I'm very confused and wanted some clarity if I can get it. I'm reading about 3 different tabs on aircraft, balance tabs, servo tabs, and anti-servo tabs. Everything will be related to an elevator.
A balance tab moves in response to you moving the control column up or down and helps you move the control column.
A servo tab is on a free floating elevator and when you pull back on the stick, you are moving the servo tab which then moves the elevator using aerodynamic forces.
An anti-servo tab is more like an anti-balance tab and when you move the elevator up or down, the anti-servo tab adds control pressure.
Am I getting this right?
Tabs on Control Surfaces
- Conflicting Traffic
Re: Tabs on Control Surfaces
You're basically correct. The terminology can vary a bit depending on what source you look at. For example, what you're referring to as a 'Balance Tab' can also be called a 'Servo Tab'. It's not required that the control surface be free floating for the tab to be considered a servo tab. Also, note that a single tab can serve two purposes. For example, the trim tab on a Piper Cherokee is also an anti-servo tab.
Conflicting Traffic please advise.
