WestJet's New Routes: Calgary - Dubai & Calgary - Edinburgh?
This might explain the real reason they pulled their 787 from Toronto, (if this is true):
https://www.flightglobal.com/networks/w ... 53.article
"Canadian airline WestJet looks poised to launch flights between Calgary and Dubai beginning in March 2023, after securing required landing slots at Dubai International airport.
The flights would be the first WestJet routes to the Middle East, and the first to connect the two cities non-stop.
According to slot coordinator Airport Coordination Limited’s (ACL) Dubai International airport summer 2023 initial coordination report, dated 4 November, WestJet has been allocated 186 slots for the 31-week summer travel season which begins on 27 March. It initially requested more than double that number.
WestJet is listed in the report as a “new operator” to Dubai International airport...."
"Further ACL data indicates that WestJet may also begin to operate flights between Calgary and Edinburgh, Scotland for the summer 2023 travel season. "
Eric Janson
Re: WestJet's New Routes: Calgary - Dubai & Calgary - Edinburgh?
Airlines request slots all the time at airports all over the world. Depending on the airport slots can be worth $$. I've seen an Airline sell London Heathrow slots.
Says nothing about whether flights will actually take place.
Calgary - Dubai is pushing the capabilities of the 787 isn't it?
Distance between Calgary (Calgary International Airport) and Dubai (Dubai International Airport) is 7134 miles / 11481 kilometers / 6199 nautical miles.Eric Janson wrote: ↑Mon Nov 21, 2022 5:47 am Calgary - Dubai is pushing the capabilities of the 787 isn't it?
787-8 Dreamliner Range nmi (km) 7,305 nmi (13,530 km)
787-9 Dreamliner Range nmi (km) 7,565 nmi (14,010 km)
The high density altitude of YYC is working against ULH operations. Especially, as you would think, during the summer.
A 787-9 can take off 35R at max gross at -10°. Start increasing temps and it drops dramatically. Running the numbers through our performance computer, my back of napkin calculations gives roughly:
If headed to DXB, 300 passengers at -10°, 260 at 0°, 240 at 10°, 215 at 20°, 160 at 30°. (!). This is at 29.92, with no wind. Carry on and baggage, but no cargo.
averageatbest
There's one thing that we need to remember about the new WestJet. The airline is no longer an airline... it's a branch of Onex.Crewbunk wrote: ↑Mon Nov 21, 2022 7:57 pm The high density altitude of YYC is working against ULH operations. Especially, as you would think, during the summer.
AC is doing the Heathrow Mumbai 5th degree freedom maybe that’s the same plan for WJ
averageatbest
What benefit would that serve WestJet? I believe that the Dubai slots will remain in the same boat as most of the European slots.
mmm...bacon
Who would fly from YYC to Dubai?
If you want to go to an unaffordable featureless place in the middle of nowhere floating on a lake of oil, then take a trip to Ft. MacMurray - at least they won't stone you to death for taking a sip of alcohol!
And, if you want to transit elsewhere in the world, go west through somewhere civilized such as Tokyo, Singapore, or Bangkok.
The benefit being you can fly the route otherwise you won’t have the range to get their. Essentially a tech stop with a crew change and fill back upaverageatbest wrote: ↑Tue Nov 22, 2022 7:19 amWhat benefit would that serve WestJet? I believe that the Dubai slots will remain in the same boat as most of the European slots.
TeePeeCreeper
Your post would seem to indicate that you haven’t worked/lived or visited the UAE. Trust me there’s plenty of cheap booze (legal) and there are more Russian prostitues there than there are in Russia itself! (If that’s your thing) Dubai truly is “the Las Vegas” of the Middle East.mmm...bacon wrote: ↑Tue Nov 22, 2022 8:26 am Who would fly from YYC to Dubai?
TPC
Hear hear I second that
Emirates Airlines.... The first article is from 2010 when they tried to get direct routes but were denied. The second from 2018. Apparently, they see a market in those routes.
https://www.theglobeandmail.com/report- ... le4388369/
https://dailyhive.com/vancouver/uae-can ... tions-2018
Eric Janson
As mentioned there are plenty of other factors that may limit this flight.Mach1 wrote: ↑Mon Nov 21, 2022 7:58 amDistance between Calgary (Calgary International Airport) and Dubai (Dubai International Airport) is 7134 miles / 11481 kilometers / 6199 nautical miles.Eric Janson wrote: ↑Mon Nov 21, 2022 5:47 am Calgary - Dubai is pushing the capabilities of the 787 isn't it?
Since you can't fly over Russia at present - the flight time/distance will be longer. Approximate routing would look closer to Calgary - Amsterdam - Dubai. Extra fuel = less payload.
Operating out of Dubai in the summer is interesting. I've departed there with surface temp of 48c. With a 4000m runway and low pressure we had a 20,000kg performance penalty. This is for a 4 Engine aircraft which generally has an edge over a twin under these conditions.
Russian overflight it certainly a factor. By my best estimation, flight planned distance would be about 6700 nm avoiding Russian airspace.
But, the biggest problem is the high density altitude of YYC.
Granted, I used Air Canada’s performance numbers (I’m using the assumption that the two airlines’ 787-9s are identical with regard to engines/weights). To carry 320 passengers from YYC to DXB, the OAT at Calgary would have to be -14° or colder. Reduce that by about 100 passengers on a 20° summer day and to around half on a hot summer day of 30°!
