Video of Helicopter crash
WTF was going on there. I know nothing about heliocopters but I've watched other crash videos of them and they usually seem pretty controlled unless they roll on the ground or hit something with the rotor what could have been going on here?
Wait I know maybe a Bumble Bee got inside.
arewethereyet
- low n over
- Bubbaganoosh
linecrew
Here are links to the official NTSB reports:jimmyjazz wrote:WTF was going on there. I know nothing about heliocopters but I've watched other crash videos of them and they usually seem pretty controlled unless they roll on the ground or hit something with the rotor what could have been going on here?
http://www.ntsb.gov/ntsb/GenPDF.asp?id= ... 117&rpt=fa
http://www.ntsb.gov/ntsb/GenPDF.asp?id= ... 117&rpt=fi
- rotorhead350
It was apparently a hydraulic failure caused by a mechanic putting the hydraulic belt on upside down. These particular belts are marked for installation with an arrow so how the guy/gal missed it is anyones guess. I have loads of experience working on these machines and let me tell you the hydraulic system is very hokey. They have now gone to a Poly V belt which is mandatory here in Canada. Not sure about the US though. Anyways it is still an all-round great little machine, very fast and quiet..............rh350
- Rank Moderator
Yes, fly the Astar, and it was hyrdraulic failure handled poorly. The pilot intially radioed a tail rotor failure for some reason, leading to the belief that was the primary issue, it doesn't seem to have been.ch135146 wrote:So, you're a helicopter pilot? Ever had an actual control failure in a helicopter?low n over wrote:Looks more like a poorly handled Hydraulic failure.
If "no" to either question, STFU.
There are three(in a B2, two in BA, B) hyrdraulic accumulators that give you several seconds of pressure to SLOW THE A/C DOWN before they are exhuasted. The proceedure is to get the airspeed back to 50-70kts and then manually dump the remaining pressure in the accumulators so you loose all the pressure at once, if you do not, then one accumulator will run out before the others, ie. the cyclic, then control becomes very difficult. Not reading through the NTSB reports, it seems the pilot here did not follow that proceedure.
The machine is quite flyable with no hyrdraulics, however the a/s MUST be slow (50-70) or the control forces are too great to overcome due to aerodynamic loading.
STL
- rotorhead350
Hi STL and RH350,
Okay, I have not flown the AS350. My experience is on the B212 and B206. Due to long term health effects of near-fatal injuries suffered in a 1984 B212 hi-hover tail rotor failure, I had to stop flying in 1992.
So I have experienced the incredibly rapid onset of "violence" and disorientation felt in the cockpit of a helicopter out-of-control. (The violence of impact with the ground is a separate thing!) (Not to mention the rotor head and main transmission collapsing into the cockpit too.)
Before it happened to me, I too used to jump to the conclusion that the poor bastard pilot "poorly handled" the emergency, i.e. didn't follow the checklist procedure properly. But helo flight control failures, more often than not, result in damage and sometimes injury or death.
Even when handled correctly initially, the inherent instability of the machine and the demanding environments they are flown in, often stack the deck against a happy landing.
In the case we are discussing, the news chopper was hovering at 1,000 to 1,200 feet over Brooklyn just before the problem.
I've read that the AS350 emergency procedure with a hydraulic failure recommends foward flight (40-60 knots,) flat approach to a clear landing area, and a run-on landing. And, that this helicopter requires ample physical strength to fly without hydraulic boost.
So, he had to transition from 0 Knots at 1000AGL to the book speed and put it down ASAP. Sounds pretty easy to read; much tougher in practice.
While he did not correctly identify the hydraulic failure or follow the correct "switchology," I think he would have been pretty much fucked even if he had, given the subsequent flight profile and terrain required for a successful conclusion, and, that the controls were going stiff.
p.s. Too bad the film didn't show the whole sequence.
Regards, Steve
Regards, Steve
- Rank Moderator
Hi Steve,
Sorry to hear about the 212 accident, I just came off my first season on it, scary situation.
With the Astar, the horn will sound at the intial stages of a hydraulic failure, and the accumulators are there to provide up to 30 seconds of control movement, but, and it's a serious but, rapid control movements WILL drain them much faster. In the case of a failure in the hover, the controls would not go stiff immeadiatly, but the horn would sound.
At that point there should be ample time to tranistion to the required 40-60kt safe a/s. If however this was not achieved, the a/c wold become difficult to control.
Hyraulics off in the Astar is not much different than that of a 206, it can be hovered, and flown to a slow approch. Nervousness and/or a delyed reaction to the failire would cause some issues - and rightly so!
Anyway, time to go for a trip.
STL
STL
