https://www.flyingmag.com/1-dead-9-miss ... MzMzOTAyS0
https://twitter.com/flightradar24/statu ... 20220904-1
geodoc wrote: ↑Mon Sep 05, 2022 2:47 pm Operated by NW Seaplane, not Kenmore Air. Looks like a GE / Walter engine'd machine. Very high rate of decent before impact per FlightRadar24. Bummer.
This Otter was serial # 466 the last one built. It’s former Canadian registration was VQD. It was operated at various times out of Red Lake, Lac Dubonnet, Whitehorse , and Prince Rupert.
AP
Reading a bit about the AD that applies. It appears that the initial AD was released that required an additional push / pull rod on the servo tab (not the flap system connected tab) applicable to the Vazar (PT6), Garrett, GE / Walter and PZL recip STC'd aircraft. Later it appears that that requirement was dropped on the Garrett and GE / Walter STC'd aircraft. At least this is what it seems from what I can glean from a perusal of internet available info. Is there an AME or other person knowledgeable about this AD and its history that an chime in with the straight skinny?FishermanIvan wrote: ↑Fri Sep 09, 2022 8:22 pm Dan Gryder is a fucking idiot, but it's hard to disagree with him.
There's a reason why Canadian Otters have two linkages on the trim tab.
It would probably depend on whether the Walther STC / installation was accomplished before or after it was exported to the US. Also whether it was installed in either Canada or the US whether the version of the AD was current that rescinded the requirement for incorporating the 2nd servo tab push pull rod on Walter engine STC's. At least that's the way I read it.
There is lots of solid aircraft out there but fatigue is fatigue and these are old airframes that are getting pushed harder than every with the power of the engines. The blue water crash in Manitoba where the wing folded up is another example.T-bag wrote: ↑Sun Sep 18, 2022 7:12 am I was flying a DeHaviland product that same day within 20nm of N725TH’s flight path only 30 minutes before the incident. We had delayed our flight for an hour due to wx (low vis). The vis around 1:30 was 4 sm in mist. But worse along route to Vancouver. Port Angele was similar. I’m not convinced it was mechanical but I’ve never flown the Walter version. But I do agree with the feelings about Dan Gryder. What a Wanker.
Looks like AD 2004-05-01 only applied to the Lurton install (P&W). Probably because there was more of them operating and TC and the FAA had more info on them. Also I heard the Texas turbine has a different thrust line angle resulting in less to no buffeting on the tail. Plus the prop spins slower having a lesser impact on the tail. As you can see. Not every Turbine Otter is the same. I’m no expert but with over 10,000 hours in Single Otters on floats I reckon it’s a solid aircraft. Well at least the ones we fly.