29.92. No wind. Carry on and checked baggage, no cargo. These are performance limitations, so increasing the licenced MTOW will have no effect.
Westjet needs a 777-200LR.
In Air Canada’s configuration of 300 passengers, 40J, 24 W, 236Y, the beast can fly nonstop to DXB from YYC with an OAT of 30°! (With 22,000 Kgs of additional cargo and the damned thing still wouldn’t even grunt).
vanislepilot
An insane amount of people in my opinion. Think anyone who resides in Alberta from the middle east, India, Africa. This would be a substantial chunk of people. One flight to Dubai then the world is your oyster.mmm...bacon wrote: ↑Tue Nov 22, 2022 8:26 am Who would fly from YYC to Dubai?
vanislepilot
averageatbest
https://www.newswire.ca/news-releases/c ... 57261.htmlvanislepilot wrote: ↑Tue Nov 29, 2022 9:16 pmAn insane amount of people in my opinion. Think anyone who resides in Alberta from the middle east, India, Africa. This would be a substantial chunk of people. One flight to Dubai then the world is your oyster.mmm...bacon wrote: ↑Tue Nov 22, 2022 8:26 am Who would fly from YYC to Dubai?
Knowing the way Onyx works, they probably got the slots just to make sure Air Canada didn't get them. I highly doubt that they will be utilized.
I am expressing no opinion. Just a set of numbers. You are presenting more numbers.Eric Janson wrote: ↑Tue Nov 29, 2022 7:58 am As mentioned there are plenty of other factors that may limit this flight.
AC is already maxed out with the number of flights it can operate, slots make no differenceaverageatbest wrote: ↑Wed Nov 30, 2022 2:21 amhttps://www.newswire.ca/news-releases/c ... 57261.htmlvanislepilot wrote: ↑Tue Nov 29, 2022 9:16 pmAn insane amount of people in my opinion. Think anyone who resides in Alberta from the middle east, India, Africa. This would be a substantial chunk of people. One flight to Dubai then the world is your oyster.mmm...bacon wrote: ↑Tue Nov 22, 2022 8:26 am Who would fly from YYC to Dubai?
Well there is this thing called "hubs". And Dubai is one of the major "hubs" in the world. And judging by the increasingly diverse population in Alberta this would be an excellent opportunity to bypass that huge mess called Pearson and simply fly direct to a major "hub" where you can connect to go anywhere in the world with all kinds of airlines. Or take a few days in the desert to relax and shop. Dubai has a lot of shopping. Yeah it is most definitely not Fort Mac.
averageatbest
My two cents: they'll fly to Tokyo before they fly to Dubai.billhill wrote: ↑Sat Dec 03, 2022 10:19 am Well there is this thing called "hubs". And Dubai is one of the major "hubs" in the world. And judging by the increasingly diverse population in Alberta this would be an excellent opportunity to bypass that huge mess called Pearson and simply fly direct to a major "hub" where you can connect to go anywhere in the world with all kinds of airlines. Or take a few days in the desert to relax and shop. Dubai has a lot of shopping. Yeah it is most definitely not Fort Mac.
https://news.paxeditions.com/news/airli ... ghts-japanaverageatbest wrote: ↑Sat Dec 03, 2022 2:42 pm
"The Canadian Transportation Agency (CTA) has approved a request from WestJet to operate scheduled international service between Canada and Japan, PAX has learned.
As per a determination notice posted on Nov. 30, 2022, the CTA noted that it is satisfied that WestJet, in accordance with the Air Transport Agreement, meets “all the applicable requirements” for operating the service, which would expand the carrier’s global reach quite significantly.
The CTA also found that the terms and conditions of the arrangement have been complied with.
Accordingly, the CTA has issued WestJet a Japan licence, which is subject to conditions within Canada’s Air Transportation Regulations.
Some conditions apply, such as WestJet being authorized to operate scheduled flights on routes as set out in the arrangement, which has not yet been made public."
bobcaygeon
See you in YOW next February at Convoy 2.0!!!mmm...bacon wrote: ↑Tue Nov 22, 2022 8:26 am Who would fly from YYC to Dubai?
It’s the “hubs” thing. If you’re thinking DXB just as the endpoint you’re missing the point of DXB. From there one has extensive access to Africa, Middle East, India, Pakistan, Sri Lanka, Iran etc.averageatbest wrote: ↑Sat Dec 03, 2022 2:42 pmMy two cents: they'll fly to Tokyo before they fly to Dubai.billhill wrote: ↑Sat Dec 03, 2022 10:19 am Well there is this thing called "hubs". And Dubai is one of the major "hubs" in the world. And judging by the increasingly diverse population in Alberta this would be an excellent opportunity to bypass that huge mess called Pearson and simply fly direct to a major "hub" where you can connect to go anywhere in the world with all kinds of airlines. Or take a few days in the desert to relax and shop. Dubai has a lot of shopping. Yeah it is most definitely not Fort Mac.
Performance wise, YYC can clearly be a challenge as others have shown but, as previously mentioned a typical hot, humid summer day in DXB can take density altitude from SL to around 4000’.
So DXB can make sense (cents?!
FlyAlberta
APR 30
