Vancouver, British Colombia, 2 November 2022 — Today, the Transportation Safety Board of Canada (TSB) released its investigation report (A22P0019) into the 16 March 2022 tail rotor strike and roll over involving an AS350 B3 helicopter in the Kootenay Valley, BC.
https://canadianaviationnews.wordpress. ... -colombia/
https://www.tsb.gc.ca/eng/rapports-repo ... P0019.html
Air transportation safety investigation report A22P0019
Collision with terrain
Kootenay Valley Helicopters Ltd.
Airbus Helicopters AS350 B3, C-GWTQ
Nelson, British Columbia, 35 NM N
16 March 2022
History of the flight
On 16 March 2022, the Kootenay Valley Helicopters Ltd. Airbus Helicopters AS350 B3 helicopter (registration C-GWTQ, serial number 7482), contracted by the British Columbia Ministry of Transportation and Infrastructure (MOTI), was conducting avalanche control operations north of Nelson Aerodrome (CZNL), British Columbia (BC), with the pilot and 2 avalanche technicians on board.
The occurrence flight was the second avalanche control flight of the day. The flight was in the London Ridge avalanche area, approximately 35 nautical miles (NM) north of CZNL, and consisted of dropping strategically placed explosive charges (12.5 kg bags of ammonium nitrate and fuel oil [ANFO] compound) and igniters onto the slope from a height of approximately 20 feet.
The occurrence aircraft took off from the staging area near New Denver, BC, at 1315Footnote1 under visual flight rules (VFR). The crew were the same as on the first flight, but the avalanche technicians exchanged roles and positions: the one who had fulfilled the duties of bombardier (or blaster of record) on the previous flight was the blasting assistant, and the former blasting assistant took on the role of bombardier and planned to deploy 15 explosive charges.
En route to London Ridge, the sky was overcast with scattered clouds at and below the ridgeline with calm to light winds from the southwest. The helicopter was being operated at an altitude of about 7000 feet above sea level (ASL), approximately 100 feet below the ridgeline. The pilot and technicians coordinated the placement of the charges and documented whether they detonated and triggered controlled releases of snowpack. The bombardier was seated on the right side of the rear bench wearing a high-visibility fall-arrest/restraint harness. His role was to deploy charges out of the right-side pocket door.Footnote2 He coordinated the placement of the helicopter with the pilot to achieve the best effect from the explosive charge. The role of the blasting assistant, who occupied the left front seat, was to document the operation.
The bombardier requested an adjustment to the initial target for the second explosive charge to be deployed, and the pilot climbed the helicopter up the slope, nearer to the ridge and close to the base of the clouds. The trees in the new location were more sparse and covered with more snow. The pilot assessed the new location and estimated that, as previously anticipated, his exit strategy to turn left and then fly downhill would be appropriate.
As the helicopter progressed along the mountainside near the upper treeline, the pilot positioned and stabilized it in a hover to allow the explosive charge to be deployed. Just as the pilot lost reference with the ground and flight visibilityFootnote3 was reduced, the bombardier deployed the second explosive charge. At this time, the main rotor downwash and prolonged hover over a layer of loose snow created whiteout conditions.Footnote4
The pilot, with reduced visibility, turned the helicopter to the left. During this manoeuvre the tail rotor contacted either a tree or the surface of the slope; this caused the helicopter to shudder. The high-frequency vibration rapidly worsened and the pilot performed a forced landing. At approximately 1331, the helicopter landed hard on its skids and tipped onto its right (the pilot’s) side (Figure 1). The main rotor and blades were fractured and the tail boom was partially severed. The helicopter came to rest about 3 to 5 m downslope of the second explosive charge deployed; the charge detonated approximately 2.5 minutes later, but did not trigger a release of the snowpack.
Snow entered the cabin through the gap where the pocket door had been removed and through several windows that had broken or popped out. The 3 occupants were initially disoriented and shaken, but were not injured. The bombardier was face down in the snow, still secured in the aircraft by his harness, with bags of unprimed ANFO on and around him. The blasting assistant was still belted in the front passenger seat and was disoriented due to being on his side. The pilot secured the electrical and fuel systems, and he, along with the blasting assistant, egressed from the helicopter.
The bombardier required some assistance to release his harness because his own knife was not easily accessible. He also experienced difficulty releasing his lap belt because the latch mechanism had been taped over.Footnote5 With the assistance of the other crew members, he was released and egressed from the aircraft. The required survival equipmentFootnote6 was on board the helicopter; however, because the helicopter was lying on its right side, the cargo door could not be opened and the crew could not access this equipment.
The pilot was able to remove the emergency locator transmitter (ELT) from its housing, attach the remote antenna, and turn it on manually to ensure that it was activated. The signal was received by the Canadian Mission Control Centre and relayed to the Joint Rescue Coordination Centre (JRCC) in Victoria, BC.
