Take home pay
Malfunction
Take home pay
Post by Malfunction »
Can anyone comment on take home pay yr 1 and 2 ?
Re: Take home pay
Unfortunately you may need to wait a few weeks as the new CBA pay took effect on the 1st, but won't start being paid out till the 13th. After that really you need to give it another month because the 1st and 15th pay are different in that OT, and pre-diem are paid out on the 15th, and union dues, benefit deductions are on the 1st. When I started it was around 1900 ish on the 1st, and usually 2200 on the 15th take home if memory serves.
Dirty24.7
Re: Take home pay
Post by Dirty24.7 »
Any updates on this?
Monthly Take home F/O and CA pay?
Arnie Pye
Re: Take home pay
Post by Arnie Pye »
You're going to get a wide range of take home pay. With or without a family medical dental plan. With or without your 3% company match. With or without RRSP taken off at source?
You should be able to get a good idea as the biweekly pay is 40 hours at the rate of $147 per hour. I believe 1st year captain pay works out to $5800 prior to deductions. Best guess would be just about half of that amount would be take home +/- family medical dental plan and retirement savings.
flying4dollars
Re: Take home pay
Post by flying4dollars »
Arnie Pye wrote: Fri Feb 03, 2023 9:12 am You're going to get a wide range of take home pay. With or without a family medical dental plan. With or without your 3% company match. With or without RRSP taken off at source?
Wouldn't it be 42.5 hours? In either case take home should be at least $4k per pay without the per diems and OT. When I was there my take home was never less than $3000 per pay cheque without per diems and OT, even on the old scale (before even you).
If in doubt you can use this:
http://www.ees-financial.com/img/upload ... r-2022.htm
Found it to be pretty accurate.
the_new_guy
Re: Take home pay
Post by the_new_guy »
Malfunction wrote: Mon Jan 09, 2023 2:07 pm Can anyone comment on take home pay yr 1 and 2 ?
Depending on your home province, but quickly after taxes in Ontario you're looking at one smaller pay around 3300$ and the other pay depends on what you did, perdiems, overtime as applicable, etc. For example my mid month pay in January was 6200$. Those are after taxes, first year captain.
Hope this helps.
Blueontop
Re: Take home pay
Post by Blueontop »
the_new_guy wrote: Sat Feb 04, 2023 7:28 pm
Hope this helps.
So paid bi-monthly? about 12400 take home per month not inclusive of OT/per diem, etc..
rudder
Re: Take home pay
Post by rudder »
Blueontop wrote: Sun Feb 05, 2023 8:57 am
Hope this helps.
On another thread, Chief Pilot said “take home pay in Ontario approximately $8000 for year 1 CA and $4300 for year 1 FO not including overtime or per diems”.
Blueontop
Re: Take home pay
Post by Blueontop »
rudder wrote: Sun Feb 05, 2023 9:10 am
Hope this helps.
Isn’t Y1 CA $150K, which should be roughly 12k after tax, is there a lot of deductions or other things?
rudder
Re: Take home pay
Post by rudder »
Blueontop wrote: Sun Feb 05, 2023 3:23 pm
You are looking at a 30% tax bill. Add CPP/EI and union dues/pension contribution means keeping 60-66% of gross seems accurate.
flyingcanuck
Re: Take home pay
Post by flyingcanuck »
rudder wrote: Sun Feb 05, 2023 3:26 pm
after regular deductions, rrsp, and ESOP I was bringing in 45-55% of gross. :cry:
JHR
Re: Take home pay
Post by JHR »
flyingcanuck wrote: Sun Feb 05, 2023 3:51 pm
Welcome to Peoples Republic of Canada, comrade!
the_new_guy
Re: Take home pay
Hope this helps.
To be clear, that 6200$ included a little overtime pay, perdiems, etc.
You're looking at a bare minimum of 6600-6700$ monthly tax free. Then add perdiems, overtime, extras, etc.
Y1 Capt
tbaylx
Re: Take home pay
Post by tbaylx »
This is directly from HR;
Year 1 FO:
Total Gross: $3191 biweekly ($6382/month)
After Regular Deductions (union dues, taxes, CPP, EI): $2332 biweekly ($4664/month)
*does not include benefits deductions*
Year 1 Captain
Total Gross: $6440 biweekly ($12 880/month)
After Regular Deductions (union dues, taxes, CPP, EI): $4539 ($9078/month)
Canadaflyer46
Re: Take home pay
Post by Canadaflyer46 »
Hell of a lot better take home than at WJ. Year 1 FO here is $1280 and $1800 for take home each check (if contributing 20% to the WSP)
I bet a Calgary left seat wouldn’t take 16 years either. Food for thought!
rudder
Re: Take home pay
Post by rudder »
tbaylx wrote: Mon Feb 06, 2023 8:46 am This is directly from HR;
Year 1 FO:
Year 1 Captain
Year 1 CA $147.06 x 85 = $12,500 gross per month
Year 1 FO $72.03 x 85 = $6,126 gross per month
Looks like pay is semi-monthly, not biweekly.
Return to “Flair Airlines”
