled open even while at rest, potentially leading to an uncommanded release of the sling load.
Based on the rate of events, it is obviously more risky than I might have thought to be underneath a helicopter slinging a load.
From TSB.....
C-GTHU, a Summit Helicopters Limited Bell 407 helicopter, was conducting helicopter slinging
operations in the vicinity of Bronson Creek Airstrip, BC, with only the pilot on board. While moving
a load of core samples on a long line, the pilot inadvertently pressed the load release button
located on the cyclic control. The long line and load released from the helicopter belly hook and
landed in the nearby Iskut River. The long line was not located. There were no injuries or damage
to the aircraft or property.
From TSB.....
From TSB...
C-GHOA, an Airbus Helicopters AS 350 B3 operated by Hydro One Networks Inc. was conducting
powerline work in Island Falls, ON, at approximately 32 NM NNW of Cochrane Aerodrome
(CYCN), ON. While slinging a crossarm onto a two-pole powerline, the pilot experienced an
unintentional release of the load from the remote hook. As the crossarm was being lowered
through the phase conductors, it became caught on the middle phase. While the pilot was holding
the load in position, awaiting the lineman to reach the end of the arm, the load unexpectedly
detached from the remote hook and fell to the ground. No injuries were reported.
From TSB...
C-GCHZ, a Custom Helicopters Bell 206L, was conducting a sling load flight from a staging area 9 nautical miles (NM) northwest of Whale Cove Airport (CYXN), NU, to BG Gold camp, 22 NM westnorthwest of the staging area. The aircraft had a 100-foot longline attached, and a 650-pound toolbox attached with 2 straps. At 1800 CST approximately 10 NM into the trip, the toolbox slipped out of the straps and fell approximately 1000 feet to the ground. There were no personnel injuries or damage to the aircraft.
From TSB...
C-GCUQ, a Government of Canada, Department of Transportation Bell 412EP helicopter, departed Prince Rupert/Seal Cove (Coast Guard) Heliport (CBY5), BC, on flight CTG948, under visual flight rules, to Maitland Island (53° 44' 05" N, 128° 56' 02" W), BC, with 1 flight crew member on board. The helicopter was carrying a slung basket of construction materials. During the initial climb at an airspeed of approximately 60 knots, the pilot observed that the slung basket was oscillating and beginning to spin. The pilot elected to return to CBY5 to rectify the load. On short final, part of the load exited the basket. After landing, it was reported that additional parts of the load had exited the basket undetected during the departure. The load had been inspected prior to takeoff with nothing abnormal noted. No injuries or damage was reported. The flight was conducted over an unoccupied forest and water. A vessel was dispatched to look for the debris that splashed down on short final.
From TSB...
C-GJIX, an Airbus Helicopters AS 350 B-2 aircraft operated by Custom Helicopters Ltd., was conducting local external load wildfire fighting operations from Goose Bay Airport (CYYR), NL. The helicopter departed the company hangar at CYYR and crossed Runway 15/33 heading south with a slung long line and Bambi Bucket attached. The helicopter was in the departure climb below 500 feet above ground when the long line and bucket detached. The slung load fell in the CYYR airport midfield, and no persons or structures were in the area where the load fell. The minor damage to the bucket from the unintentional release was repaired. A full inspection and test of the external hook, long line and bucket was conducted with no faults found. It is considered that the external load was not adequately secured before the departure on the occurrence flight.
From TSB...
C-FQNG, a VIH Helicopters Limited Sikorsky S-61N, was conducting heli-logging operations with a
longline and grapple approximately 72 nautical miles northwest of Tofino-Long Beach Airport
(CYAZ), BC, with 2 flight crew members on board. While in flight, the aircraft suffered an
uncommanded release of the longline assembly and grapple. The equipment fell into a forested
area. There were no injuries reported and the aircraft was not damaged.
A maintenance inspection was conducted after the longline assembly and grapple were recovered.
Cotter pins in the manual release assembly were found to be worn and that was determined to be
the cause of the release.
From TSB....
C-GFAT, a Kootenay Valley Helicopters Limited Sikorsky 61N helicopter was conducting slinging
operations 18 nautical mile south-southwest of Port Alberni (Alberni Valley Regional) Aerodrome
(CBS8), BC. During the 8th lift of the second flight of the day, the belly hook released while
airborne and the line, grapple, and logs were dropped. There were no injuries or damage reported.
The hook was removed for inspection and another hook was installed.