The technicians had a portable radio on board, but it was not readily available after the impact. It had been left on top of the instrument panel glareshield and was displaced during the accident sequence. After approximately a 15-minute search through the snow, it was found. The operator was contacted and informed of the accident, and transportation off the mountain was coordinated.
The JRCC then contacted the operator. It was determined that search and rescue resources were not required because a local helicopter operator could rescue the crew. The local helicopter arrived at the accident site at approximately 1430.
Pilot information
The pilot had a valid commercial pilot licence – helicopter for VFR flight and had completed a pilot proficiency check valid until 01 June 2022. He had accumulated about 11 000 total flight hours, mostly on the occurrence helicopter type. He had many years of experience flying avalanche control missions, and had previously flown similar missions in the same area. The pilot was certified for the transportation of dangerous goods by air. The occurrence flight was the third avalanche control mission in which he worked with these technicians.
Avalanche control operations
The BC MOTI’s Avalanche and Weather Programs unit has a published manual, Explosive Use Operational Plan,Footnote7 that specifies that the Ministry artificially triggers avalanches to reduce the threat of naturally triggered avalanches along provincial highways. As the manual states,
[p]redicting where and when avalanches could occur requires a thorough understanding of the interaction between weather, terrain, and the mountain snowpack. […] The decision to conduct explosive control is based on a complex analysis of current and future weather and snowpack conditions, and the effect these conditions may have on the avalanche hazard.Footnote8
Annual training had been conducted and procedures had been reviewed before the occurrence (during pre-season training in the fall of 2021). Both technicians had over 20 years of experience in avalanche control and were certified for the transportation of dangerous goods by air. Both also had current blasting certification with a helicopter deployment endorsement.
The blasting procedure requires that the deployment of the bag(s) be performed from an ideal height above the ground or slope because the bags could disappear from view under the helicopter, requiring the helicopter to break off the operation to track them and document whether or not they detonate.
The MOTI avalanche control personnel are provided with helicopter familiarization training, which is primarily focused on safety in and around helicopters. Training includes instruction on shutting off fuel and electrical systems and on access and operation of ELTs.
March 2022 tail rotor strike and roll over in Kootenay Valley, British Colombia
1 post
• Page 1 of 1
Jump to
- TOP AVIATION FORUMS
- ↳ General Comments
- ↳ Covid
- ↳ Flight Training
- ↳ Maintenance
- ↳ ATS Question Forum
- ↳ NavCanada Hiring
- ↳ Aviation Videos & Photos
- ↳ Corporate
- ↳ Helicopter Forum
- Employment
- ↳ Aviation Job Ads (Free)
- ↳ Hire me
- ↳ Employment Forum
- ↳ Salary
- Classifieds
- ↳ Marketplace
- ↳ Aircraft for Sale
- ↳ Crash Pads
- Airlines
- ↳ Air Canada
- ↳ Air Transat
- ↳ Flair Airlines
- ↳ Porter Airlines
- ↳ Sunwing
- ↳ WestJet
- ↳ WestJet Encore
- ↳ Additional CAR 705
- ↳ Air Canada Rouge
- ↳ Air Creebec Inc.
- ↳ Air Inuit
- ↳ Air North
- ↳ Air Tindi Ltd.
- ↳ Buffalo Airways Ltd.
- ↳ Calm Air
- ↳ Canadian North
- ↳ Cargojet
- ↳ Central Mountain Air Ltd.
- ↳ Chrono Jet Inc.
- ↳ Enerjet
- ↳ Kenn Borek Air Ltd.
- ↳ Nolinor
- ↳ North Cariboo Air
- ↳ North Star Air Ltd.
- ↳ PAL Airlines
- ↳ PIVOT Airlines
- ↳ Summit Air
- ↳ Sunwest Aviation Ltd.
- ↳ Swoop
- ↳ Trans Capital Air Ltd.
- ↳ Transwest Air
- ↳ Voyageur Airways
- ↳ Wasaya Airways
- ↳ West Wind Aviation
- Announcements & Help
- PRIVATE FORUMS
- ↳ Ladies' Night
- ↳ Mentors
- ↳ AvCanada's Mentor Program
- ↳ Hicks & Lawrence Limited
- ↳ Hope Air
- ↳ Air Inuit
- ↳ Kivalliq Air/Keewatin Air
- ↳ NACair
- ↳ Prince Edward Air
- ↳ Buttonville flying club
- ↳ Canadian North
- ↳ PAL
- ↳ Peninsulair
- ↳ SkyRegional
- ↳ Jazz Private Forum
- ↳ Private Forum Info
- ↳ KENN BOREK AIR LTD.
- ↳ Investing Rumors
- Other Forums
- ↳ Aerobatics & Airshows
- ↳ AvCanada's Wall
- ↳ Around the Camp Fire
- ↳ Drones & UAS
- ↳ Health & Fitness
- ↳ Homebuilders
