Air to Air Frequency
This is for general conversation between 1 or more ac that are enroute together and don't want to tie up unicoms etc. Is there one for Canada? I'm reading the U.S has one but don't see anything about a reserved Canadian frequency. I see one mention of someone using 123.45. Anyone?
- Conflicting Traffic
Re: Air to Air Frequency
TC AIM COM 1.5 references AIP Canada GEN 3.4. If you go there, you get the following:
AIP Canada GEN 3.4 wrote:For air-to-air communications between pilots within Canadian Southern Domestic Airspace (SDA), the correct frequency to use is 122.75 MHz; in the Northern Domestic Airspace (NDA) and the NAT, the frequency allocated by ICAO is 123.45 MHz.
Conflicting Traffic please advise.
Interesting, I didn't know that. I always used " the fingers". Thanks for sharing.Conflicting Traffic wrote: ↑Wed Jan 11, 2023 2:07 pm TC AIM COM 1.5 references AIP Canada GEN 3.4. If you go there, you get the following:AIP Canada GEN 3.4 wrote:For air-to-air communications between pilots within Canadian Southern Domestic Airspace (SDA), the correct frequency to use is 122.75 MHz; in the Northern Domestic Airspace (NDA) and the NAT, the frequency allocated by ICAO is 123.45 MHz.
Fingers, five across, bullshit. 19.95 whiskey, 29.95 cheap suit etc....
I've used cheap suit, and I think there was cheap shoes too but I can't remember it.
If you're on 126.7 some guys say "go up a nickel". That would mean to talk on 126.75 MHz.
Up in northern Ontario, we used to use "Go Canada" as code for 118.67 (1867 year of Confederacy).
- schnitzel2k3
